I see a lot of disparaging remarks about using rectifier diodes in parallel. This configuration is not always a sign of cost cutting or poor design. Naturally, discreet Si diodes in parallel will be unrepredictable in their operation. It is possible that Si rectifier diodes on the same substrate would behave better. However it is good to remember that Si diodes have a negative temp. coefficient. As the temperature rises, Vf will go down, which almost assures that only one diode will take the entire amount of current. Probably not worth the effort for power rectifiers.
Schottkey diodes on the other hand have a positive temperature coefficient. Parallel Schottkey diodes self-adjust their Vf with temperature variations to share the current equally. Parallel Schottkey's, especially on the same substrate or on the same heat sink is a workable arrangement and shouldn't be taken as a sign of poor design practice.
It's cold here at times in Canada, but not that cold!
Easy solution is to go to AcuRite website and purchase the sensor. Right?...
