measuring Vcore
  • BigAlNZ
    • Mar 2008
    • 65
    measuring Vcore
    Hi Guys,
    I have been playing around with measuring Vcore on some old motherboards.
    Quite simply I have been turning the mobo on and putting negative on a mounting screw ground and positive on one of the caps along the side of the cpu.
    Is this correct?
    Now its all very well being able to measure Vcore but I need to know what it should be? I assume for a given socket Vcore is a set value, or does Vcore change depending on the CPU?
    Ie Dual Core and Quad core can both fit a 775 socket, but can they have different Vcores? (ignoring overclockers here for a mo)
    I have had a look at a few intel data sheets which seem to specify Vcore, and sometimes a voltage range for Vcore.
    When a mobo has bad caps, can it be shown on a DMM with a Vcore that is way outside values?
    Is Vcore and Vcc for a CPU the same thing?
    Cheers
    -Al
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: measuring Vcore
    Vcore should be measured on the Coils next to the CPU, these are the closest things you can generally reach from the topside of the board...
    The most accurate is to measure directly on the underside of the CPU socket, wikipedia for example has pinouts, and pinouts.ru too
    But that's really overkill...
    In the olden days CPU's where just binned at the factory for the speed which they would run reliably at, all CPU's sharing the same vcore
    So for example you had Barton based Athlon XP CPU's and they ran at 1.65v
    And from 1666Mhz > 2100Mhz
    But nowdays it's more complex, CPU's are binned both for speed in Mhz but also at how low a voltage they can run
    So nowdays the CPU's differ in vcore, they have a range they accept but every CPU will be different
    My current Q9450 for example has a VID of 1.25v, but it could be anything between 0.85v - 1.3625v
    The lower the reported vcore voltage is the cooler the CPU will run and generally the more it will overclock...
    http://www.cpu-world.com/CPUs/Core_2...569Q9450).html
    Core Temp can be used to check the VID of a CPU; http://www.alcpu.com/CoreTemp/
    As for the actual Vcore voltage you should see that is set by the BIOS
    Or on older boards by switches on the board itself
    Vcore flucuasions can be measured by a DMM, but it is normal to see fluctuations, when the CPU draws 100% power vcore will sag, this is normal
    You will not know if you have bad caps or not, for that you need a ESR meter
    • shadow
      • Feb 2007
      • 732
      Re: measuring Vcore
      I can not talk about all processors here. However of the processors that I have had experience with. It is the CPU that governs the VCore voltage. Different CPU's fitting the same socket run on slightly different voltages.
      In my experience, even two 'identical' CPU's can have different Vcore voltages. When I say identical, I mean the same socket and processor speed. The steeping of the CPU's were different. The two CPU's were manufactured at different times and hence they are not exactly identical CPU's but extremely similar CPU's.
      I am not sure why this is the case, I just know that it is.
      • gdement
        • Jan 2007
        • 690
        Re: measuring Vcore
        Intel started not specifying an exact Vcore during the late P4 days. So-called "multi-VID" chips started coming out, meaning you don't know what VID is programmed on a given chip, even if you know the S-spec code.
        You can test without a CPU just to see if it's a CPU killer. But on a good board the reading will either be 0v or maybe a minimum value until you actually plug a CPU in to it.
        At least on older boards, the CPU pulls various pins either to ground or +(5v?), and the VRM uses those signals to set it's voltage. Without a processor, the board pulls all of them one way (ground probably) which corresponds with the minimum Vcore setting.
        When using caps (or anything else) to measure Vcore, ideally you should check for continuity with the proper pins on the CPU socket so you know it's actually on Vcore. Sometimes unexpected stuff can be near. I remember an ABit board which actually had AGP caps *above* the Vcore caps. Nuts, but I checked it several times and I'm sure that's what they were.
        • gg1978
          • Dec 2004
          • 431
          Re: measuring Vcore
          VRM signals float high, and the CPU pulls some of them down to ground to signal what voltage it wants.. So, if all pins are high ie "1111111", that means there is no CPU in socket, and VRM will be turned off. VRM 8.1 started out with a 4 bit VRM id, while VRM 11, the latest one, basically has a 7 bit VID..
          I forget exactly which VRM spec allows Vcore to change dynamically with CPU loading/clockspeed.. Probably past VRM 9.0 i'm guessing.. As Per Hannsen says, the output inductors are a good place to probe, as you're less likely to short something out. The actual Vcore will be very slightly less than what you measure at the inductors, even though the trace that goes to the CPU is massive, but then again, the current and the delta current are very high as well..
          Try putting your video card in the other PCIe slot.. I've seen some nvidia boards with a bum pcie slot, but putting the card in the other one would allow the board to POST. Or try a PCI video card..
          • BigAlNZ
            • Mar 2008
            • 65
            Re: measuring Vcore
            Thanks. Thats a pretty good reply.
            What about measuring Vdimm - is that more straight forward?
            • Per Hansson
              • Jul 2005
              • 5895
              • Sweden
              Re: measuring Vcore
              Yea, I generally measure Vdimm on the memory socket itself, it is possible to get a probe touching the lead even when you have memory in the socket of most sockets I've seen
              It can also be measured on the mosfet that delivers current to the memory of course...
              As for the voltage this too is set by the BIOS, but if you run at "Auto" the voltage should be whatever is programmed into the SPD, or if there is no voltage info in the SPD just what the JEDEC spec says for that type of memory
              Though variances occur here too due to "performance memory" where manufacturers run the memory at voltages outside the JEDEC spec to attain higher speeds...
