Buying custom crystals...
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8706
    Re: Buying custom crystals...
    I don't take samples for one offs, seems like theft. However if I were thinking about mass producing,then I'd view samples as advertising...
    Then again, maybe they should be advertising their product to me for a future design...
    • Agent24
      I see dead caps
      • Oct 2007
      • 5085
      • New Zealand
      #42
      That's what samples are for! It's a free test. Even if you intend on mass production there's no guarantee you're going to use the same chips you prototype with. The design can always change.
      And, if you successfully use their sample to mod your radio, that IS advertising - other people may want to do the same, and they may sell more chips as a result...
      -David VanHorn
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8706
        I think I got a green light on the prototype side... I think I can get this HF circuit working on a solderless breadboard after someone getting an FM transmitter (VHF) working on a a solderless breadboard
        Unfortunately I'm still out locating and extracting a varactor or few.
        Also after finally figuring out the dividers, kind of bummed that either I have to build a 17-bit programmable counter to get 5KHz stepping, or I could use a 16 bit for 10KHz steps for the receiver. Needless to say, 17-bit counters will be very expensive and 16-bit counters are "free."
        So I plan on making the transmitter with the 5KHz step and receive 145.115- on my scanner as proof of concept that my contraption works (and hope someone's still using the NCARC 2m repeater)
        • goontron
          5000!
          • Dec 2011
          • 4108
          • US
          #44
          ^Ive said before i have some boards that may have varactor caps on them. Let me check, its boards from an old 2M radio where the final (a discrete package) got blown out by a nearby lightning strike, but the rest was OK.
          Follow the white rabbit.
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8706
            You should fix it and make a new discrete transistor final for that radio...
            Anyway it doesn't matter that the parts comes from a 2m radio, I have to redesign it anyway because the LO is actually more like HF or low VHF.
            • goontron
              5000!
              • Dec 2011
              • 4108
              • US
              #46
              Ive looked into that. Then decided that since it didn't have CTCSS and all my attempts to add it, be it from an actual function generator or a hack job using a TRS cord and a computer to try a higher level (hotter) output, have failed. So i scrapped it.
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8706
                Ouch... hope I don't run into that issue... That will be next...
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8706
                  BTW how did you try to hook up the tone generator? Mixed with the microphone input or after the microphone BPF? If you hooked it up at the microphone you'd need a pretty hot signal to blow over the BPF (if there is one of course --- what radio was this?)
                  Gosh I hope this isn't going to be that hard to get it to work..scared now. I thought the PLL was going to be a daunting challenge, if CTCSS is going to also be equally as tough... shiver in 90°F weather....
                  • goontron
                    5000!
                    • Dec 2011
                    • 4108
                    • US
                    #49
                    ^ Its a TR9000. Before the mic preamp/bandpass it would get filtered out. I tried after the BPF and using the tonepad input. They both work, but they either cause distortion or don't open up the (very old) repeater...
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8706
                      Hmm... would need to know how that input is fed into the modulator to know more, perhaps the DTMF input overblows the voice input and really need a more balanced mixer.
                      How did you control enabling the tone - enabled the oscillator when keyed up? I suppose if you kept it running continually, it should work minus the distortion problem.
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8706
                        GRRRRR... I hate SMT.
                        I bought an old, junk VCR in hopes that I could swipe the varactor from it... It was an 1986 model...
                        ... and it had SMD
                        Ugh... plus the proprietary parts make it tough to figure out where the varactor is. Sigh. Might have to go buy from fleabay after all
                        • Agent24
                          I see dead caps
                          • Oct 2007
                          • 5085
                          • New Zealand
                          #52
                          Sorry to say it but you'll have to get used to SMD sooner or later... with the right tools its not all bad though. I used to hate SMD parts too. Now they only mildly annoy me.
                          I actually like them more sometimes for DIY and prototypes. No holes need to be drilled in a custom PCB. But it depends on the part. Most chip resistors, ceramics, diodes, etc are easy and fun. SMD electrolytics are silly though. Ultra fine-pitch ICs aren't necessarily joyous either.
                          But hey. It's where we're headed...especially in repair.
                          -David VanHorn
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8706
                            Well, it's not that... actually finding which device is the varactor is the problem when they're not labeled properly, no schematic, and custom parts
                            But yes, I hate drilling PCBs too.
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8706
                              Ugh...speaking of tariffs, I wonder what to do if I do end up needing to china import varactors.
