ULN2003 max input voltage?
  • waqqas.qayyum1
    • Feb 2017
    • 21
    • Qatar
    Re: ULN2003 max input voltage?
    Sir the way I explained, I made the circuit like that. I removed all the board relays and connected external relays. I gave Neutral and Phase input to board. Before the board the board was getting R N B N Y N because the heating elements were getting current pass through the relays contacts. so i removed the relays and provided only N and Phase to the board. When i turn on the circuit it works normally but when i connect controller to the board the neutral fuse blows each time i connect the controller. I dont know what is the issue here.
    • waqqas.qayyum1
      • Feb 2017
      • 21
      • Qatar
      I need to provide R Y B to board. I think no need. board only need R phase for its controller electronics part and neutral. but 100mA fuse is blowing again and again after i connect room controlled device. Before room controlled device it is ok. I dont know what to do.
        LM358 LM358S-13 Datasheet
        The LM358 LM358S-13 consists of two independent, high gain, internally frequency compensated operational amplifiers which were designed specifically to operate from a single power supply over a wide range of voltages. Operation from split power supplies is also possible and the low power supply current drain is independent of the magnitude of the power supply voltage.
        Application areas include transducer amplifiers, dc gain blocks and all the conventional op amp circuits which now can be more easily implemented in single power supply systems. For example, the LM358 series can be directly...
        10-07-2024, 04:12 AM
      • Dannyx
        Modifying SMPS input voltage range
        by Dannyx
        Good day folks. Long time no see. It's been a while since I've tinkered with any new projects, despite one thinking this would be the perfect time, with the pandemic and the quarantine, people tend to stay indoors....it's not my case anyway: I go to work like normal, but it's here where I'm bored out of my mind with nothing to do, so here's something.
        A while back, I got myself this adjustable load kit form off Ali. I put it together and it works. It's powered by an AC or DC input and I've been running it off a 12v wall adapter on the bench. What good is such a device if it doesn't...
        03-30-2020, 06:45 AM
      • ugamazing
        820-02020 Super Weird Issue: Keyboard Input Character Map "Wrong"?
        by ugamazing
        So, I have a really bizarre issue that I'm struggling to identify the cause of. Working on an 820-02020 board with some bizarre keyboard/input-source character mapping. My suspicion is a possible damaged SPI ROM (U1970), perhaps, but I'm really not sure in this case:
        1. The issue is pretty weird, but when installing MacOS, I noticed my WiFi password did not work. I quickly realized the special characters (!@#$%^& etc) were not mapping correctly.
        2. I noticed the keyboard layout/input-source is defaulting to JAPANESE every single time I restore the board. I am not...
        04-10-2024, 08:06 AM
        Texas Instruments bq24745 bq24745RHDR bq24745RHDT Battery Charger IC for Laptop Computers Datasheet
        The bq24745 bq24745RHDR bq24745RHDT is a high-efficiency, synchronous battery charger with an integrated input-current comparator, offering low component count for space-constrained, multi-chemistry battery-charging applications. The input-current, charge-current, and charge-voltage DACs allow very high regulation accuracies that can be easily programmed by the system power-management microcontroller using the SMBus interface. The bq24745 charges two, three, or four series Li+ cells, and is available in a 28-pin, 5-mm x 5 mm QFN package.
        The bq24745 features dynamic power management...
        10-23-2024, 02:50 AM
      • Fernon@Repair
        Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
        by Fernon@Repair
        i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
        VCCIO voltage ok
        VCCSA Voltage OK
        VCCPLL Voltage OK
        Ram Voltage ok
        RamVTT OK
        VPP 2.5 OK
        But No Core Voltage
        and i want to this vrm ic datasheet or pinout (ISL69269)
        anyone have this ic pinout voltages?...
        06-25-2025, 07:19 AM
