Anyone I.D this chip/have datasheet
  • nogger
    • Aug 2010
    • 190
    Hi all, just wondered if anyone had any info/datasheet or knew what this chip does. It's made by NEC and has the number 12233766a (pic attached). I have done the usual googling but came up with nothing .
    It is used in a diversity amplifier board from a BMW 3 Series car, the board picks up the RF signal from the remote keyfob and passes the signal to the security module to unlock the doors. I think it's some type of voltage reg or dc-dc chip
    Thanks in advance
    Nogger
    • 31277
    Re: Anyone I.D this chip/have datasheet
    so it's a 433MHz decoder?
    • nogger
      • Aug 2010
      • 190
      No, i don't believe it's an RF chip, there are other chips (TDA chips) on the board that i have identified as doing the decoding, this seems to be part of the voltage reg circuitry.
      Nogger
      • Agent24
        I see dead caps
        • Oct 2007
        • 5085
        • New Zealand
        Customised part number specifically for BMW probably... and I doubt they'll tell you!
        I'm going to guess information on these will be very scarce in the interests of security.
        -David VanHorn
        • nogger
          • Aug 2010
          • 190
          The image i attached was from elektroda.pl as the image i took was out of focus. There's a user on there asking the same question, he calls it a microcontroller. I dont think its a custom number for BMW as the board is full of standard Philips and ST chips, Also on Aliexpress there another image of the chip with Chinese writing across the image but i dont want to buy one, just need the pinout/details of it
          Nogger
          • jiroy
            • Jun 2016
            • 2416
            • Lebanon
            Well , at least , it's not a rarity , and it's available :
            https://www.jotrin.com/product/parts/12233766A
            • nogger
              • Aug 2010
              • 190
              Yes, there's lots of Asian suppliers with links to datasheets which turn out to be not links to datasheets
              • jiroy
                • Jun 2016
                • 2416
                • Lebanon
                Not necessarily . Most of the world website suppliers rely exclusively on some few specialized websites for Datasheets , like the powerful "Data4u" and "Alldatasheet" , which , they too , rely on the datasheets released by the components manufacturers . Suppliers websites rarely own Datasheets archives .
                As so , when a datasheet is unavailable , it means the related company didn't release it for public , for different considerations , like for an example Anti-reverse engineering , or a discrete programmable microcontroller , etc. etc...
                • acedogblast
                  by acedogblast
                  11-02-2024, 05:13 PM
                • DynaxSC
                  ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
                  by DynaxSC
                  Hi
                  I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
                  08-04-2025, 12:20 PM
                  Common SPI bios chip programming Questions and Answers
                  by SMDFlea
                  Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
                  A: If you can`t read from it how do you expect to write to it ?.
                  Q: Why is my bios chip unreadable ?.
                  A: The programmer is faulty or has a worn or broken zif socket.
                  The USB cable is frayed,connector pins worn or some other physical damage.
                  Not enough amperage or voltage to power the programmer properly.
                  Bad...
                  09-02-2021, 04:40 PM
                • Troystain
                  Help EZP2023+ updated chip database for w25q256jveq?
                  by Troystain
                  Hello, anyone here have updated ezp2023+ chip database in .dat file format.
                  I need to add w25q256jveq chip but I do not know what data should I type.
                  I'm using the ezp chip dabase editor posted from here https://www.badcaps.net/forum/troubl...ro-programmers
                  The currenty unit model that I am trying to detect is HP elitebook 640 g9 which is currently locked on admin bios....
                  11-25-2024, 12:53 AM
                  Renesas H8S/2112 R4F2112 R4F2112R - 16-Bit Single-Chip Microcomputer Datasheet
                  H8S Family / H8S/2100 Series
                  Ordering codes:
                  F2112TE25V F2112BG25V F2112LP25V
                  The core of each product in the H8S/2112 Group of CISC (complex instruction set computer) microcomputers is an H8S/2000 CPU, which has an internal 16-bit architecture. The H8S/2000
                  CPU provides upward-compatibility with the CPUs of other Renesas Technology-original microcomputers: H8/300, H8/300H, and H8S.
                  As peripheral functions, each LSI of the group includes a serial communication...
                  10-23-2024, 02:33 AM
