Re: Buying custom crystals...
OUCH. No wonder why it was railing, it thought the frequency was ZERO because it couldn't detect any pulses from the VCO! I was hoping I could tune the VCO's amplifier to hit CMOS VIL/VIH but this is not the case. So I'll need to amplify it further before I can feed it into the divider
I then decided to write in a tiny frequency counter into the microcontroller because I grew tired of using my frequency counter... now I don't need to lug the counter around to test. It actually worked quite well despite having a oddball timing pulse source (I have a 28 1/8 Hz heartbeat clock, don't ask why...), plus I did not gate, so I lose pulses during computation. It only has 4-digit resolution too. Alas such is life, compromises. Still good enough to know if I'm in the ballpark, a quick go/no-go alive or dead test: at least tell if the input is reaching VIL/VIH thresholds.
Hmm...might have to cheese this with a Schmitt trigger inverter/buffer IC or something, consistently biasing a BJT seems annoying. Except I may need to shift the zero point... And I really need to design something that would work with 48MHz not just 8MHz that it is right now. So no op amps, or none of the cheap op amps I have in my collection. My 17MHz op amps are not fast enough
More analog trouble.
Then again perhaps a voltage controlled device is what I need, else I would need a differential pair such as in the op amp... hmm... think think think. Such is electronic design