              • sam67
                • 256
                Re: measuring Vcore
                Is there any where that shows you a bit more in depth i.e photo's of examples as to where to check with dvm as i would like to learn some of these measurements ..Any help appreciated.
                Cheers
                • Headcase
                  Re: measuring Vcore
                  How is the Vcore on a 'dead' motherboard tested? I have two machines (possibly) in need of recapping, and one of them doesn't power on. I don't have spare CPU's, they're both Intel but different socket types. I tried testing the dead machine at the coils, and got 0.3V with the chip in, and nothing without the chip installed. How do I tell if this motherboard will kill a CPU, or if it has?
                  Thanks,
                  Headcase
                  • ChaosLegionnaire
                    HC Overclocker
                    • Jul 2012
                    • 3266
                    • Singapore
                    Re: measuring Vcore
                    due to variances in things like dust particle count and level of impurities present in the silicon wafer during manufacturing, each and every cpu manufactured is "unique".
                    this "uniqueness" most often manifests itself during overclocking. when no two cpus from different batches can overclock to the exact same speed with the exact same vcore unless u're really lucky.
                    due to that, each cpu has different voltage requirements to stay stable at their specified binned speed. also, from what i heard about how intel bins their cpus, they usually test whats the max stable speed a cpu will be at a given voltage then mark it down 2 speed bins and then sell it. thus if u have a 2.4ghz cpu, its actually been tested to be stable at 2 speed grades higher at 2.8 ghz.
                    hope this sheds some light on the question raised about vcore differences among cpus of the same speed.
                    • Headcase
                      Re: measuring Vcore
                      I think I should restate, maybe I rambled too much and didn't describe my problem succinctly, sorry about that.
                      The revised version: ()
                      I have a machine that won't power on, and it looks like the board needs recapping. I'd like to test the vcore first to see if it's going to kill the CPU or not. Is this possible to do, and if so, how?
                      • Per Hansson
                        • Jul 2005
                        • 5895
                        • Sweden
                        Re: measuring Vcore
                        The voltage is set by the CPU.
                        But there are CPU test cards you can buy on eBay, they have diodes lighting up telling you if there is a faut, short etc...
                        On the other hand there are also CPU's costing just a few dollars you can buy on eBay
                        • barry101
                          Apple 820-3662 VCore shorted to ground.
                          by barry101
                          Hi, Would appreciate some help.
                          I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
                          Get charger light but no fan spin or chime. No liquid damage.
                          Found PPBUS and VCORE both shorted to ground. Other rails were ok.
                          Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
                          With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
                          Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
                          06-24-2025, 07:34 AM
                        • Francisco.s
                          CPU vcore missing in HP workstation Z2 Mini 4G
                          by Francisco.s
                          Hi, have a HP workstation Z2 Mini 4G for repair with CPU vcore missing.
                          The resistance at the output of CPU vcore coils, is less than one ohm so I think CPU could be damaged, but no mosfet are damaged.
                          It mounts an i7 8th gen, and have only i5 7th gen for test, but I think it is not compatible.
                          Without CPU in the socket there is no short, but there is no vcore voltag, and it emits a beep like no detecting ram.
                          The controller chip for cpu vcore is a MP2949A, and has no enable voltage at pin 37.
                          I wonder which circuit generates this enable...
                          04-22-2024, 12:35 PM
                        • mikzs
                          Rx580 8gb sapphire nitro+ turn off vcore randomly
                          by mikzs
                          Hello, this is my first post, English is not my native language but I hope you understand me. I recently got a 580 that didn't turn on the typical short mosfet, as I didn't know exactly which one was short, I unsoldered them until I got the bad one out, I was able to remove the short and identify the bad mosfet, the gpu gives video again! but it has a problem that completely turns off vcore at random times or if I try to put a load on the gpu vcore drops to 0 I don't have much idea why because I don't know much about sapphire, any advice on where I could start looking or what problem it could...
                          11-06-2023, 12:28 PM
                        • c_corr
                          Asus P4C800-E VRM issues
                          by c_corr
                          This board had the initial fault in VRM with high side Mosfet from PWM1 (phase 1) getting very hot. It also had the VRM caps quicly heating up in 10-15 seconds after power on.
                          This board uses mext ICs and Mosfets in VRM:
                          - ADP3180 PWM controller - in 3 phase mode
                          - ADP3418 as Modfet drivers
                          - High side Mosfets STD38NH02L (from ST)
                          - Low side Mosfets STD90NH02L
                          Some of the symptoms were very similar with the "Dead Asus P5P800-VM" in this forum.
                          I had the sawtooth voltage on Vcore too this was probably the cause of the Vcore caps...
                          02-08-2025, 11:59 PM
                        • jm942
                          Hp Lh482p 5 short 3 long short after cpu vcore mosfet replacement
                          by jm942
                          My laptop went dead and after checking ,the main 19 volt power rail was shorted. After some checks i could identify that a high side vcore mosfet was shorted.
                          I replaced the mosfet and now the white powerled is present , fans start spinning but capslock shows the famous 5 long and 3 short code.
                          I checked the vcore voltages after replacement and i get for all 1.01 V so means for me that the driver is still working of the replaced shorted mosfet. On the Nvidia i measure around 0.8 V after the mosfets.
                          I did voltage injection on the cpu with 0.7V and i have a current...
                          07-11-2024, 05:11 AM
