Ridiculous Rheostats
  • 370forlife
    Large Marge
    • Aug 2008
    • 3112
    http://www.ocforums.com/showthread.php?t=312170
    I followed the instructions there to calculate which rheostat I need to get to control my 92mm nidec's, I wound up needed a rheostat about 4 ohms, 6.42W.
    After checking all the major websites, any that had some close enough were about $25-50. ridiculous.
    Anyway, is there any other cheaper way to do this? Each fan is 12v, 1.1A. One will be controlled independently from the other 2.
  • Krankshaft
    • Jan 2007
    • 2328
    Re: Ridiculous Rheostats
    Rheostat haven't heard that term in awhile. Gone the way of LPs and 8-Track tapes .
    They used to use them (among other things) as dimmer switches before triacs. As you probably can guess they heated up ALOT and I'm sure caused a few fires.
    This is quite simply the caveman way of reducing fan speed. Can't screw up installing a 2 terminal device .
    2 ways to do this:
    Voltage Regulation
    Pulse Width Modulation
    Voltage Regulation
    With the VR route you set up a variable voltage regulator (with a suitable heatsink rated for the total current draw of the 2 fans) tie 1 resistor and a POT (in a voltage divider arrangement) to the control pin and ground and you have a speed controller.
    The disadvantage of this is heat dissipated you also must make sure that the fan will start from a dead stop at your selected speed (voltage) and not stall. Since each fan model has a minimum voltage needed to overcome inertia. Once it's going it will continue this is a quick check and only needs to be done once.
    Also the speed range adjustment of the fan will be limited for the reason described above.
    Building this yourself isn't practical and would probably cost more than buying a PWM fan controller premade. Basically it switches the fan rapidly on and off from 0V to 12V to regulate it's speed.
    Check this link out about regulating DC fan speeds:
    http://www.analog.com/library/analog...fan_speed.html
    • 370forlife
      Large Marge
      • Aug 2008
      • 3112
      Can you draw a diagram or something of the VR method?
      Any specific ratings I need to look for the voltage regulator, the resistor, and the pot?
      • PlainBill
        • Feb 2009
        • 7034
        By searching on LM317 I found a number of circuits, and component calculators for it. This guy has a 12V to 9V regulator using an LM317. With a few modifications you can have a variable speed control for your fans. The most important one - attach a heat sink to the LM317. I recall there was an earlier thread, but I don't remember what you want to do. The big choice - do you want the fans to run at a fixed speed, or do you want to adjust the speed easily. If you want an easily adjustable speed, get a 1K pot with a shaft and put a knob on it. Otherwise use a simple trimmer pot.
        PlainBill
        • lucky13
          • Aug 2007
          • 412
          Is the 4ohm to be in series with the +12v line to reduce the voltage at the fan to something like 7v?
          If so, and assuming you don't need to adjust the fan speed, you could buy a 3.9 or 4.3 ohm 10W resistor and just wired it up. There are some wirewound resistors that can be chassis mounted so use your computer case as heatsink.
          • 370forlife
            Large Marge
            • Aug 2008
            • 3112
            I think I am just going to break down and get a lamptron fc-2 controller. Does PWM with 4 channels at 20w each. blue led lit dials and a black finish in a 5.25" bay.
            Only 20 bucks too.
            • PlainBill
              • Feb 2009
              • 7034
              Only 20 bucks too.
              That would be gross overkill, but probably it would be cheaper than building one yourself. Even more so if you factor in the hassle of building it.
              PlainBill
              • 370forlife
                Large Marge
                • Aug 2008
                • 3112
                Each one of these fans are 13.2W (1.1A). 110cfm nidec screamers.
                • PlainBill
                  • Feb 2009
                  • 7034
                  I prefer quiet fans. If I want screaming I can always complain about my wife's housekeeping.
                  PlainBill
                  • Toasty
                    • Jul 2007
                    • 4171
                    >>If I want screaming I can always complain about my wife's housekeeping.<<
                    OUCH !!!
                    veritas odium parit
                      NVDC charger configuration...
                      11-05-2024, 03:28 PM
                      MT3608 Step-Up Converter IC Datasheet
                      The MT3608 is a constant frequency, 6-pin SOT23 current mode step-up converter intended for small, low power applications. The MT3608 switches at 1.2MHz and allows the use of tiny, low cost capacitors and inductors 2mm or less in height.
                      Internal soft-start results in small inrush current and extends battery life.
                      The MT3608 features automatic shifting to pulse frequency modulation mode at light loads. The MT3608 includes under-voltage lockout, current limiting, and thermal overload protection to prevent damage in the event of an output overload. The MT3608 is available...
                      10-07-2024, 05:02 AM
                    • mscottdoran@gmail.com
                      Can anyone identify the classification of this data signal?
                      by mscottdoran@gmail.com
                      Hi, I'm an elevator technician. The attached oscilloscope display picture is from a digital elevator hall arrival lantern data signal. We have been having problems with “ghost signals” causing intermittent hall arrival lanterns to illuminate randomly when the elevator is not actually due to arrive at the floor.
                      The tech support of the hall arrival board manufacturer (CE Electronics) is blaming the elevator controller manufacturer (MCE), and the tech support of the elevator controller blames the hall arrival board manufacturer.
                      The boards are powered by a ground referenced...
                      02-08-2025, 11:31 AM
                      ISL95836 Laptop PWM Controller Datasheet
                      The ISL95836 Pulse Width Modulation (PWM) controller IC
                      provides a complete solution for IMVP-7/VR12 compliant
                      microprocessor and graphic processor core power supplies. It
                      provides the control and protection for two Voltage Regulators
                      (VRs). The first VR, typical for Vcore, incorporates 2 integrated
                      drivers and can operate in 3-, 2- or 1-phase configurations. The
                      second VR, typical for graphics, incorporates 1 integrated
                      driver and can operate in 2- or 1-phase configurations. The two
                      VRs share...
                      11-05-2024, 03:31 PM
                      Richtek RT8205L RT8205M Power Supply Controller for Laptop Computer
                      The RT8205L RT8205M is a dual step-down, switch mode power supply controller generating logic-supply voltages in battery powered systems. It includes two Pulse-Width Modulation (PWM) controllers adjustable from 2V to 5.5V, and also features fixed 5V/3.3V linear regulators. Each linear regulator provides up to 100mA output current with automatic linear regulator bootstrapping to the PWM outputs. An optional external charge pump can be monitored through SECFB (RT8205M). The RT8205L/M includes on-board power up sequencing, a power good output, internal soft-start, and internal soft-discharge output...
                      10-23-2024, 03:58 AM
