Hello everyone I'm trying to identify the blue capacitor in the pic. I was at the electronics store today and they gave me the ones in the package also in the pics. They seem to be half the size of the blue ones in the board now. This capacitor comes out of a LED TV.
Help Identify Capacitor
Tags: None
Re: Help Identify Capacitor
R_J thanks the blue one blew the back out for what ever reason. So a 2KV would have worked also?Comment
It would be better to use 2KV, that is snubber cap and it is common failure cap.Never stop learning
i seriously doubt those new ones are 1Kv,
they look too thin.
i never trust NTE, they started as a company buying obsolete/surplus parts and re-selling them with there own numbers on them.
a good excuse to sell a lookup-table.Comment
Not sure if I'm breaking a forum rule by posting a link. Here is what I found as far as USA stock, but these are 3KV.
Anyone comment?Comment
Check digikey: Here is one 490-4168-ND
https://www.digikey.com/products/en/...=1&pageSize=25
or
Some brands like Vishay are smaller, tdk are larger (and blue) its just how they are madeLast edited by R_J; 04-10-2019, 04:37 PM.Comment
Thanks R_J is one brand better than another? I saw some cheap ones on amazon entire kits of 100 pieces and people complaining a failures and not within specs so figured don't bother.
Also when this cap popped I didn't see any other damage. I just did ohm readings on the nearby components.Comment
Sometimes the fet can go also, if its not shorted, put one of the nte caps you have and try it. Then you will know. Its a snubber capacitor, its value is not that critical. If you want to replace it with a 2kv, any of those from digikey will be fine.Comment
R_J think i can just use the NTE I bought as pictured in a previous post just as a test to see if the thing turns on? Then I'll go get the 2KV.
Or is that NTE not a snubber cap?Comment
The capacitor is used as a snubber in that circuit, It is used to suppress any high voltage spikes created by the switching circuit. It protects the fet from any high voltage spikes that could damage it. The nte will work. its just good practice to to use a 2kv as it will handle the higher high voltage spikes.
the nte cap can be used anywhere in this case it is used as a snubber.Comment
As did Mouser. Back in really ancient times there was Poly-Paks, who I think bought up floor sweepings and reject bins. Long, long ago in a desert far, far away, Honeywell Phoenix had a warehouse where they sold all kinds of surplus parts. De Vry students loved the place (Dervy was on 24th St. and Highland Ave. at the time).PeteS in CA
****************************Comment
Yeah, they were kind of a grab bag kind of thing. This was somewhere around 1970, when our school cafeteria was serving the last of the frozen dinoburgers.PeteS in CA
Hi all well, replaced the cap and nothing. Checked some pins that lead to the logic board which have about 4 pins stating 13VDC, but nothing. Then went back to hot side of board, and the fuse is good, get 120V, checked a bridge rectifier, I get no AC or DC on it. On the hot side of the board, I get low voltages all around the board about 8.3 volts.
i attached some more pics of the board.Attached Filesif you find these attachements useful please consider making a small donation to the site
I am guessing this is a samsung board, bn44-00740a, If you have no a/c on the bridge you will not have any voltage at all, anywhere. are you sure your meter is working?
Check the fuse and then check VX801S
What are you using for ground when checking voltages on the hot side?
You also need to tell us which pins you are checking that have voltage "Some pins" does'nt mean anything.
I see that cap was just across a diode, I thought it was across a fet like on some power suppliesLast edited by R_J; 04-12-2019, 04:03 PM.Comment
Yes correct it's a samsung BN44-00740A...maybe I should have started another thread under the TV troubleshooting?
So on the hot side I just used one of the board screws.
Not sure how to test that mov while it's in the board can that be done with a multimeter, I found not good youtube videos on those while in circuitComment
When checking DC in the primary, always use the (-) of the main bridge rectifier, that is refered to as HOT ground
Correction, The mov VX801S will check open, NT811S should check low (2.5Ω) I got mixed up looking at the top and bottom pictures.
To eliminate a bunch of checking, measure the DC voltage across the (-) and (+) of the bridge rectifier.
Next measure the voltage across the main filter CP811S
You said you measured 13 vdc on CNM803 plug, This voltage on the secondary CAN be measured to ground, You can check this voltage on any of the JP808-11 jumper wires.
If you have 13 volts, then Unplug the tv, disconnect CNM803 from the main board and plug in the tv and see if the backlights come on (they may or may not)Last edited by R_J; 04-12-2019, 06:00 PM.Comment
by MORETTIGIANTitle:
Capacitor detached from PCB – RTX 2070 Super Founders Edition
Description:
During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
I did not notice it detaching, so I am unsure of its original location on the PCB.
Procedure performed:
- Removed backplate
- Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
- Reapplied thermal compound
- Reassembled card
Observed behavior after reassembly:
- GPU powers on and operates normally under...11 Photos -
This specification for the Microsoft Surface Redbank i5/8/256 Blue Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Redbank i5/8/256 Blue boardview and Surface Redbank i5/8/256 Blue schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...09-07-2024, 05:50 AM
This specification for the Lenovo IdeaPad IP3 14 I7-1255U 8GB 512GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 14 I7-1255U 8GB 512GB BLUE boardview and IP3 14 I7-1255U 8GB 512GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...09-07-2024, 05:00 AM
This specification for the Lenovo IdeaPad IP3 15 R7 5825U 8GB 512GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 R7 5825U 8GB 512GB BLUE boardview and IP3 15 R7 5825U 8GB 512GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...09-07-2024, 05:00 AM
This specification for the Lenovo IdeaPad IP3 15 I5-1235U 8GB 256GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 I5-1235U 8GB 256GB BLUE boardview and IP3 15 I5-1235U 8GB 256GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...09-07-2024, 05:00 AM
- Loading...
