LM723 adjustable bench PSU not working
  • eccerr0r
    replied
    Re: LM723 adjustable bench PSU not working
    What's the voltage at the base of the 2n3055 too, check for bad wire?
    Are you measuring with any load on the output? With these emitter follower designs, it gets confusing when the output (emitter) has no load...
  • R_J
    replied
    This looks similar model is PS-1502d under many names
    replied
    your 3055 could be open-circuit.
    i'v never seen a 723 fail - and worked with hundreds of them - i still have several tubes of new ones.
  • Dannyx
    started a topic LM723 adjustable bench PSU not working
    Good day folks. I've had this cheap and nasty adjustable power supply in the shop for about a year now. It's called "Bakku" (obviously a take on Hakko), though it's not the least bit important, because I've seen this exact same product under many different names and appearances.
    Anyway...less than 2 days ago, this thing dies on me: my colleague tried charging some laptop cells on it but forgot about them and left them connected for more than an hour. The little transformer inside got extremely hot and the primary shorted out, blowing the fuse and rendering the whole thing useless. I took it apart and tried replacing the transformer with a laptop power supply at 24v DC which matched the original voltage of the transformer. It worked to a degree, the voltage adjusted up and down and I was ready to leave it like this, except when I tried charging the laptop cells again, I had to increase the voltage A LOT before the current started going up and when it finally did so, it jumped to around 2a, then something died again and everything dropped to 0. Now I can't figure out what went wrong and why it failed, since it's never failed under heavy loads with its original transformer. The voltage now stays at 0v all the time, so I suspect the output transistor died, despite not showing any shorts. The thing is based on an LM723 although I can't fully understand how it operates in this case. The output transistor is a 2n3055 fed by a B647 PNP. Although I get 22v out of the collector of the B647 and into the base of 2n3055, I get nothing on the ouput (the emitter) of 2n3055....I started drawing the schematic of the thing (though it's far from complete and doesn't include the current sensing side) and I kinda get how it's SUPPOSED to work, although I don't understand why the B647 transistor is not driven by pin 10 Vout, but is instead connected to pin 11 Vc of the LM327...how does such a thing work ? Actually pin 10 is floating :| Let me know if you need any clarifications on the schematic - it's rather messy and not to scale. Don't worry about those breakout connectors - they go to the voltmeter and ammeter on the front panel, which do come on, so I don't think there are any issues there.
    Trying to fix it first and then perhaps increase its current capacity a bit by employing a larger transformer, as that's its main limitation at the moment - the build itself seems stable enough.
  • ohren
    Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
    by ohren
    Hello!
    I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
    Measured voltages with no load:
    After rectifier diodes
    12V: 6.17 V
    5V: 5.67 V
    Secondary transformer pins AC measurement (really don't know if this says anything)
    12V: 2-2.5 V
    5V: 1.04 V
    I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
    03-18-2023, 10:33 AM
  • mikey5791
    Is it possible for transformer substitution?
    by mikey5791
    Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
    Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
    My questions are
    1. How do i test to see if the transformer is in good working condition?
    2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
    Hope you guys understand what i was asking. My intention is...
    11-03-2022, 02:11 AM
  • dennis_elx33
    3PHASE STEP-DOWN Transformer in Check
    by dennis_elx33
    Hello All,
    i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
    Problem statement: Power tripped Off
    Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
    Action Done:
    1) Replaced the faulty parts with good spare.
    2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
    12-02-2024, 06:52 AM
    ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) Book Specification for Upgrade or Repair
    This specification for the ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T101HA - X5DHD boardview and T101HA - X5DHD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
    09-06-2024, 04:40 PM
    ASUS Transformer T304UA-P71SP-CA Hybrid (2-in-1) Pro Specification for Upgrade or Repair
    This specification for the ASUS Transformer T304UA-P71SP-CA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T304UA-P71SP-CA boardview and T304UA-P71SP-CA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
    09-06-2024, 12:00 PM
