LEDs and CRs
  • stevo1210
    • Oct 2006
    • 4156
    LEDs and CRs
    I have a basic electronics questions so here goes.
    Are LEDs (as in the light emitting diodes) cathode rays?
    My friend said that LEDs are cathode rays but I've tried googling it up and haven't found anything on that. I'm not going against what he says, but I would like to know if this fact is true.
    Thanks.
  • Gianni
    • Jul 2008
    • 681
    • Italy
    Re: LEDs and CRs
    Can this article answer to your question?
    Ciao
    Gianni
    "In the confrontation between the stream and the rock, the stream always wins...Not through strength, but through persistence."
    H. J. Brown
    • Wizard
      • Mar 2008
      • 2296
      Re: LEDs and CRs
      LED emit light by electron collisions that emits when electrons falls back from upper orbit levels at the very narrow region. All solid state, no need for vacuum.
      CRT is a vacuum bottle uses stream of electrons emitted from hot heater and repelled by cathode voltage fields and HV fields to slam into phosphors thus glow.
      Plasma relies on this as well except done different ways. Fluorsecents, CRT and other arc lighting is all forms of using electrons in flight to stike another kind of atoms or just electrons alone (pure arc) to make light.
      Cheers, Wizard
      • stevo1210
        • Oct 2006
        • 4156
        Re: LEDs and CRs
        Yup, the article answers my question. And so LEDs are cathodes after all.... unless I misread something.
        • Wizard
          • Mar 2008
          • 2296
          Re: LEDs and CRs
          Yes, LED is another kind of diode but the P N junction is done differently to emit protons (light of specific range of frequency) and done in solid state while other technologies use either vacuum or gas filled tubes in different ways to make light.
          Cheers, Wizard
          • Toasty
            • Jul 2007
            • 4171
            Re: LEDs and CRs
            #1 - What moron on crack decided light blue printing on a white background was the way to build a web page.
            No. They are not cathode rays. As the article says, they are photon emitters. i.e. visible light. They carry no electric charge and can not be bent or directed by a magnetic field or voltage.
            Cathode rays (actually electron beams) are the stream of electrons leaving the cathode (negative electrode) in a low pressure gas environment such as a vacuum tube. They do carry an electric charge and in a CRT are created in a hot electron stream as Wizard explained in #3 above. Because they are electrons, they can then be directed by voltages and magnetic fields. See also particle accelerators.
            Toast
            veritas odium parit
            • Pipolups
              Corsair K70 LUX RGB dying LEDs
              by Pipolups
              Hi there !
              I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
              Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
              10-08-2024, 11:58 AM
            • THE GTC
              Insignia NS-37D20SNA14 intermittent LEDs
              by THE GTC
              So I use this TV daily as a second monitor for my PC or my Playstation - at one point a few months back I tried to fix the problem - but in the process, I figured out something that works so I haven't posted this for awhile. It is an annoying trick to have to do though, so I decided to post about it to see if anyone could spot what's wrong. It baffles me because it works on it's own half the time.
              When I first got this TV, I was told it wouldn't turn on, and of course I did the flashlight test, and the image was there. Also, the red LED on the front indicated that it had power (it...
              11-03-2020, 02:40 AM
            • pni
              Backlight panel diffuser melt by backlight leds broken
              by pni
              Hi guys, I changed my backlight to a 5g in Samsung but the broken leds burned the thick plastic panel . I give the photo. Do you think if I try to rotate the panel, with the botton on the top I have a good image? Becacause now how u can see, on the light color I sse the leds because of the burned on the plastic diffuser....
              10-12-2025, 12:08 AM
            • VitalComputing
              Replacing Mode Indicator LEDs
              by VitalComputing
              I have what should be a simple job but is causing me issues. There are three LEDs (yellow, green and red) on the indicator panel of a solar PWM controller and these have broken off. I need to replace them but I am unsure of the voltage drop across these. I don't want to replace with random LEDs in case they blow.
              I took one of the LEDs out of circuit, put 19V across it with a 500 ohm resistor in series and there is a drop of about 13V across the LED, and this seems to increase as I increase the input voltage.
              I thought I could just put a resistor...
              09-17-2023, 04:43 PM
            • jimbofz
              just a quick question do all qled leds appear blue when fault finding ?
              by jimbofz
              i have replaced many leds strips that have changed blue when they are worn
              and the new replacements are perfect white
              but when fault finding do quantum leds always look blue?
              08-28-2024, 06:51 AM
