LED Backlight current question
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    *long story! Skip to second part for actual question*
    Good day folks. I was messing around with a couple of TVs that got left behind in the shop, essentially being knackered in one way or another and I found two which are almost identical and each have a different issue: one has a dead power supply and the other a dead main board, so I thought I'd combine the two to make at least one of them functional, which got me thinking about one thing which I'll discuss later on. The main boards aren't quite direct replacements, not matching physically for one and secondly the panels are different sizes: one is a 24, the other a 22 incher. The PSUs however are virtually identical outside maybe their brand and the position of the components, so it was easier to adapt the PSU, instead of the main board and messing with firmwares and trying to matche the panels and just....naaah.
    The only difference is that one panel had only two wires for the backlight (+ and -) and the other one had 6 (2 +, 2- and two dummies which we don't care about). Unfortunately the functional PSU belonged to the 2 wire panel. I pushed on with this adaptation because I noticed despite it having more wires, they were nothing more than simply paralleled, so all - were bunched together and all + were bunched together, so I maintained that arrangement and soldered the red bunch to LED+ and the black bunch to LED-...while the TV fired up with the replacement PSU, the backlight didn't - not even a spark or something...it just sat there. I then tried multiple combinations of those wires, removing one set and leaving just the other alternatively, but still nothing. I managed to get it going however: guess what the big secret was....the polarity was reversed, in other words RED was negative and BLACK was positive all along....I would've never figured it out had I not pulled the datasheet for the panel which thankfully is an LG and has a comprehensive one. So I soldered black to + and red to - as counterintuitive as it was, but only had one wire pair connected (the other was floating - we're talking about the 22 incher which has 2 pairs of wires). This time the backlight did flash on for a second upon applying power and 3v to the BL-ON pin and once I connected the second pair as well, the backlight remained on properly.
    This got me thinking however, despite it not being fully related to what I did there today: assuming the LED driver is a constant current source designed for a specific type of panel with a specific current draw, assuming I try adapting a CC source for a smaller panel with a smaller current draw, what would I need to change ? I initially thought I'd HAVE to perform such a hack to enable the smaller panel to be run by the driver of the bigger panel (having less LEDs and thus smaller draw), but it turned out it wasn't necessary after all. Assuming it was, what would it come down to ? The current sense resistors ? When talking about CS resistors on general, would an increase in the value result in a higher load, tricking the PSU into running the smaller load, or is a DECREASE in value necessary for this purpose ? I messed around with Ohm's law and I THINK an increase in resistance results in the PSU detecting a higher voltage drop across the resistor, hence a higher load. If the PSU is expecting a value of X volts dropped on that current sense resistor, a LOWER value than expected would be like a lower or missing load, like in the case of a disconnected or open LED strip (which is why my PSU shut down back there when I only had one string of LEDs connected - when I connected the other one, the PSU stayed on). Assuming I HAD no second strip and wanted to run just the first one, how would I achieve this ?
    Think of it like this: a 1A load across a 1ohm sense resistor would result in a 1v drop, whereas if I had the same 1A load but through a 2ohm resistor, this would result in a 2v drop....V=IxR ? Assuming it's 2v the comparator expects, it stays on. With the smaller value, the drop is lower and the comparator detects an "open lamp" fault....is this close to being a correct assumption ? Cheers and thanks.
    Wattevah...
    Re: LED Backlight current question
    Can we at least see the pictures of Top and bottom side of BOTH power supply boards?
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      Umm....yeah I could snap some pics tomorrow, but the discussion's meant to be generic about CS resistors and how they operate, so pics aren't really relevant....I mean I know how they operate, but in the case of LED backlight drivers, how does changing its value affect the operation - that's the summary of that wall of text
      Wattevah...
        You increase the value of the current sensing resistor to decrease the constant current level through the LEDs, there are thread at Bc about modding the current. Some LED driver IC also has current setting pin.
        I like to see the pictures to see if it really driving LED string in parallel or not.
        The + for the Anode of the LED strings are usually tied together and fed by single Boosted Voltage, it is the Cathode side is the one that is being done on the sink side for constant current control.
        • Dannyx
          CertifiedAxhole
          • Aug 2016
          • 3912
          Yes it is, because there are only two output points on the PSU, one + and one -, though I shall upload some pics nonetheless.
          So I was right in my assumption even after that long-winded story
          Wattevah...
            "The only difference is that one panel had only two wires for the backlight (+ and -) and the other one had 6 (2 +, 2- and two dummies which we don't care about)" so the one with 4 wires has the traces for the two (-) tied together?
            • Dannyx
              CertifiedAxhole
              • Aug 2016
              • 3912
              Correct. Two blacks tied together (which are actually + but NVM), and 4 reds tied together (out of which 2 are "active" and 2 are dummies according to the datasheet for that panel which lists them as NC).
              Wattevah...
              • quickname
                Cyberpower 1500AVR UPS repair
                by quickname
                I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
                I decided to verify that the batteries were...
                11-12-2023, 09:57 AM
                Texas Instruments bq24745 bq24745RHDR bq24745RHDT Battery Charger IC for Laptop Computers Datasheet
                The bq24745 bq24745RHDR bq24745RHDT is a high-efficiency, synchronous battery charger with an integrated input-current comparator, offering low component count for space-constrained, multi-chemistry battery-charging applications. The input-current, charge-current, and charge-voltage DACs allow very high regulation accuracies that can be easily programmed by the system power-management microcontroller using the SMBus interface. The bq24745 charges two, three, or four series Li+ cells, and is available in a 28-pin, 5-mm x 5 mm QFN package.
                The bq24745 features dynamic power management...
                10-23-2024, 02:50 AM
                Is there any high current pouch battery that are size 60mmX80mm maximum thickness 21mm for a battery operated tab welder
                I have a battery operated tab welder and the battery does not have enough current for the battery tab welder because after about 30 welded it does not have the same current output it voltage has gone down by at least 0.500 volts or maybe a more than that
                I can fit 21700 battery cells in the enclosure it is very tight fit for four of them that are 35 amp high current capacity 35X4=140 high current output this should work a lot better than what is installed right now
                I tested the battery cells there are installed right now and they are testing good with no issues that I...
                02-04-2025, 08:08 PM
              • AJ847.63e
                Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
                by AJ847.63e
                Hi Folks,
                Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
                I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
                The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
                05-06-2025, 10:37 PM
                ISL95836 Laptop PWM Controller Datasheet
                The ISL95836 Pulse Width Modulation (PWM) controller IC
                provides a complete solution for IMVP-7/VR12 compliant
                microprocessor and graphic processor core power supplies. It
                provides the control and protection for two Voltage Regulators
                (VRs). The first VR, typical for Vcore, incorporates 2 integrated
                drivers and can operate in 3-, 2- or 1-phase configurations. The
                second VR, typical for graphics, incorporates 1 integrated
                driver and can operate in 2- or 1-phase configurations. The two
                VRs share...
                11-05-2024, 03:31 PM