                              Looks like I should have targeted AM radios, alas, AM radios with varactors somewhat uncommon to be garbage unlike VCRs... AM radios without varactors are frequently garbage, however.
                              • eccerr0r
                                Solder Sloth
                                • Nov 2012
                                • 8706
                                I SEE YOU, LITTLE BUGGER!!! STOP HIDING! (though I don't know about all the SMD on the other side of the board...)
                                Anyway, thank you silkscreen!
                                Unfortunately it still is an unmarked. Hopefully I can get its capacitance and it falls into the range I need...
                                • eccerr0r
                                  Solder Sloth
                                  • Nov 2012
                                  • 8706
                                  OOhhh..this is annoying. I found another one, hooked them up inverse parallel, and was able to get a voltage adjustable capacitor according to my Sencore! Was getting 15pF to 30pF or so. It's a start!
                                  However, building this into a Colpitts isn't working Can't seem to get it to oscillate Perhaps the ESR of the varactors are too high to oscillate with the coil I was playing with... I suppose I also need to carefully take into account the extra picofarads that are lying around in the solderless breadboard as it introduces random capacitance every which where, which may break the circuit.
                                  Should do a bit more due diligence on calculating expected frequency, currently tossing random devices to see what it would do...if it would do anything at all. I might still need to buy off the shell varactors anyway, this 30pF is a bit small. I don't think I need all the way to 300-400pF but perhaps having it that high is helpful.
                                  Sometimes amazing thinking about the difference between a 1000uF SMPS output cap and a 40pF varactor... Many orders of magnitude here!
                                  • goontron
                                    5000!
                                    • Dec 2011
                                    • 4108
                                    • US
                                    #57
                                    RF anything....solderless breadboard
                                    • eccerr0r
                                      Solder Sloth
                                      • Nov 2012
                                      • 8706
                                      http://sci-toys.com/scitoys/scitoys/...readboard.html
                                      https://www.youtube.com/watch?v=fwOvI_cqZoQ
                                      http://www.qsl.net/jh5esm/homebrew/7tr1015bb.html
                                      It's all about managing parasitics.
                                      Oh BTW, first rev of this circuit shall be ~7MHz only, I've done 10MHz stuff just fine, so it should be okay... well except an extra 2pF capacitance on 30pF is a huge 7% - will need to more carefully place.
                                      Might actually be a wiring problem though.
                                      • eccerr0r
                                        Solder Sloth
                                        • Nov 2012
                                        • 8706
                                        YES... well sorta YES! I hit checkpoint 3!
                                        Checkpoint 1 was: basic design, digital and analog section top level planning.
                                        Checkpoint 2 was: Varactor diode validation - verified I can adjust capacitance with voltage.
                                        Checkpoint 3: ~6.25MHz oscillation sustained on a solderless breadboard that's variable by voltage!
                                        Well, I didn't completely pass the checkpoint but close. Problems I see is that the adjustment range is not what I want, I have some bad noise on the waveform despite being on batteries, and the waveform is jittery at certain voltage points (VERY BAD).
                                        My calculated oscillation frequency is not quite the measured frequency, though it's expected on a breadboard; and I have too much inductance in places which is probably the source of strange artifacts on the waveform.
                                        I'm using my 20MHz 'scope (calculated frequency from interpolating the calibration marks). Eventually I should view this on the 300MHz Teks, but this should be sufficient for now.
                                        Note my target frequency needs to be a somewhat higher than 8MHz (because 8MHz * 18 is 144MHz: low end of the 2m amateur band) so I still need need to tweak this.
                                        Progress brings hope, hope is needed for success!
                                        • eccerr0r
                                          Solder Sloth
                                          • Nov 2012
                                          • 8706
                                          FAIL! Well, expected fail. Haha!
                                          Well, the whole loop is now complete and assembled on the solderless breadboard. It's time for debug
                                          I guess I got lucky on one thing: I got my LCD routines working first try YAY! Well I had swiped my known working routine from another project, but I needed to reroute one pin due to needing the resource on the microcontroller... Anyway, fast 4-bit LCD updates is working with a random HD44780 LCD I grabbed. Luckily this particular LCD actually works, I have never seen it working until now. Also shows gcc-7.3 is capable of generating working AVR binaries, and I was able to get it to shrink the code down so I have plenty of space left.
