Is there a big difference between these 2 diodes?
  • NeedsMoreFlux
    • Oct 2017
    • 121
    • California
    I'm trying to figure out why the axial diode blew out another chip that I still have not been able to identify.
    These are both 1n5819.
    I pulled one like this(which I believe was a 1n5819):
    https://cdn.badcaps-static.com/pdfs/...5718d86211.pdf
    and replaced it with one like this(off ebay):
    I checked and did not find any shorts/bridging from the new solder joints.
    And now I am trying to figure out what this 8 legged, SOIC 8/Sop 8 AN3102 chip is, since that appears to be a chinese number.
    If anyone knows what that AN3102 number means or is replaced with, I will be forever in your debt. And I have a big box of spare parts if you ever need anything.
    Thank You!
    Disclaimer: Don't trust a thing I say-I am frequently wrong!!!
    I have tons of spare parts, some used, some N.O.S. ham transistors and caps. Message me if you need any parts.
    Some of the things I've fixed:
    60" Vizio-bad LED's. iBook G4: Resoldered VCC Plug. Geo Tracker ECU: Swollen / Leaking capacitors. Windows Laptop: Soldered broken LVDS wires. Dryer: Burned contact on temp switch. Oven in R.V.: Bad contacts in relays-Exploded by the looks of them! Samsung Oven: Burned contacts on Relays. MSI Motherboard: BSOD-Swollen capacitors, bad graphics card, Moved SATA Input from SATA 1 to SATA 2 plug
    Re: Is there a big difference between these 2 diodes?
    5817 is only rate at 20V, 5819 is rated at 40V so you should never go with lower Voltage than the original.
    • NeedsMoreFlux
      • Oct 2017
      • 121
      • California
      Oops, haha. I don't know how that happened. I clicked on a 5819, at least I think I did!
      But yah, thanks. I was reading up on those different diode numbers.
      I did order 5819's off ebay, and after soldering it in-it blew another chip!
      • Dvsr
        On M-Audio AV40 active studio speaker's two zener diodes get really hot.
        by Dvsr
        Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
        I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
        After replacing the caps I started testing out the speaker. It seemed...
        09-10-2025, 10:20 AM
      • caspian
        What Zener Diodes on a Linear Power Supply
        by caspian
        Dear members,
        I have a linear variable power supply with unknown brand name that I used for voltage injection.
        Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
        In addition, I discovered that its zener diodes are defective.
        I can replace the burned transistors.
        But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
        Therefore, I cannot replace the zener diodes.
        I do not want to test the zener diodes in a test circuit to discover their model or value.
        no schematics are available...
        05-26-2025, 12:38 PM
      • Nikolai Danylchyk
        Lenovo T480s usb-c charging port replacement - Knocked off a couple of diodes.
        by Nikolai Danylchyk
        Hi folks. As the title says, I was doing a port replacement on a Lenovo Thinkpad T480s and in the process of post-solder cleaning, I somehow knocked off 2 or 3 diodes (i think they are diodes) near the main usb-c. I can't seem to find what kind of a diode is that. I know it's ultra tiny and just has a letter "G" on it. Would someone maybe have a proper schematic for the t480s model? I can only find the non-s one and it's quite different to the "s". Would love to figure out what component that is.
        Thanks in advance!...
        05-08-2025, 06:18 AM
      • Fontana
        BN44-00505A dead. Need to know voltages on output diodes (Samsung T22B300EW)
        by Fontana
        1. g´day! I have a samsung 22" tv monitor to fix. power supply model bn44-00505A. some stuff blown up on the primary, according to research something typical on this model. secondary seems ok. writings on the board say in outputs a5v (standby), b5v (switched) both on the lower 3 diodes on the picture, vamp and b13v (12.8v, both are the linked at the connector that goes to the main board) my question is, are both the upper diodes for 13v? I believe so but wanted to make sure before injecting voltage there to test. I injected 5v on the lower side and standby circuit is working fine
        2. if
        12-18-2023, 05:45 AM
      • DjKrish
        Zener diodes component equivalents
        by DjKrish
        Hey guys, i have a sony home theater power supply thats a few smd zener diodes blown but its so hard to get them. any recommendation for me to use normal zener diodes?
        1. UDZSTE-1710B (9.99V 5mA) (SC-90, SOD-323F)
        2. UDZSTE-1724B (24V 200mW) (SC-90, SOD-323F)
        3. UDZSTE-175.1B (5.1 V 200 mW) (SC-90, SOD-323F)
        These are the diodes. If i use normal zener diodes, it will work right? Question is, can i get these values on normal zener diodes?
        08-15-2021, 11:06 PM
