Car Battery Spot Welder
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
    Is there any high current pouch battery that are size 60mmX80mm maximum thickness 21mm for a battery operated tab welder
    I have a battery operated tab welder and the battery does not have enough current for the battery tab welder because after about 30 welded it does not have the same current output it voltage has gone down by at least 0.500 volts or maybe a more than that
    I can fit 21700 battery cells in the enclosure it is very tight fit for four of them that are 35 amp high current capacity 35X4=140 high current output this should work a lot better than what is installed right now
    I tested the battery cells there are installed right now and they are testing good with no issues that I...
    02-04-2025, 08:08 PM
    New Super Capacitor 5v DC Battery Spot Welder with a 12 volt power supply
    This is a new item at Battery Hookup that I bought I have always wanted to buy a good capacitor battery stud welder but they are to expensive for my budget that I want to spend on one this was surprisingly moderate price for what it can
    It came by FedEx today so I decided to try it out on some tabbing that my battery stud welder has a little issue making constantly welded with out having to redo some because it would not get hot enough to do it properly
    Well right out the box when the super capacitor charges up with the setting as follows does a very good job the first...
    05-21-2023, 04:28 PM
  • mkdj
    by mkdj
    Mark and model: ASUS X571
    Tests already made:
    - I have removed...
    07-14-2025, 09:16 AM
    Modifing a Battery Spot Welder because of Controller Issues
    I keep having the same exact issue with these battery spot welder controller boards
    They either do one of two things
    One the controller does not send the signal for the transformer fire which is a very common problem with this controllers micro controller failure
    Or
    The controller has some malfunction which means that it does not cycle the pluses more than once or none at all and should do it any where from 1 pluse to 20 pluses because you can not change the setting does not respond to its input micro controller failure
    This...
    10-12-2019, 08:51 AM
