Buying custom crystals...
  • Sparkey55
    • Jan 2010
    • 1523
    Re: Buying custom crystals...
    Crystal swap meets. Ham, SWL, Scanner freaks, etc. Ask around, look online.
    • Sparkey55
      • Jan 2010
      • 1523
      It would be awesome if I could tune the receiver all the way from 88MHz to 162MHz so I could at least hear FM Broadcast and NOAA weather as well...
      Scanners that cover those freqs are a dime-a-dozen. Why bother?
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8706
        Because it's a no cost addition if it works with my homemade PLL!
        Extra bonus for the homemade PLL!
        • Sparkey55
          • Jan 2010
          • 1523
          Knock yourself out then.
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8706
            Well, why wouldn't one want to add this feature in? I guess it's not absolutely "no cost" because it would force the PLL to run in the fringe (the VCO would need to have a larger frequency spread) but if all that was needed was to change the multiplier to "overclock" or "underclock" the superheterodyne... get it?
            • Agent24
              I see dead caps
              • Oct 2007
              • 5085
              • New Zealand
              #26
              I'm not entirely sure what it is you are trying to do, but my general experience has been that if you are trying to design something which requires a very specific and impossible part, then you might just be overlooking a much simpler way to do the same thing.
              But, as I said, I don't really know what you're doing, so I could well be completely wrong...
              -David VanHorn
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8706
                Well, the simpler way is to buy a Baofeng (or rip up the radio...)
                To be clear:
                Goal: Make my Regency HR-2B able to receive and transmit on all amateur frequencies without needing to get all crystal combinations
                Constraint: Keep HR-2B as original as possible (i.e. do not desolder anything if at all possible, only connect to serviceable points.)
                Stretch goal: Make the Regency HR-2B into a scanner as well.
                As in Sparkey55's point on that webpage selling $15/ea crystals, the constraint is part of the radio itself: it uses triplers, which makes life difficult for getting specific crystals or PLLs to work. The idea is to compensate for them and still be able to come up with the correct frequencies needed to transmit/receive. The receive side uses one tripler, the transmitter uses two stages.
                If it had been using all doublers, this would make the PLL implementation _MUCH_ easier.
                Ideally I don't resort to DDS, though another solution is a 1Hz resolution DDS without jitter (asking for 277.7777Hz resolution is probably asking for something weird, 1Hz would at least cover all needed frequencies within 0.7Hz). I really don't want to get an off the shelf DDS that costs more than a BaoFeng, that's another problem. Come to think of it, how would one create merely a square wave digitally controllable oscillator with 1Hz resolution that can scale from 48.000MHz to 49.333MHz with 20PPM accuracy?
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8706
                  EUREKA!
                  I just figured out my solution...
                  I just realized if I had a 10KHz signal (which is easily gotten from a 4MHz clock) and I simply divide this by a non-power of 2 or 10: 9... THERE'S MY 1111.1111Hz refclock!!! Why didn't I think of this before!!! Now I can get rid of this crazy 277.7777 divider and get rid of a bit of jitter that would cause!
                  Granted, now I need to do some wacky math in the microcontroller... floating point even...
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8706
                    Oh no... the eureka moment dies... then again my original solution was flawed.
                    My original solution ended up actually requiring a 1Hz refclock - while possible, this would really make lock time take forever! so I have to throw that idea out the window
                    So I have to use the new 1111.1111 Hz refclock... but this makes things run too fast, the 5KHz channel step separation goal dies, have to go to 10KHz.
                    Back to the drawing board.
                    • goontron
                      5000!
                      • Dec 2011
                      • 4108
                      • US
                      #30
                      ^ Why are you so opposed to cracking it open and gutting the oscillator section may i ask? One thing you will learn over the years once you are licensed is that second hand radios are going to have modifications done to them 99% of the time.
                      Follow the white rabbit.
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8706
                        Tread lightly, leave things as much as they were - ability to revert back for nostalgic purposes or if the project turns to a dead end.
                        Hacking on a CTCSS board is quite a bit different than pulling out the analog multipliers... and FRS is already in the 70cm band - only requires tuning/PLL multiplier changes. Heck that's what I sort of did with the Kenwood, had to tune out of the high 70cm range and down into the ham bands, though the next step is that I have to figure out how the controller communicates to the PLL and force the PLL to run in the ham bands because the current microcontroller blocks transmitting there -- I'll need to hack up a new microcontroller for it. Odd that receiving seems to work fine out of its designed band though that needed its own reverse engineering effort.
