nets on the motherboard
  • myth77
    • Feb 2017
    • 380
    • Croatia
    I am a big noob but eager to learn so.. please help me to understand how DC electricity in laptop motherboard works and all through the nets... so, there are many nets on the motherboard...for example basic are gnd-ground, nv-negative, pv-positive....
    And, off course when i plug the charger in, the DC electricity is going from positive part in charger to all chips and other parts in motherboard, powering them up, and coming back to charger through negative and ground? making the whole circle? off course, on its way mosfets, diods, resistors... are changing voltage, resistence to supply each chip, card, memory modul, cpu with voltage needed to work. Is this correct?
    Further, when charger is not plugged there is no connectivity or should i say continuity in the whole motherboard, because there is no closed circle. But, if i use multimeter i will see that lets say ground and negative are connected, and they shouldnt be in any way connected to any other net? positive or other? cause that would mean that there is short somewhere? further, should all other nets have no continuity also? lets say net +5vs and +5v_kbled? should they have continuity if charger not plugged?
    Please answers/advices, links to books/pdf on the theme very appriciated
  • cpt.charlie
    • Sep 2013
    • 270
    • Spain
    Re: nets on the motherboard
    DC voltage isn't "connected" to all chips, dc input goes to many power supplies, some of them will be ON all time (mostly 3.3V and 5V) and some will be OFF when laptop is OFF but with power (S5 status), you shouldn't have continuity to ground on any rail (be careful, big BGA chips will fool your meter and might show a "short").
    In most cases all 5V nets "come" from the same power supply, but the power of the net could be controlled by a mosfet or transistor and after that point the power has a different name, thus a new NET.
    • myth77
      • Feb 2017
      • 380
      • Croatia
      my mistake, bed english...i meant goes to many power supplies
      ok, thx, but when power is down, should i have continuity between those new nets and 5v net or it depends? if depends, on what it depends? Or i will figure it with expirience?
      • vinceroger69
        • Mar 2012
        • 6714
        • uk
        This guy has some well explained videos
        https://www.youtube.com/channel/UCXb...AKbUKImRX-HBHg
        • cpt.charlie
          • Sep 2013
          • 270
          • Spain
          Just read the schematic and you will discover if it shiold have continuity or not.
          • motormayhem
            Lenovo T460 Only Charges on One Charger
            by motormayhem
            Laptop Question
            I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
            A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
            05-12-2023, 01:46 PM
          • Docus
            Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
            by Docus
            Hi everyone 😀,
            I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
            To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
            Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
            1. I already own the exact same model, but its plastic chassis is badly damaged.
            06-10-2025, 04:24 PM
          • glovecaps
            by glovecaps
            11-25-2024, 04:23 PM
            NVDC charger configuration...
            11-05-2024, 03:28 PM
          • Johndill
            Dell Inspiron 7567 LA-D993P odd charger issue
            by Johndill
            Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
            There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
            I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
            Here are the tested scenarios:
            1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
            2. With the laptop off, plug in charger (LED says on) & the front charging...
            11-16-2022, 10:55 PM
