What is the level of repairability of these equipements ?
  • SistMaticZ
    replied
    Re: What is the level of repairability of these equipements ?
    Originally posted by Curious.George
    But, if, for example, the welder (or charger or VFD or...) uses parts with "house" markings (I'm trying to avoid using the term "proprietary") and the manufacturer doesn't make those parts available to you, then you're SoL.
    Thanks for the quick reply.
    I am currently trying to figure out what to do in my bench , should i do repairs only or combine it with something else like selling stuff to cover a respectable income.
    What i am doing right now is repairing inverting welders as i can find spare parts like igbts relatively easily , and also this equipement isnt very complicated to undersrand and troublshoot for me.
    Now am afraid that welders will use like you said in house power components witch is not the case nowadays but it is the case of VFDs.
    I hope am still fine with welders of any type ; At least thats what am good at right now .
    I also have some skills with laptops and software repairs .
    I find smartphone very delicate and not a good bisness for me too much microscopic components with high integration level and hard disassembly.
    If someone got another point of view it is very welcome.
  • Curious.George
    replied
    Originally posted by SistMaticZ
    lTaking in consideration component availability and cost , repair difficulty and overall faisability of the repair for a sustained monthly income in my bench ; Can you put these equipement from the most repairable to the least repairable
    * Inverting welders - heavy duty 3 phase welders
    * Battery chargers smps and linear
    * variable frequency drives.
    * industrial electrical systems and automated systems.
    * high power switch mode power supplies
    * laptops and desktops
    * smartphones and tablets.
    That will depend on the sorts of failures you encounter and the availability of appropriate "spares". All are repairable -- if you have the equipment and skillsets to diagnose and perform the repair.
    Phones/laptops/tablets/desktops can avoid this problem because there is a sizeable market for certain common replacement parts that might not apply to the other "industrial" devices.
    Also, keep in mind the expectations of your customer in each of these markets. A bit of kit used on the production line will probably NEED to be repaired ASAP if it unavailability is effecting "output". And, the customer will likely be really intolerant of a fix that craps out in short order -- regardless of cost.
    A laptop customer might WANT his device repaired ASAP but, typically, has alternatives available and isn't as dependant on having it working as the industrial client.
    replied
    the laptops/phones/tablets need very different tools to the others - dont mix them.
  • What is the level of repairability of these equipements ?
  • x_orange90_x
    Busted panel corners... Repairable?
    by x_orange90_x
    I have a 50" Toshiba bezel-less that I replaced backlights in a few weeks ago. The tape didn't hold well so the panel started hanging from the top. The pressure caused the two bottom corners to shear off. I can see a court contact on the right corner, but the left is gone in assuming. The screen is not cracked anywhere else, but it displays no image.
    Is it at all repairable? I'm assuming not....
    02-02-2025, 04:17 PM
  • guizmo1967
    Xbox Series X, is this repairable ??
    by guizmo1967
    Just look at the pictures and tell me if this Xbox is scrap or repairable ?
    I removed the mosfet next to the blown one to see what the traces look like ! Pictures are from top and bottom.
    Thank...
    02-02-2024, 12:18 PM
  • guizmo1967
    Is this trace damage repairable ??
    by guizmo1967
    I fried the CPU by mistake, every coils around it was shorted ! So I decided to remove it, I did a good job except when I cleaned the CPU traces, one lifted up !!
    In the picture you can easily see it, is it repairable ?? It is ground.
    To the right, you can also see some solder mask got removed, is this a problem ??
    Would you throw away that motherboard ??
    Thank you !...
    08-21-2023, 05:59 PM
  • ipatch
    troubleshooting microsoft surface pro 4 no power no led charge light
    by ipatch
    hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
    10-05-2023, 11:59 AM
  • shamzeli
    Dead Iphone 6 plus . İs it repairable?
    by shamzeli
    My friend has an old iphone 6 plus (dead by liquid damage long time ago), no previous repair trials have done.
    i opened it the first time yesterday.
    My observations ;i am doing reparing things as a hobby, not as a professional
    1- the liquid damage indicator on top is red, the one on the side still white.
    2- no obvious corrosions or blown component (i removed all shields).
    3- no short on pp_batt_vcc neither on vcc_main.
    4- when connecting the charging cable: with the battery connected it draws 440mA fixed, when battery disconnected...
    08-24-2024, 12:13 AM
