Hacked a Kentli AA 2800 mill-amp battery for my MP3 player
    • Jul 2011
    • 6040
    Here is the story of why I did this battery hack and this mod to my MP3 player
    I got this MP3 about 10 years ago and when was brand new if you left the battery in it would be dead the next day so you had to remember to take the battery out of it
    then put back in when you want to use it---> (this a pain in the a** if you what I mean
    I even use the Kentli battery in it and would run this battery down to it might take a day or so to this (Really) I had with this MP3 player so I would hardly use it because of this
    So a couple week ago I got a very bright idea to cut the metal case on this battery and
    see if I get buck convetor out of it with out catching the battery on fire well the first attempt did not go so well when I cut the top off the battery I cut into the board and the top of battery got so warm that almost could not hold on to the battery
    The battery was still ok but a little run down
    A week later I tried this again and this I was able to get the board out in one piece
    Here where the fun begins is soldier the small wire on this little board
    I took a ten foot long USB cable and cut the small connector end off
    and just used the red and black wires and cut off the white and green wires not need
    Some more fun with mod the display on the MP3 has a back light that was not hook up but want to use so I took 2.2k ohm resistor and hook it up to the red wire on the USB cable now I have backlight now this is cool now I can see it the dark
    Now to put MP3 back together this was real fun to get all the wires in my the right place so the switches would work it took a few tries before I got back together and everything works
    The buck convertor board fits where the battery went all I had to is cut a small notch for the USB cable can come out the back of the player It works real good now
    • Jul 2011
    • 6040
    Re: Hacked a Kentli AA 2800 mill-amp battery for my MP3 player
    I have one very small problem with this setup it when it goes from one song to the next you hear small amount of ringing in the background what can I do to get rid of it it is not very loud but you can hear it
    This is with the volume almost all the way up on MP3 player an on the Bluetooth speakers with the volume a little lower yes do not hear it at all
      • Jul 2011
      • 6040
      Update
      I found the problem was this
      The Bluetooth speakers that I was using has USB output port that I used to also power the MP3
      Player is where I was getting the ringing noise from
      As long as I power the MP3 player from a different USB power pack it is fine the ringing is not there
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • mkdj
        ASUS X571 no power : battery issue?
        by mkdj
        Mark and model: ASUS X571
        Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
        Tests already made:
        - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
        - I have removed...
        07-14-2025, 09:16 AM
      • techfreak9356
        Vostro 3400 (LA-K033P) won't charge battery, everything else ok
        by techfreak9356
        I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
        09-14-2023, 11:10 PM
        NVDC charger configuration...
        11-05-2024, 03:28 PM
      • ferah831208
        Strange battery present behaviour in Lenovo Legion 5-15ARH05 mb model nm-d041
        by ferah831208
        Hello guys, i need help with this problem, I have a NM-D041 mobo, it came with low impedance in 3v linear regulator rail, the cause was a damaged EC controller ITE8227e-192. I ordered a new one and replaced it. This laptop have a different chip for keyboard management and it8227e pins for programming ITE chips are not accesible through keyboard interface, I flashed it using i2c interface pins with vertyanov programmer because laptop was dead and SPI flash didn't have power (only 3v EC) so it couldn't access firmware stored in SPI memory. I read SPI and extracted it8227 firmware from original BIOS...
        03-18-2025, 01:18 AM
