Nichicon HE series experience?
  • barmoley
    • Jun 2009
    Does anybody have experience using HE series of Nichicon, specially part number UHE2A331MHD6?
  • shadow
    • Feb 2007
    • 732
    Re: Nichicon HE series experience?
    I have used Nichicon HE series capacitors in one particular recap project. It was the only series of good quality low ESR capacitors that I could get hold of in the appropriate physical dimensions.
    Needless to say that they worked just fine.
    I think that the HE series of capacitors do not have specifications that are as good as the Panasonic FM, FC series capacitors or the Rubycon MBZ series of capacitors. However they are way ahead of garbage capacitors.
    The way to check this is to pick up the data sheet for the Nichicon HE series and compare it to the competition. Usually it is not difficult to source the Panasonic FM and FC series of capacitors.
    The things to look out for when comparing equivalent capacitors include:
    ESR - lower is better
    Ripple - Higher is better
    Nichicon is considered a good brand. However they have had an issue with their HN(M) series of capacitors in the past.
    By the way, what are you trying to fix? Pictures help a lot.
    BTW, welcome to the forums!
    • barmoley
      • Jun 2009
      Thank you for your prompt reply, I'm considering to recommend it to my friend who fixing his motherboard. I will try to clarify with him more details.
      • Bobdee
        • Jun 2008
        • 461
        Sorry I could not help noticing something wrong here,the link here
        http://parts.digikey.com/1/parts/423...2a331mhd6.html
        says this is a general purpose cap not low esr, needs checking out
        • Toasty
          • Jul 2007
          • 4171
          A 100 volt cap on a mobo???? Not likely.
          Not low enough ESR in the HE series for mobo work.
          Shadow is correct regarding Panasonic FC or FM(best).
          Ruby MBZ's & MCZ's are available from this site https://www.badcaps.net/pages.php?vid=22 .
          If you have to use Nichicon, stay with the HZ(best) or HN series.
          Toast
          veritas odium parit
          • yanz
            • Nov 2004
            • 910
            I have used HE series since 2006, no problem so far. perfect for PSU recap and mobo (vrm input). it has a long lifetime and low enough esr. And IMHO, im not agree about FC better than HE, it's the way arround : HE is beter than FC.
            • shadow
              • Feb 2007
              • 732
              Well I am not sure what constitutes as a "Low ESR" capacitor. How low should it be? It seems like Digi-Key groups its capacitors into two groups. General Purpose and Polymer.
              However I used the HE capacitors for a P3 system. P3's don't stress the VRM as much as modern processors as far as I know.
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                Yes, HE is a better grade than FC. [For ESR and Ripple anyway.]
                Mann-Made Global Warming.
                - Dr Seuss
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  There are no "Official' definitions of what 'low' or 'ultra low' or similar expressions mean. That's up to the manufacturer and some of them [mostly from TW and China] aren't especially honest in their data sheet 'advertising'.
                  The way to compare caps grades between series' is to look at ESR and Ripple for the same can size.
                  Since you use Digikey their non-poly grades go like this:
                  giving Ripple/ESRLooking at 8x20mm can size and giving Ripple/ESR:
                  ------ 8x20mm ---------- 10x20mm -----
                  FM -- 1560 / .030 -- -- - 2180 / .019
                  KZE - 1280 / .041 -- -- - 1820 / .023
                  KY -- 1050 / .069 -- -- - 1400 / .046
                  HE -- 1050 / .069 -- -- - 1400 / .046
                  PW -- 995 / .065 -- -- - 1220 / .052
                  FC - - 995 / .065 -- -- - 1220 / .052
                  LXZ -- 810 / .080 -- -- - 1220 / .052
                  You STILL have to look up the specs for the individual caps because for a given uF a 'better grade' series may have a 10x12.5mm can and the 'lesser grade' series has a 10x25mm can.
                  In that case the 'lesser grade' cap may have better specs due to the larger can size.
                  - Dr Seuss
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    KZE are a great choice for all-around on P3 boards and they tend to be less expensive than the others from Digikey.
                    - Dr Seuss
                    • yanz
                      • Nov 2004
                      • 910
                      That's a simply good guidlines, Bonez
                      KZE are goods, but the brown family caps of chemicon are easy to be counterfeited. Fake chemicon caps can easily be found here like brownies cakes. (Oh, but that's my story.. ) But i guess if u buy it from reputable online shop like digikey then there's no worries.
                      • Bobdee
                        • Jun 2008
                        • 461
                        I have used Nichicon HE series capacitors in one particular recap project. It was the only series of good quality low ESR capacitors that I could get hold of in the appropriate physical dimensions.:
                        Hello Shadow
                        Sorry for my error, I was mislead by Digikey been on Nichicon site and HE are described as Extremely Low Impedance,
                        And with other members input there can be no doubt about the above advice being correct.
                        bob
                        • DrewPhillips
                          Capacitor Diarrhea - Nichicon PL Series
                          by DrewPhillips
                          Hello All, I have on the bench a couple of PSU's which have some failed Nichicon PL series caps. They didn't "puke" their guts through the top, but instead "diarrhea'ed" corrosive brown electrolyte through the bottom, down the legs and onto the board. On one cap, the electrolyte rotted the cap right off the board leaving 2 little stubs, and also corroded a trace on the foil side.
                          The PSU's are Power-One MAP series and are ringing-choke topology. The semiconductors have date codes in 1993. The PSU's were used in a commercial application, fan-cooled. They had failed...
                          03-02-2025, 10:18 PM
                        • chth96
                          Is there datasheet for nichicon LXJ series?
                          by chth96
                          I want to calculate capacitor ESR referring to below guide.
                          https://forum.digikey.com/t/calculat...-from-tan/2633
                          I must find out dissipation factor(Tan(δ)) for nichicon lxj series(6.3v 1500uf,25v 1000uf ,10v 2200uf)
                          I finally found out datasheet which has all series of nichicon capacitor.But unfortunately, It removed old nichicon capacitor.
                          Is there anyone who still has old nichicon datasheet which has information of LXJ series?
                          11-20-2022, 08:11 AM
                        • chth96
                          Is there any datasheet for nichicon RT(M) series?
                          by chth96
                          A few days ago,I destroyed one of my japanese retro game console by pluging it to 220v outlet.
                          https://www.badcaps.net/forum/troubl...e-been-blew-up
                          and I finally fixed​ this retro game console by soldering varistor and glass fuse.
                          But I noticed that When I measure voltage of PSU's 5pin connector, it is 8.80-9.07v, 5.13v,3.40-3.48v,GND,GND instead of its rated voltage of 9v 5v 3v GND GND.
                          I have spare console...
                          11-28-2023, 03:36 AM
                          ASUS Pro Series D320MT-TR362D Pro Series i3-6100 Specification for Upgrade or Repair
                          This specification for the ASUS Pro Series D320MT-TR362D can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320MT-TR362D boardview and Pro Series D320MT-TR362D schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                          09-12-2024, 03:28 PM
                          ASUS Pro Series D310MT-0G32500650 Pro Series G3250 Specification for Upgrade or Repair
                          This specification for the ASUS Pro Series D310MT-0G32500650 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D310MT-0G32500650 boardview and Pro Series D310MT-0G32500650 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
