SOP28 Detection
+ More Options
Posts
  • mentosmec
    • Jun 2018
    • 64
    • Belgique
    SOP28 Detection
    Hello friends,
    I found (a 28 pin chip) with a program that I want to copy at all costs.
    My man has erased the mark (model)!
    How to purge to know which chip it is?
  • petehall347
    • Jan 2015
    • 4436
    • United Kingdom
    Re: SOP28 Detection
    where did it come from ?
    • mentosmec
      • Jun 2018
      • 64
      • Belgique
      Re: SOP28 Detection
      I do not know it's for a friend
      • mentosmec
        • Jun 2018
        • 64
        • Belgique
        Re: SOP28 Detection
        I just want to know how to copy it
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          Re: SOP28 Detection
          Chances are, without other information, you are SOL even if it wasn't illegal.
          • mentosmec
            • Jun 2018
            • 64
            • Belgique
            Re: SOP28 Detection
            • mentosmec
              • Jun 2018
              • 64
              • Belgique
              Re: SOP28 Detection
              possible or impossible ?
              I can pay if possible
                • 31181
                Re: SOP28 Detection
                trace the circuit, it looks like a microcontroller.
                so if you work out what pins are for power, and crystal, and to the programming pads on the left then maybe you can identify the make & series.
                • mentosmec
                  • Jun 2018
                  • 64
                  • Belgique
                  Re: SOP28 Detection
                  how should I proceed?
                    • 31181
                    Re: SOP28 Detection
                    i just said.
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8701
                      Re: SOP28 Detection
                      If you want to be that secretive not to show
                      - the whole device
                      - large, clear pictures of the chip with all the interconnect
                      plus don't know any electronics... there's not much we can do. And even if we can figure out the chip (yes, it's a microcontroller, nobody would scratch out the ID of a memory chip), there's copy protection on these chips.
                      • mentosmec
                        • Jun 2018
                        • 64
                        • Belgique
                        Re: SOP28 Detection
                        2010-2017 Quick Tool-P2 manufacturer (kadentech)
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8701
                          Re: SOP28 Detection
                          Which pins are each of the P2 connector connected to, hard to tell with the wires underneath the chip, need access to actual device to proceed unless you have an ohmmeter or something to check connections.
                          But I fear you will run into the copy protection on the chip, which is somewhat difficult to defeat. You're better off doing a cleanroom reverse engineer, which will need a logic analyzer and recreate the program...
                          • mentosmec
                            • Jun 2018
                            • 64
                            • Belgique
                            Re: SOP28 Detection
                              • 31181
                              Re: SOP28 Detection
                              so it's a card reader??, that will have security enabled.
                              • eccerr0r
                                Solder Sloth
                                • Nov 2012
                                • 8701
                                Re: SOP28 Detection
                                Apparently it's likely a JTAG shifter that shifts into an appl€ product to unlock EFI passwords. So the guy who made it is likely just as savvy as apple to make sure it doesn't get copied.
                                • petehall347
                                  • Jan 2015
                                  • 4436
                                  • United Kingdom
                                  Re: SOP28 Detection
                                  it will also change log in to apple . just the thing for stolen units to be able to be used .
                                  • mentosmec
                                    • Jun 2018
                                    • 64
                                    • Belgique
                                    Re: SOP28 Detection
                                    I would like an address for logic analyzer
                                    • mentosmec
                                      • Jun 2018
                                      • 64
                                      • Belgique
                                      Re: SOP28 Detection
                                      the brand tells you nothing?
                                        Copy DMI info easily with Hex editing software and Macro script
                                        by SMDFlea
                                        Copying DMI information from an old bios to a new one is difficult for some members, often they have no experience with a hex editor,or some that have tried find it too hard.There is an option to make things easier for those members so that they don`t need to post their own bios backup for the DMI copying.
                                        Experienced bios modding members can help by posting in other threads the DMI offsets,macro script generated by the software and a download link to the software at softpedia mentioned in this guide,or post your macros in the comments here with a link to the bios request thread ....
                                        02-28-2023, 02:14 PM
                                      • Caimano
                                        Need to copy DMI info for HP ProBook 650 G2 Bios
                                        by Caimano
                                        UPDATE of JANUARY 5th : I am cancelling this post because problem has been solved by creating a new bios starting from the old one with correct dmi and cleaning ME. everything works fine . thanks anyway
                                        Hi, I am replacing a motherboard circus-6050A2723701-MB-A02 to an HP 650 G2 laptop because the original one was faulty. I bought and repaired a used MB which works fine now with its BIOS, but I wanted to copy the DMI data from the old to the new MB. I created with Flash Image Tool a new bios starting from the old original chip , cleaned ME region and new updated dump region extracted...
                                        01-03-2024, 05:19 AM
                                      • m0seba
                                        how to block copy from network access
                                        by m0seba
                                        hi
                                        there is a small company have 4 computers and server with windows server 2016
                                        all computers are entered into the server by local users, and there is shared folders on server with limited access to every computer
                                        my question is there any method to disable copping form all shared folders on this server, but jest disable copy form server not paste on it.
                                        my client want his team copy from their computers and paste on any shared folders on server, on the other way can not copy anything from shared folders to their computer.
                                        or any way to disable copy on windows...
                                        03-16-2021, 03:35 PM
                                      • fredyjbi
                                        please help friends thinkpad T470 error post "bottom cover tamper detection error"
                                        by fredyjbi
                                        please help friends thinkpad T470 board CT470 series NM-A931 error post "bottom cover tamper detection error"
                                        I've already
                                        flashed the bios clean me and updated from the Lenovo site, then removed the switch and immediately jumped the S3 from pins 1 to 4, 2 to 3 but the problem remained the same, thank you
                                        06-15-2024, 09:56 AM
                                      • Danghaibang
                                        Acer AN515-57, Recovering Thunderbolt Controller After Erasing Firmware on UT3 SPI ROM of Intel® JHL8040R Retimer
                                        by Danghaibang
                                        About a year ago, I accidentally erased the firmware on the SPI ROM of a Thunderbolt retimer in my computer, mistaking it for the main BIOS chip. Since then, the Thunderbolt controller no longer appears in Device Manager, and I'm unable to use Thunderbolt functionality.
                                        For context, my system has two retimers: UT5 and UT3. The one I erased is the UT3, which uses a W25Q80DVSSIG chip. In an attempt to fix this, I used a CH341A programmer to copy the ROM data from the UT5 retimer to the UT3, hoping it would restore functionality. Unfortunately, this didn't...
                                        03-22-2025, 08:56 PM
