Lets talk about CC CV ....
  • EasyGoing1
    Shock Therapist
    • Sep 2016
    • 977
    So as Ive stated in other threads, I've been wanting to build a LiIon charger with an Arduino ... just because. Really though, I want to understand the process and get a better feel for battery technology in general.
    When I started googling on this topic about a year ago, I saw a lot of the CC CV stuff being thrown around. Constant Current and Constant Voltage power supplies are not something that I've ever messed with.
    It also took me a while to realize that in order to maintain a constant current, the power supply must adjust voltage - or else Ohm would be made a liar ... and we know he's not a liar.
    And maintaining a constant voltage is not as difficult as maintaining a CC would be - in my opinion.
    Charging a LiIon battery ... lets assume that the cell is a 4.2V cell and lets pretend that the C value of the battery is 3. Therefore, I can charge it at a CC of 1.5 amps or less and feel safe about it.
    What I've been kinda struggling with, is in the situation where the battery may be kinda low at 3.2V and in order to get the current up to 1.5 I might have to apply a voltage across the battery HIGHER than 4.2 ... but everything I've read says that applying a voltage higher than its rated for is bad juju ...
    Can someone comment on this? Because it seems contradictory to me that you would have to violate the batteries own laws in order to stay with spec of the battery during charging.
    sigpic
    • 31156
    Re: Lets talk about CC CV ....
    if your not wanting to use a dedicated chip, take a look at the old L200 regulator.
    • EasyGoing1
      Shock Therapist
      • Sep 2016
      • 977
      Im not building this because I need one, im building it to UNDERSTAND everything involved in actually charging a LiIon ... its for knowledge, not function.
      sigpic
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        Actually that is the problem with Li-Ion. You NEVER charge with a voltage over 4.2V - even if it's not drawing enough amps to charge quickly. So don't expect that 1.5 amps to charge that battery, likely the outcome is to throw that battery out and buy a new one.
        It's possible to build a CVCC battery charger with a LM317 and a transistor. The transistor will do the current limiting and the LM317, the voltage limit.
        This is an example of probably the simplest LM317 charger: http://danyk.cz/li-ion_en.html . Completely analog, no microcontroller needed. Only thing this lacks is charge completion.
        • EasyGoing1
          Shock Therapist
          • Sep 2016
          • 977
          From that link, "Stabilization of current is not as critical as the stabilizing voltage, so it is sufficient to stabilise it by a shunt resistor and NPN transistor"
          Thats useful information.
          Im kinda thinking that the internal resistance characteristics of the battery is the dictating factor on how much current its going to consume...
          So it sounds like this statement would be accurate concerning the charging of a LiIon battery:
          The constant current stage of charging must never allow the current to exceed one half of C, while also ensuring that the voltage applied to the battery never exceeds its rated value.
          So if we start charging the battery and lets say we start out at 3.4 volts ... but at 3.4 volts, its only drawing .2 amps but rated for charging at 1 amp, then we increase the voltage going to the battery until one of two things happens:
          We hit the max rated current for charging - at which point we stop raising voltage and only adjust it to maintain that current until we reach 4.2V ...
          ok this is beginning to make sense now ...
          sigpic
            • 31156
            i hope your working on a paving stone or a large ceramic tile incase you set one of these things off!!!
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8701
              Indeed. Improvising lithium ion chargers is the same as working with explosives here
              • EasyGoing1
                Shock Therapist
                • Sep 2016
                • 977
                You should see my breadboard while working on an LM317 project ... the plastic in about three rails was liquid ... but only for a few minutes ... lol
                sigpic
                • EasyGoing1
                  Shock Therapist
                  • Sep 2016
                  • 977
                  This photo was texted to me about an hour ago by my good friend ... he took it last night and yes, that is his back yard ...
                  sigpic
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8701
                    I think the worst liquefying experience I had was on my digitally controlled CC/CV PSU (in this case as it's a bench PSU, reaching 0V is a consideration...) where my gate drive was not quite high enough to fully saturate the transistor coupled with the tiny heatsink. I never measured the temperature of the MOSFET and it melt its insulator.
