What did I damage
+ More Options
Posts
  • Grimuls
    • Feb 2007
    • 16
    What did I damage
    Hello Gentlefolks.
    Here's my story. I really hope you can help.
    Some time ago, I made a simple little mod for my PC motherboard (model seen below)
    http://www.newegg.com/Product/ShowIm...%20Motherboard
    It was simple really.
    What I did, was to get faster speeds from the CPU FAN by bypassing the fan's thermal diode (by bridging it)
    It spun at 6000RPM then (really loud)
    so then use the motherboard's PWN (fan control) feature to control how fast it went in ratio to how hot the system got during gaming.
    I also connected another larger fan to the same Motherboard CPU fan header, and made provisions for the negative voltage of BOTH fans to be run from the POWER SUPPLY and NOT the motherboard (to lessen the load of the motherboard, and not cause it to die overtime as they often do when too much load is drawn from them)
    It worked lovely.
    Then, (and here's where it gets bad)
    I decided to clean my machine.
    I did that, but I also redid the mod.
    Just what nature of zaniness, drunkenness, deliriousness and or carelessness struck me then, I am not sure.
    But when I redid the mod.
    I RAN the 12 volts line from the PSU, against the 12v output of the motherboard CPU header
    It worked fine for a long time. my huge mistake didnt even come to mind.
    But I noticed something DIFFERENT happening in the fan control util I use (speedfan).
    NORMALLY, it would boot with the fans blaring load and fast, then drop IMMEDIATELY after speed fan loaded (and started controlling the pwm).
    But after my suicidal mod mistake, it would slow down GRADUALLY to the 50% (speed) mark showing the increments of fall.
    I ignored that.
    But now that I think of it, it was like there as a fight going on.
    Anywho - sure as the sun.
    SOME TIME after (which as applaud-able on MSI's part) the speed the fans were spinning at began to fluctuate.
    AUDIBLY! I could hear it fall in and out.
    Then it worsnened - which led me too look. And lo and behold;
    THE HORROR :| - I had FED the motherboard 12 volts into the header.
    I changed the cap nearest to the header.
    Now this happens
    It doesnt fluctuate now, but it isnt as fast as when it was good.
    Guys, WHAT did I damage?
    I MUST REPAIR THIS BOARD. I LOVE IT.
    and I'll buy a dead one even, to scrap what I need!
  • Grimuls
    • Feb 2007
    • 16
    Re: What did I damage
    I dont seem to be able to edit my own first posts.
    So I'll have to DP
    Here's what the mod SHOULD look like, vs what I did.
    (I tried replacing with a cap of the same values to get the right frequency for the PWM, didnt work)
    Close by are a set of resistors, an IC and a three legged component, I think is also another IC, or transistor)
    I want to know which I probably damaged by running 12v (NEGATIVE- I THINK) into the board.
    • Grimuls
      • Feb 2007
      • 16
      P.S
      The system now detects a hoard of new sensors!!??
      Weird.
      Speedfan Also continually gets error messages from the SM bus. (popping up in its status window.)
      It brings the CPU up to 45% load in increments each time it does this!
      http://www.youtube.com/watch?v=ObWDwPDKtsA
      • Grimuls
        • Feb 2007
        • 16
        Bump.
        I'm thinking the damage is around here.
        It SHOULDNT be hard to isolate if someone with a bit more knowledge in electronics could help out.
        This is where the components that make up the PWM are: (in the red circled area)
        • Grimuls
          • Feb 2007
          • 16
          help?
          • Grimuls
            • Feb 2007
            • 16
            wow. 107 views. n nothin'
            • zandrax
              Hit and miss
              • Dec 2007
              • 1157
              • Italy
              Sorry Grimulus, likely nobody know how to fix your problem so nobody answers you.
              Said so, the Smartfan continuous rescan can be or a bad setting (IIRC the autorescan option was recently added in version 4.37: check settings or try an older version) or a damaged PWM fan controller: since the controller is usually part of the chipset (in some boardspart of an external hardware monitor chip) this is a bad news.
              If I were you and the board were fine except for the header issue, I'd forget it, connect the two fans to two potentiometers and feed them through a molex: you lose the rpm monitoring but you can control temps and adjust fan speed by hand.
              Zandrax
              Have an happy life.
              • kikkoman
                • Jul 2007
                • 691
                no.1 in my picture is the fan driver, and no. 2 is the i/o chip.
                since no.2 reports the SMBUS devices and usually has fan control too, it's probably the culprit.
                replacing it probably isn't worth the hassle (and that chip will be hard to source anyway).
                so, as zandrax said, using a hardware fan controller is probably the cheapest option.
