Increasing Load on PSU for short testing
  • macattack600
    • Aug 2011
    • 97
    I am using atx psu 12v rail to find short on 12v rail motherboard. There is absolute short on this rail but 45 smd components in front of it. I started removing about 10 of the legs and gave up
    I believe the board has a internal short through the VIA and not a component but I want to confirm.
    I have now 1 12v car light bulb attatched to ground as the load the meter reads 2.0amps .
    question ----If I add another bulb and so on would that would raise the amperage by 2 ?
    Nothing is getting hot no components get warm, barley any voltage on the rail , the bulb in fact turns on so its completeting the circuit and not switching off the PSU
    I figure I need a heavy load to really feel this internal short to confirm.
    The more amps I tack on the more should be pulled through this heavy short right and I would be able to feel what is really getting hot, Providing i'm not going over say 12 or 16amps?
  • petehall347
    • Jan 2015
    • 4425
    Re: Increasing Load on PSU for short testing
    quick tip ... transistors and diodes short in the main ... capacitors also short but not so often ... ic chips short also ... resistors burn up .
    get the schematic and look for culprits then test on the board . if showing short remove and test again .
    the way you are going you will make smoke and things will be worse than they are now ..
    you could always get really involved and start checking voltage drops across resistors and checking voltages at semiconductors to find the short .
    • cpt.charlie
      • Sep 2013
      • 270
      • Spain
      If you connect another bulb in parallel yes, current should increase but you may ruin your board.
      • macattack600
        • Aug 2011
        • 97
        so for every bulb it should raise up 2 amps ? I'm thinking about attaching a long LED rope light I need a very demanding load.
        • macattack600
          • Aug 2011
          • 97
          I would like to learn what is thermal resistance short finding something to do with heating the board with heat gun and measuring resistance drop you know about this?
          • cpt.charlie
            • Sep 2013
            • 270
            • Spain
            LEDs won't make a high load BTW, use a car lamp instead.
            If you had a miliohm meter it could be handy to approach to the fault.
            • macattack600
              • Aug 2011
              • 97
              I also have a 50w 12v light bulb do you know if the amps i'm looking for will jump up by how much?
              • cpt.charlie
                • Sep 2013
                • 270
                • Spain
                50/12=4.16A in theory, consider some extra resitance at the short and contacts so current will be a bit lower
                • macattack600
                  • Aug 2011
                  • 97
                  Great I have 2 I will report back later. I really don't think I'm going to burn this rail up i'm getting no action @ 2 amps I'll go 1 at time , it's a large smd internal VIA pad connecting 45 components to both sides. I have hunch its shorted inside but I need to know for sure.
                  • petehall347
                    • Jan 2015
                    • 4425
                    check voltages at semiconductors before adding more current and burning the board and more stuff .
                    • macattack600
                      • Aug 2011
                      • 97
                      I have no voltage on the line I remove the resistor for voltage i'm missing per schematic. In diode mode--- red probe ground black on pad I get Dead short to ground and so on removing legs one by one stopped after 15
                      Cross reference working board gives 0.0500
                      • cpt.charlie
                        • Sep 2013
                        • 270
                        • Spain
                        Do you have a short in the general 12V rail (24 pin connector) or the short is related to 12V VRM rail?
                        • macattack600
                          • Aug 2011
                          • 97
                          In VRM rail , when I remove the resistor everything behind it gives 12v the board is making what's necessary but stopping short .
                          • macattack600
                            • Aug 2011
                            • 97
                            The psu says the 12v is rated @9.2amps so I guess I cannot go over that right?
                              BTW, the cold resistance of the bulb will be about 10~15 less than the hot resistance so watch out high inrush current.
                              • AJ847.63e
                                Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
                                by AJ847.63e
                                Hi Folks,
                                Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
                                I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
                                The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
                                05-06-2025, 10:37 PM
                              • repair-it
                                TOSHIBA DLP 52HM95 How to reset timer module on bulb
                                by repair-it
                                I replaced the bulb only on my Toshiba DLP The bulb is a TB-25. This is the first time I've done a bulb only replacement. Supposedly there is a timer module that needs to be re-calibrated or reset. I don't know where the module is located. I see some vendors selling the bulb with the housing stating module included which leads me to think the module is located inside the enclosure the bulb mounts in, but I didn't see it. Maybe it's inside the plug attached to the bulb?
                                Anyway - I am seeking information on how to reset this so called module so that the lamp will operate. Apparently...
                                10-11-2023, 07:18 PM
                              • ezenia
                                LUMIMAN Smart Bulb IC ID?
                                by ezenia
                                I have a LUMIMAN Smart Bulb that suddenly stopped lighting one day. The bulb is still detected in the app, but won't light. I've probed around and nothing seems to look off with any of the diodes, caps or resistors. The Bluetooth/Wi-Fi module seems to be working as it's still detected in the app. I even tried deleting and re-pairing the bulb (it didn't light, but I was still able to follow the pairing instructions), it re-paired fine, but still no light.
                                In diode mode, the LEDs all light up when probed so I'm guessing this means the LEDs themselves are OK. I was expecting...
                                04-28-2025, 05:56 PM
                              • dicky96
                                Load Testing Audio PA Amplifiers
                                by dicky96
                                Hi, one of my customers who rents out equipment for events and carnivals asked me to make a passive dummy load so the can test amplifiers under full power without causing noise problems to other nearby businesses.
                                He wants 8 ohm and 4 ohm loads, originally he asked for 8 ohm 500w resistors, and I said we could use two resistors in parallel for 4 ohm 1000W
                                Then I found these cheap power resistors on Alibaba. It says they are 'Braking' resistors, but they seem to be suitably rated for my purpose
                                https://www.alibaba.com/product-deta...w-Resistor-8-o...
                                01-12-2021, 10:31 AM
                              • DXseekerMO
                                Samsung PN51F8500AFXZA, PSU BN44-00619A, Short QP802S, ICP801S testing/sourcing
                                by DXseekerMO
                                Hello everyone!
                                So from the free pile yesterday I got a Samsung PN51F8500AFXZA that wouldn't turn on. Stand-by light did not illuminate. Found fuse FP801S open, the DC legs of both Bridge Rectifiers shorted and MOSFET QP802S short drain to source. Removed QP802S and short on Bridge Rectifier cleared. Confirm QP802S is short drain to source. No short found on QP804S.
                                Control IC ICP801S is TI SPC1012T.
                                Questions:
                                Is there a way to test ICP801S with a multimeter for short/failure?
                                Neither DigiKey or Mouser stock SPC1012T....
                                05-12-2021, 09:22 AM