                        Come to think of it, I may need the new microcontroller anyway, as I was planning to also add microcontroller support to replace the DIP switches on the CTCSS board of the Kenwood. That is also a problem for this radio - it has no way of storing the CTCSS codes for a particular programming, nor does it have a way of saving different tones for transmit and receive. As it's only a 10W radio, I'm not sure when I'll start this - would like to see 2m working first since I know my 35W icom will at least try to transmit in the 70cm ham bands, it appears. Besides, building a PLL from scratch seems more interesting than microcontroller work, I've already hacked up multiple microcontroller projects in the past, not much new...
                        Besides, at 50-60MHz it's already starting to get into problematic logic speeds for the PLL, so the analog multipliers "help" to an extent. Trying to get a digital circuit with off the shelf through hole parts to run at 144MHz is a problem in itself if I want to directly synthesize the LO, not to mention the digital logic is now emanating RF in the 2m band...
                        • goontron
                          5000!
                          • Dec 2011
                          • 4108
                          • US
                          #32
                          ^Are you sure its the micro and not a discrete bandpass filter on that kenwood? They are known for that.
                          Many radios use RF sources in the carrier frequency range, its all about shielding, but that's more complexity, so i think i see why you want to make a PLL and use the multipliers for that reason.
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8706
                            Yes it's the microcontroller, at least it seems to be from these observations: I programmed a bunch of frequencies to try transmitting into the dummy load. The frequencies that seem to "work" I see a large increase in power consumption. The frequencies it does not like, the power does not increase while transmitting into the dummy load as if it didn't even bother transmitting. It's not even a gradual drop, it just stayed at nominal power consumption of the receiver plus a few milliamps for the antenna relay.
                            And right, shielding is a solution, but shielding does not help trying to force logic devices that take 25ns to propagate through and trying to feed a 144MHz signal into it. The signal will change before it finished getting through the chip!
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8706
                              Hmm... perhaps I should see what the PLLs in the kenwood are actually trying to do when I try to transmit... but it seems really discouraging when it doesn't draw power when trying to transmit. Perhaps there is a BPF somewhere, but where...
                              The receive circuitry, however, yes it has a BPF that I hacked to get it to work...
                              • eccerr0r
                                Solder Sloth
                                • Nov 2012
                                • 8706
                                Well, learned something from the Kenwood which I will need to apply to the homemade PLL. Varactor tuning is going to be a beach. I'll be lucky if I can go from 144 to 164MHz, going down to 88MHz will likely not be possible unless I add more varactors in parallel, perhaps, and hope they don't disable the high end frequencies(!)
                                Still don't have a viable solution for the PLL however, as right now it looks like the Atmel's timer counter isn't sufficiently fast enough to be the primary/only divider. The only thing that will work now:
                                * I will need 10KHz/9 reference clock
                                * My goal of 5KHz channel step is gone. 10KHz is best I can do now.
                                * Need a Low (for transmitter) and High (for receiver) range control.
                                - High range for the receiver will enable a divide by 3 which will allow an AVR to be able to count.
                                - Low range for the transmitter is still broken with no solution. Currently stuck with either a 20KHz channel separation (no bueno!) or perhaps go to a 555.55555555 Hz reference clock, which will then allow 10KHz transmit channel separation. On the bright side, with 555.5555555 Hz it will allow a 5KHz receive channel separation. It will also slow down lock time to probably a half second or so (just a guess) which will make scanning very slow Plus pressing PTT one will need to wait a second for lock, then transmitting would be possible.
                                The other possibility is I use two different reference clocks, one for receive and one for transmit ... Doesn't help channel separation any, but will speed up scanning.
                                • redwire
                                  • Dec 2010
                                  • 3912
                                  Si5351 looks interesting. I2C-Programmable Any-Frequency CMOS Clock Generator + VCXO.
                                  https://hackaday.com/tag/digitally-c...led-oscillator
                                  • eccerr0r
                                    Solder Sloth
                                    • Nov 2012
                                    • 8706
                                    Thanks, yeah I was thinking about how I could use a clock chip from a motherboard though stepping by 1KHz is not enough, I need to step by ... oh these numbers are coming up again and again...
                                    277.7777777 Hz (for 5KHz step on transmit, or 2.5KHz step on receive). If I don't get these fractional Hz accurate, I'll end up with erroneous carrier center frequencies due to the multipliers. However if the step is small enough, I'm not sure what happens if you transmit or received with say 147052066 Hz for 147.052MHz because that's what the multipliers ended up with. Would that be okay?