                                          Now problem is, my phase comparator hit one of the rails...heh. I will need to tune my inductor and caps to see if it's even possible for it to get into range (no clue what the inductance is after I discovered a second slug -- and rotated it out to speed things up...
                                          ... or if I'm using the CD4046's phase comparator properly, could have been dumb and it's currently pumping up when it's supposed to pump down. Shame shame didn't read the datasheet clearly (was assuming its onchip VCO behaved the same way as my VCO, though usually higher voltage denotes higher frequency.)
                                          Anyway, full steam ahead!
                                          • Teban1306
                                            [REQUEST] ThinkPad T14 Gen 1 (20S1) - Custom Boot Logo Modification
                                            by Teban1306
                                            Hello everyone!
                                            I hope this is the right section for this request. I'm looking for help to modify the boot logo on my ThinkPad T14 Gen 1.
                                            System Information:
                                            • Model: Lenovo ThinkPad T14 Gen 1
                                            • Machine Type: 20S1S4E600 (Intel i7 variant)
                                            • Current BIOS: N2XET42W (1.33) - Latest version
                                            • BIOS File: n2xuj25w.exe (12.98 MB) - Downloaded from Lenovo support
                                            What I'm trying to achieve:
                                            Replace the default "LENOVO" boot logo with a custom image during POST.
                                            🔧 What I've tried:
                                            09-14-2025, 11:49 AM
                                          • pc_okay
                                            Crystal compatibility 32khz ASUS UX325 NB255_PCB_MB_V4
                                            by pc_okay
                                            Hello friends,
                                            Its been a while, i wish you an happy new year 2025 !
                                            I have this laptop doesn't start, power light up a second when pluging USB-C charger.
                                            Laptop take 0.11A.
                                            All signals and voltages before SLP_S4# are OK but no SLP_S4# , S3...
                                            I get no oscilation on XTAL 32.768 KHZ
                                            Battery is not charging but charging led is here.
                                            PCH heat at 30° approximatively. (with no heatsink)
                                            I think this crystal might be dead, i have only boardview giving me this: XTAL 32.768KHZ 12.5PF/20PPM.
                                            It's a 2 pins Crystal.
                                            01-13-2025, 09:26 AM
                                          • OakleyDAR
                                            Zotac GTX 1050 Ti Mini ZT-P10510A-10L Replacement Crystal
                                            by OakleyDAR
                                            HI,
                                            I'm looking to replace the 27MHz crystal on this board as it isn't generating the signal. I thought it would be easy to identify a suitable replacement as there are clear markings on the crystal, but it appears I was wrong as Google gives nothing. Bad photo attached, but it has X27.0000 and 16AP1 on the casing. It appears to be a 3225 package, but looking through suppliers there are lots of different things like capacitance, tolerance, active or passive, etc. that need to be considered. Could anyone help identify a suitable replacement please?
                                            Thanks....
                                            04-21-2024, 03:07 PM
                                          • Keshenatech1
                                            Question on microprocessor crystal oscillator circuit
                                            by Keshenatech1
                                            I'm troubleshooting a reel controller board for an IGT slot machine. The digital section seems to be dead. There is no USB communication, PC or utility program for flashing firmware do not see it but they do see good/working boards. I noticed the waveform on the crystal is very erratic/asymmetrical/glitchy on the bad one compared to the nice even waveform on a good board. My question is would this most likely be caused by a bad crystal or something gone bad in the circuit loading it down? I'm attaching a couple pictures of my scope probing the good and bad boads.
                                            02-26-2024, 11:05 AM
                                          • GuiTi
                                            Need Custom BIOS (UEFI/Dualboot) for Lenovo Chromebook 100e Gen 3
                                            by GuiTi
                                            Hey everyone!
                                            I need help with my Lenovo Chromebook 100e Gen 3.
                                            Here are the details:
                                            • Motherboard: LA-L131P
                                            • MFG Date: 2022/01/07
                                            • MTM: 82J80001BR
                                            • MO: MPNXB2103001
                                            • Factory ID: LI123
                                            I bought a new Winbond 25Q128FVSG chip.
                                            The chip currently on the board is the same model but with different ending letters.
                                            I can’t use the CH341 clip on the chip that’s on the board because it’s too low-profile and doesn’t make proper contact.
                                            The Chromebook is Google account locked, and I’ve already tried everything.
                                            I understand that I need to replace or...
                                            10-14-2025, 08:41 AM
