Tube Amp Restoration
  • capwizard
    • Jun 2016
    • 1991
    I try to do Tube Amp Restoration, Anyone wants share the experience? How can I start?
    HH Scott 222C Tube Amp Restoration Part 1
    https://www.youtube.com/watch?v=3o6MD_zTtUM
    HH Scott 222C and 222D Tube Amp Restorations - Part 2 - BG025
    https://www.youtube.com/watch?v=khugZQYOGoQ
    #242: How to use an oscilloscope. Plus, seeing signals in antique radios | NJARC
    https://www.youtube.com/watch?v=niBGkqlh2XY
  • keeney123
    Lauren
    • Sep 2014
    • 2536
    Re: Tube Amp Restoration
    First does the unit work? Pins 2 and Pins 6 on the tubes should be the heater pins. These pins need to have continuity. If you read an open than the tube cathode is burnt out.
    • capwizard
      • Jun 2016
      • 1991
      Who invented amplifiers?
      Although he liked to refer to himself as the "father of radio," American physicist and electronics engineer Lee de Forest might be better described as the "father of the amplifier." In the early years of the 20th century, he was working in radio ("wireless telegraphy" as it was then often called) and had filed a couple of dozen patents on improved antennas and receivers. On October 25, 1906, he filed a patent for a "device for amplifying feeble electrical currents": a compact, electron vacuum tube called the Audion, later known as the triode (because, in its final version, it had three key electrical components inside). Although de Forest originally imagined the triode as a telephone-circuit amplifier, it eventually became an essential component of radio receivers. Despite inventing the Audion, de Forest neither perfected it nor ever really understood how it worked (the two things may well have been connected); it was left to others (notably Irving Langmuir of General Electric and Edward Armstrong, inventor of FM radio) to turn the idea into a practical device and explain the physics behind it.
      How, then, does it work? The sealed glass vacuum tube (shaded gray and labeled D, from which all the air has been pumped out) has three key components inside, which I've colored red, blue, and green. On the left, there's a wire filament (red, F) heated by a battery. This is the cathode or negative terminal. On the right, there's a platinum plate (green, b), which is the positive terminal. In between them, there's a grid of platinum wire (blue, a). When the filament is heated, negatively charged electrons boil off it and are pulled toward the positively charged plate, making an electric current flow. A negative voltage is also applied to the grid, effectively "braking" the flow of electrons. Because the grid is so close to the filament, even tiny changes to its voltage will make a huge difference to the current that flows from the filament to the plate. If we consider the grid to be the amplifier's input, the cathode-plate circuit is its output; a small signal applied to the grid can become a much larger, amplified signal at the plate.
      Vacuum tubes based on the triode made splendid amplifiers, but they were large, unreliable, and power-hungry. When John Bardeen, Walter Brattain, and William Shockley developed their "solid-state" transistor in 1947, they solved all three problems at a stroke, making possible small, portable, highly reliable amplifiers for such things as hearing aids and transistor radios. When integrated circuits were invented, in the late 1950s, they led to smaller, more complex amplifier circuits packaged as single chips (as op-amps typically are now).
      • jiroy
        • Jun 2016
        • 2416
        • Lebanon
        Lack of available parts will be a big handicap , so i thing it's a waste of time Capwizard dude . One tube at least seem totally out of any range visually .
        Even Transistors and digging a long distance past won't fit today as Integrated circuits are the champ today ..But maybe you're planning to be an antics collector , lol ...
        • keeney123
          Lauren
          • Sep 2014
          • 2536
          Actually the grid plate gets and alternating voltage frequency signal which is then amplified in the output.
          • vinceroger69
            • Mar 2012
            • 6714
            • uk
            i have been watching this mans videos on tube repair tv/radios for a while
            https://www.youtube.com/watch?v=NrglRHeihvg
            • DCJack
              B&K 707 tube tester. I need help.
              by DCJack
              Hi everyone!
              I managed to get my hands on a rough condition B&K 707 for "the best price" because it was not working. It's my first tube tester and I'm really wanting to get it up and running. I downloaded that manual that has the schematics and tested every resistor and capacitor and replaced the ones that failed. I replaced the missing 83 rectifier tube with a used but tested-good one. I also have a number 80 rectifier tube that I have used in tests before I found the 83 tube.
              Initially I noticed that I was not getting the red on-light to turn on, but it...
              03-05-2024, 05:05 PM
            • Schoenradt
              ECH81/6AJ8 Vacuum Tube Question
              by Schoenradt
              Recently I acquired an Eico HFT 92 AM/FM radio made back in 1958. The unit has had some decent modifications done such as replacing the rectifier tube with silicon diodes and replacing the main filter capacitor with electrolytic capacitors. When I powered it up FM wouldn't tune past 105Mhz. I checked the FM tuner front end assembly and found a capacitor not soldered to the coil from the Plate B+ to and ground on the other side of the coil. Some calibration was needed on the trimmer capacitor on the tuner. My question is AM is extremely weak. When I tap on the tube I get all kinds of snapping and...
              06-10-2021, 05:49 PM
            • Sik_6ty_Sixx
              HH Scott Model A510 Stereo Integrated Amplifier/ Graphic EQ - Blowing fuses in the LEFT speaker channel only. Any Help???
              by Sik_6ty_Sixx
              So like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...
              02-18-2025, 05:06 AM
            • linuxguru
              Fatman iTube (aka Dared MP-5) tube-buffered gainclone upgrades
              by linuxguru
              The Fatman iTube (OEM Dared, which also sold its own-branded version, the Dared MP-5) is a tube-buffered gainclone first introduced c.2005, to target the iPod market with a bookshelf tube setup. It became a huge success over the next ~15 years, selling over ~100k units worldwide to a market where it was often their first introduction to vacuum-tube audio on a budget.
              http://www.enjoythemusic.com/magazin.../dared_mp5.htm
              One of the Fatman versions landed up for auditioning a few days ago, and I must say that I was impressed with its form-factor, pricing,...
              03-13-2021, 08:45 PM
            • eccerr0r
              line powered filament LED lamps...
              by eccerr0r
              I was playing with one of those "filament" LED lamps. I noticed it seemed to flicker a bit...so I tried powering it with different things to try to extract information about it - noticed it seems to be 100% LED - no droppers, no PSU, no rectifiers, nothing - the LED "filaments" are hooked straight to the contacts!
              Wondering what's the distribution of how "filament" LED lamps are driven? Do any have capacitive droppers? rectifiers? CC PSUs?
              Found another "filament" LED that does have a PSU in it, seems to be a capacitive...
              09-21-2021, 09:41 AM