                "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
                • Grimuls
                  • Feb 2007
                  • 16
                  Zandrax
                  Are you suggesting a older bios flash?
                  From my reading on PWMs and the model# of the components found close to the CPU fan header on this board, they are most definatly proponents of the PWM.
                  well. Thats just the thing.
                  NOW, theres the problem of the SMBUS causing 40% CPU spikes.
                  I need to check whether or not this only happens in speedfan or not.
                  BUT HERES MY QUESTION FOR YOU
                  Would the fan controller for the CPU fan be THAT far???
                  That one is right beside the CHA_1 header, which, works fine.
                  I'm thinking that it would be closer to the area I outlined.
                  Please just entertain/oblige me a lil more with this one.
                  I can understand that it seems completly redundant/hopeless to you but..
                  If thats the damaged header's driver.
                  Where is the other one's?
                  And, How would I use my meter to test which is which?
                  Because certainly, their are other components that would output 12/5 VDC.
                  • zandrax
                    Hit and miss
                    • Dec 2007
                    • 1157
                    • Italy
                    [QUOTE=Grimuls]Are you suggesting a older bios flash?[QUOTE]Sorry, my mistake: I wrote Smartfan instead of Speedfan.
                    I think CPU spikes are related to Speedfan's continuous scanning so I suggest trying an old version which may not exibit the same behaviour: install e.g. version 4.36 or older and watch if new SMBUS devices appear again and again.
                    Zandrax
                    Have an happy life.
                    • emil_t
                      RTX3090 working fine but fans not spinning
                      by emil_t
                      Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
                      04-12-2024, 06:54 AM
                    • JayPoorJay
                      Hot Water Rad - A Few ECU Fans and a Timer Switch
                      by JayPoorJay
                      Good Afternoon, Good People.
                      I know this will be an elementary little project for most if not all of you, but I thought I would write a post and get put on track, rather than bumbling my way through it with all kinds of trials and errors.
                      I REALLY would appreciate y'alls help.
                      This is the problem - My wife and I purchased a big ol Victorian/Colonial House in NYC two years ago. The kitchen is surrounded on 3 sides by exterior walls, there is also a 1/4 of the kitchen floor (ceramic tiles) that has a crawl space underneath, and the kitchen gets FREEZING cold...
                      10-29-2024, 12:54 PM
                    • Powderfanupnorf
                      Dell AL440LX power on switch circuit help required
                      by Powderfanupnorf
                      Hi Everyone. First official post so fingers crossed I conform and also manage to get photos to work.
                      So I am requesting some help from anyone who happens to have one of these motherboards to hand and perhaps a multimeter.
                      My board has a single row of header pins for all the front panel stuff (have seen others where they are grouped together differently so thats no help) and the two pins for the power on switch had been previously repaired and I am trying to make a better repair. There looks to be pad and trace damage and im happy to relocate the header pin/pins to...
                      06-24-2024, 01:24 PM
                    • magik20
                      Wine Enthusiast 170 Bottle N'Finity Wine Cellar Model # 273 02 70
                      by magik20
                      I'm hoping someone might be able to offer some guidance on repairing a Wine Enthusiast N'finity 170 bottle wine cellar, model 273 02 70.
                      I recently acquired this unit for free via Facebook Marketplace, hoping to fix it up as a gift for my wife. I have some basic electronic skills (comfortable with a multimeter, basic soldering, identifying components) but I'm definitely not an advanced technician.
                      The main challenge is that when I picked up the unit, the main control/power board had already been removed and the previous owner said it needs a...
                      04-30-2025, 04:46 PM
                    • Joel Ohana
                      Lenovo IdeaPad 3 15IAU7 that suffered water damage
                      by Joel Ohana
                      I have a Lenovo IdeaPad 3 15IAU7 that suffered water damage. It doesn't turn on (white power light flashes when on button pressed), and the amber light flashes when plugged in.
                      Symptoms:
                      • Short detected – sparks appear when touching the charging port connection with board with a metal (even a multimeter probe).
                      • Visible damage – after cleaning corrosion, I found 4 possibly burnt memory chips near PC3165, labeled UD5, UD6, UD7, and UD8.
                      What are my next steps to diagnose and possibly repair it without replacing the entire board? Any guidance would be greatly...
                      03-06-2025, 11:25 AM