                                    • Andyy
                                      • Aug 2016
                                      • 28
                                      You need this
                                      http://g4oep.atspace.com/channels/channels.htm
                                      • eccerr0r
                                        Solder Sloth
                                        • Nov 2012
                                        • 8706
                                        That lone Si570 chip is what I need.
                                        Alas getting that ONE chip is around $18 a pop (in quantities of 1)... ugh. Not pleasant.
                                        • Andyy
                                          • Aug 2016
                                          • 28
                                          Have you tried getting a free sample from silabs?
                                          • Teban1306
                                            [REQUEST] ThinkPad T14 Gen 1 (20S1) - Custom Boot Logo Modification
                                            by Teban1306
                                            Hello everyone!
                                            I hope this is the right section for this request. I'm looking for help to modify the boot logo on my ThinkPad T14 Gen 1.
                                            System Information:
                                            • Model: Lenovo ThinkPad T14 Gen 1
                                            • Machine Type: 20S1S4E600 (Intel i7 variant)
                                            • Current BIOS: N2XET42W (1.33) - Latest version
                                            • BIOS File: n2xuj25w.exe (12.98 MB) - Downloaded from Lenovo support
                                            What I'm trying to achieve:
                                            Replace the default "LENOVO" boot logo with a custom image during POST.
                                            🔧 What I've tried:
                                            09-14-2025, 11:49 AM
                                          • pc_okay
                                            Crystal compatibility 32khz ASUS UX325 NB255_PCB_MB_V4
                                            by pc_okay
                                            Hello friends,
                                            Its been a while, i wish you an happy new year 2025 !
                                            I have this laptop doesn't start, power light up a second when pluging USB-C charger.
                                            Laptop take 0.11A.
                                            All signals and voltages before SLP_S4# are OK but no SLP_S4# , S3...
                                            I get no oscilation on XTAL 32.768 KHZ
                                            Battery is not charging but charging led is here.
                                            PCH heat at 30° approximatively. (with no heatsink)
                                            I think this crystal might be dead, i have only boardview giving me this: XTAL 32.768KHZ 12.5PF/20PPM.
                                            It's a 2 pins Crystal.
                                            01-13-2025, 09:26 AM
                                          • OakleyDAR
                                            Zotac GTX 1050 Ti Mini ZT-P10510A-10L Replacement Crystal
                                            by OakleyDAR
                                            HI,
                                            I'm looking to replace the 27MHz crystal on this board as it isn't generating the signal. I thought it would be easy to identify a suitable replacement as there are clear markings on the crystal, but it appears I was wrong as Google gives nothing. Bad photo attached, but it has X27.0000 and 16AP1 on the casing. It appears to be a 3225 package, but looking through suppliers there are lots of different things like capacitance, tolerance, active or passive, etc. that need to be considered. Could anyone help identify a suitable replacement please?
                                            Thanks....
                                            04-21-2024, 03:07 PM
                                          • Keshenatech1
                                            Question on microprocessor crystal oscillator circuit
                                            by Keshenatech1
                                            I'm troubleshooting a reel controller board for an IGT slot machine. The digital section seems to be dead. There is no USB communication, PC or utility program for flashing firmware do not see it but they do see good/working boards. I noticed the waveform on the crystal is very erratic/asymmetrical/glitchy on the bad one compared to the nice even waveform on a good board. My question is would this most likely be caused by a bad crystal or something gone bad in the circuit loading it down? I'm attaching a couple pictures of my scope probing the good and bad boads.
                                            02-26-2024, 11:05 AM
                                          • GuiTi
                                            Need Custom BIOS (UEFI/Dualboot) for Lenovo Chromebook 100e Gen 3
                                            by GuiTi
                                            Hey everyone!
                                            I need help with my Lenovo Chromebook 100e Gen 3.
                                            Here are the details:
                                            • Motherboard: LA-L131P
                                            • MFG Date: 2022/01/07
                                            • MTM: 82J80001BR
                                            • MO: MPNXB2103001
                                            • Factory ID: LI123
                                            I bought a new Winbond 25Q128FVSG chip.
                                            The chip currently on the board is the same model but with different ending letters.
                                            I can’t use the CH341 clip on the chip that’s on the board because it’s too low-profile and doesn’t make proper contact.
                                            The Chromebook is Google account locked, and I’ve already tried everything.
                                            I understand that I need to replace or...
                                            10-14-2025, 08:41 AM
