nec 2571 is the optocoupler model
What is a typical diode voltage that saturates an optocoupler?
Re: What is a typical diode voltage that saturates an optocoupler?
The datasheet says the diode voltage typical drop is 1.2V at 10mA. Maximum current is 50mA. As with all diodes, it's current that enables it, depending on the exact optocoupler you get, the saturation voltage for one unit can destroy another.
The transistor saturation voltage is 0.3V at 2mA. -
1) How is this opto being used/connected?
2) How much is the current on the LED side?
3) Read about how to read data sheet, look at CTR: https://cdn.badcaps-static.com/pdfs/...85b94d258d.pdf
http://electronicsbeliever.com/opto-...r-explanation/Attached FilesLast edited by budm; 08-31-2018, 11:11 PM.Never stop learning
0.15mA? That can't be right, the Ice will be low also so the Transistor will not be saturating. What is the Voltage source and how is the LED side is driven?
That is very very low, no wonder the Vf is only 1V. If you look at page 8 the Graph of Forward current VS Forward Voltage you will see what the Vf will be at around 0.15mA, about 1V @25c
What kind of circuit are we dealing with here?Attached FilesLast edited by budm; 08-31-2018, 11:23 PM.Never stop learning
The led is powered by 3.3v stby pulling down to ground via transistor and 470 Ohm resistor (that's how I measured the LED current). But I now checked the 3.3_stby voltage and it drops to ~2v when I try to power on the PSU!
So I think the problem is not in the optocoupler but in the Vstby source.Comment
It will help if you tell us what kind of power supply you are working on and also provide good clear straight shot pictures of the top and bottom side of the board.Never stop learning
by abajorHave an A2141 which is reading about 5.2V 0.07A on all USB jacks, started doing the measurements.
PPBUS_3GH diode: measures good .45V
PPBUS_3GH Voltage: maybe not so good 12.25V maybe bad T2? Unit did not come up in DFU on configurator.
The weird so far is
PP3v3_G3H_RTC_X diode: .104V (WTF?)
PP3v3_G3H_RTC_X voltage: 3.39V (Normal)
Stopped there attempted reverse voltage injection at PP3v3_G3H_RTC_X with 1V. Instead of the circuit sinking any current, My PSU suddenly reads 3.4V with no current draw.
Not sure what any of this means... -
Then today it randomly sprung to life like a zombie but shortly died thereafter. I have no idea why it would have done that and its the first time I've seen it running. I discharged capacitors on the board last night, then it was sitting today.... -
i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
VCCIO voltage ok
VCCSA Voltage OK
VCCPLL Voltage OK
Ram Voltage ok
RamVTT OK
VPP 2.5 OK
But No Core Voltage
and i want to this vrm ic datasheet or pinout (ISL69269)
anyone have this ic pinout voltages?...06-25-2025, 07:19 AM -
by electron_jjHi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
I have been inspecting and testing the capacitors and diodes in the power supply board to try to... -
by sam_sam_samI found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
Now... - Loading...