                    Fortunately the heatsink was isolated and the insulator wasn't technically needed, so fortunately no shorts and no collateral damage.
                    • EasyGoing1
                      Shock Therapist
                      • Sep 2016
                      • 977
                      I still dont know why mine melted like it did ... Sometimes the wiring on the breadboard gets a little out of hand and there may have been a short somewhere is all I can think of ...
                      sigpic
                        • 31156
                        the center pin on the lm317 is physically part of the rear tab!!
                        • EasyGoing1
                          Shock Therapist
                          • Sep 2016
                          • 977
                          Yes, I'm well aware of this ... the back tab was exposed to open air.
                          sigpic
                          • x_orange90_x
                            Samsung UN50KU6300F constant reboot, bad backlights?
                            by x_orange90_x
                            This TV is in a constant reboot where the screen very dimly lights up for about 2 seconds and says SMART TV. I checked the power supply and visually all components look good. I unplugged the main board to see if the backlights would come on but they do not. I also tried my LED tester on the backlight plug and didn't get anything. I know some Samsungs will not light off a single led is out regardless of using a tester, so I'm thinking they are bad. I found a whole set for about $25 which isn't bad, but before I buy them is like to know if they would indeed cause a constant reboot like this tv is...
                            02-09-2024, 08:41 PM
                            Adjustable Boost Power Supply DC-DC Constant Voltage Current Charging Module
                            I want to know if I could hook up a solar panels to this boost converter would I have any issues doing and I would have issues what would they be
                            https://www.ebay.com/itm/116497313155?var=416785404161
                            Here are some of the description from the eBay seller
                            The main parameters:
                            1. Product name: High-power non-isolated DC boost module power supply.
                            2. Product model: 100A2000W.
                            3. Input voltage: DC12V-60V.
                            4. Input current: 100A (maximum)....
                            05-18-2025, 09:45 AM
                            Richtek RT8205L RT8205M Power Supply Controller for Laptop Computer
                            The RT8205L RT8205M is a dual step-down, switch mode power supply controller generating logic-supply voltages in battery powered systems. It includes two Pulse-Width Modulation (PWM) controllers adjustable from 2V to 5.5V, and also features fixed 5V/3.3V linear regulators. Each linear regulator provides up to 100mA output current with automatic linear regulator bootstrapping to the PWM outputs. An optional external charge pump can be monitored through SECFB (RT8205M). The RT8205L/M includes on-board power up sequencing, a power good output, internal soft-start, and internal soft-discharge output...
                            10-23-2024, 03:58 AM
                            Richtek RT8205A RT8205B RT8205C Power Supply Controller for Laptop Computer Datasheet
                            The RT8205A RT8205B RT8205C dual step-down, switch-mode power supply controller generates logic-supply voltages in battery-powered systems. The RT8205A/B/C includes two pulse-width modulation (PWM) controllers fixed at 5V/3.3V or adjustable from 2V to 5.5V. An alternative LGATE1 output LG1_CP can be used for external charge pump (RT8205B). And an optional external charge pump can be monitored through SECFB (RT8205C). This device also features 2 linear regulators providing fixed 5V and 3.3V outputs. The linear regulator each provides up to 70mA output current with automatic linear-regulator bootstrapping...
                            10-23-2024, 03:37 AM
                            AOZ2261NQI-11 Datasheet
                            General Description
                            The AOZ2261NQI-11 is a high-efficiency, easy-to-use DC/DC synchronous buck regulator that operates up to 28V. The device is capable of supplying 8A of continuous output current with an output voltage adjustable down to 0.6V ±1%.
                            A proprietary constant on-time PWM control with input feed-forward results in ultra-fast transient response while maintaining relatively constant switching frequency over the entire input voltage range. The on time can be externally programmed up to 2.6µs.
                            The device features multiple protection functions such...
                            10-07-2024, 04:02 AM
