metrix scope
  • colinaskin
    • May 2018
    metrix scope
    Hi does anyone have a circuit for a metrix ox863b scope please. I have lost the screen display although all other buttons work. I think the eht has gone down, the eht output transistor was faulty (TIP31c) replaced it but still no eht.
    would be greatful if i could get a circuit of the eht circuit.
    Thanks.
    Colin
  • badmanj0k3r
    DSA Tech
    • Jul 2016
    • uk
    Re: metrix scope
    https://www.badcaps.net/forum/showthread.php?t=42768
    does the above help!
    • Astonished
      Fixing the Charge Circuit of the Batteries of the DC Motor
      by Astonished
      Hi friends of electronics
      What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
      The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
      Please help me fix this circuit.
      (the datasheet of the IC: https://pdf.datasheet.live/28...
      01-28-2025, 06:24 AM
    • Tarot Superstars
      Short Circuit tester
      by Tarot Superstars
      Hello.
      I have seen a short circuit tester made with 3 * 9V batteries, a voltage limiter component and a resistor connected to the probes of a multimeter.
      The theory is that the meter becomes sensitive enough to read very low resistances and the lowest resistance to ground on a circuit is likely to be a short circuit in that area.
      Link
      The Amazing $1 Short Finder Upgraded! Convert ... - YouTube
      https://www.youtube.com/watch?v=0eixDdCpiO4
      My multimeter isn't normally sensitive to very small resistance, but when I put a 1 mega ohm resistor...
      09-25-2023, 09:11 AM
    • Alimash
      op amp circuit function?
      by Alimash
      I am repairing a ups which doesn't turn on ,it has the following ICs:
      SG3525 used to drive inverter mosfets.
      couple of uc3483, one for the power supply and another to drive a big mosfet at the output stage(i think the technique is called boost)
      A LM358 and TL074 for control mechanism and of course the uController.
      The SG3525 is shutting down every time the ups is turned on.
      I want your help to know the function of LM358 and TL074 in the system.
      I reverse engineered the LM358 circuit and i think that one of the block(A) is used for battery level...
      07-31-2025, 07:45 AM
    • repair-it
      Need advice testing a samsung power supply board with scope
      by repair-it
      I am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
      07-12-2025, 11:00 AM
    • M1NEBLANK SHOW
      MSI B250 Gaming M3 Short circuit in CPU power supply circuit
      by M1NEBLANK SHOW
      Hello. MSI B250 Gaming M3 board, short-circuit on the power supply. Found a problematic mosfet VQ1
      (N-PK616BA_PDFN8-HF) soldered it out - short circuit is gone. I replaced VQ1 + VQ5 (N-PK632BA_PDFN8-HF). VQ1 was replaced with PK618. After starting attempt VQ1 is lit again. What can be the problem? In the driver?
      Schematic and Boardview here
      04-04-2025, 03:57 PM
