Best "Bang for the Buck" Fluke DMM
  • VictorVictor5
    • Jun 2017
    • 23
    • US
    Greetings all -
    Now that I am done school, it's time to get my own DMM - can't use their stuff anymore.
    I'm used to using Fluke at school (forget which model number), and I know they can get pricey quick. I'm looking for the best "bang for the buck" one in terms of being able to do resistance, capacitance, etc. for all around electronics repair. I don't need a benchtop one.
    Any suggestions?
    Thanks!
    VV5
    • 31278
    Re: Best "Bang for the Buck" Fluke DMM
    for electronics work your limited and it's going to be expensive,
    most fluke meters are aimed at electricians and such.
    you may want to look at the other brands.
    low end - uni-trend
    mid-end - brymen
    high-end - hioki, keysite etc.
    i own 5 multimeters btw, dont expect to only need one.
    • Beau28713
      • Feb 2018
      • 50
      I use the Fluke 117 as my primary and the Extech EX520 as my back up. They both are not that expensive and they work real well for me.
      • retiredcaps
        • Apr 2010
        • 9271
        A budget would help us help you. Also, buying used, could yield good bargains if you know what to look for.
        --- begin sig file ---
        --- end sig file ---
          • Jul 2011
          • 6070
          Originally posted by VictorVictor5
          Greetings all -
          Any suggestions?
          Thanks!
          VV5
          What will your main use for this meter do you need to see your results remotely
          This will determine what meter would more useful
          Here is the reason I bring this up
          I work on overhead cranes and sometimes I need to run the crane on the ground and watch the current or the voltage also on the ground
          Fluke 3000
          Fluke 902FC
          Fluke has a Bluetooth function that lets you see your meter reading up 10 meters away from the meters it works very well ( but you have to give it some time to connect to the software once it connects it works very well until you close the —>Apple Application this is only version I have used )
          ( one note if you need this type of meter with this function I would not recommend any other brand than a Fluke)
          So it depends on what you need to use it for
          I need this type of meter for troubleshooting equipment that is very hard to see the meter results
          I do not use this as an every meter I only use when I need see the meter results remotely
          Now if you do not need this type of meter then are some good meters out there
          MASTECH MS8261 ( I have used a Mastech meter before but not this model )
          Fieldpiece LT83A ( I have an older model than this one which is no longer available )
          Sears also has some good meter as well but you need to look at the meters that are over $50.00
          There meters are very rugged and can take some abuse and still keep working
          ( one note do not be tempted to buy there meters that have the Bluetooth function meters the software DOES NOT work with Apple app or does the Android app —>
          I return the meter because I could not get it to work )
          I have a few of the Radio Shack meter which works very well but I do not find that they are as rugged as some other meter are as far as dropping them is concerned
          I hope this helps
          • PeteS in CA
            • Aug 2005
            • 3583
            • USA, Unsure of Planet
            I suggest doing a little planning before pricing models:
            * What features do you need?
            * What features do you want that are not essential, but you would use fairly often if you had them?
            * What accuracy do you need? The basic accuracy for DC volts for a Fluke 287 is .025%, really nice. But do you need that kind of accuracy when the price is around $400? A .05% or .1% DMM will cost much less, and .1% error in measuring 12V is just 12mV.
            Though not extensive, I've had good experience with Extech meters, similar features and accuracy, less pricey than Fluke (I've been using Fluke meters for nearly 40 years, so I have nothing against them).
            PeteS in CA
            • jm1234
              Reolink RLC-410-5MP - buck convertor
              by jm1234
              it's a PoE camera and it stopped working. Using thermal image I identified failing component U22 marked as 16AF which seems to be buck convertor TI https://www.alldatasheet.net/datashe...62569DBVR.html. I took it out and It is inteed shorted on the output. However, after I took it out, the resistance between the output pads (on the board) still shows 190ohm, is that bit low?
              Another issue is, seems to me I must be missing one of the tiny resistors R810 that should make up the voltage devider for the buck convertor. Honestly I did this months ago, I cannot...
              07-14-2025, 04:30 AM
            • Khoja
              Fluke 123 no image on the screen
              by Khoja
              Hello experts,
              I recently purchased a used Fluke 123 Industrial Scopemeter from an online Japanese auction site (jauce.com). It has now been delivered. Unfortunately, I overlooked the fact that the seller neither guarantees its working condition nor accepts returns.
              When I power it on, the backlight comes on, but there is no image on the screen. After opening the device, I noticed clear signs of previous soldering in several areas (photos attached). It seems someone attempted repairs before.
              At this point, I'll have to try and fix it myself. Has anyone here...
              04-10-2025, 09:24 AM
            • GGEZ
              16IAH7H minor liquid damage around GPU buck. boardiew and schematic included.
              by GGEZ
              Hi. I have a lenovo 16IAH7H (NM-E231) with a small amount of water spilled on the RT8816CGQWGPU buck converter. When powering on, keyboard lights up, fans will spin slowly. CPU and GPU are getting hot. No image. Not via HDMI either.
              Part number is PU4001. The liquid spillage looked minor so I cleaned it up with some alcohol and cleaned ups some crusty joints with solder and flux.
              BoardView and schematic is provided. The buck converter diagram is on PAGE 107.
              I'm inquiring about any troubleshooting tips like probe points to measure and such. I can...
              08-19-2024, 03:18 PM
            • SluggerB
              Best bang for the buck system you could build with native Win7 support?
              by SluggerB
              What would be the latest rev of hardware and CPU technology that would natively support Windows 7? I am fine slip streaming in USB3 drivers if the mobo only has those, but I am leary about building a ryzen system that has to rely on unofficial drivers from random message board posts
              My primary usage is generally office type PC stuff,. but I run a few VM's so I would want to go heavy on the RAM (like 32gb which is heavy to me) but also light on the wallet. I already have a spare HDD so that could be left out of the equation.
              Any build suggestions?
              02-08-2021, 02:21 PM
            • Baldbentley
              repairing a Fluke 335 clamp meter
              by Baldbentley
              I am repairing a Fluke 335 clamp meter. After contacting fluke it appears there is no service manual or circuit board/ component list available. I have determined that there us a faulty PNP bipolar junction transistors shown in the pictures. I am having trouble sourcing this transistor. I pulled a good one off of the board and tested it with my component analyzer but I cannot find anything that matches the specifications. Any help locating this part or a replacement would be greatly appreciated.
              Thanks...
              10-18-2023, 02:05 AM
