How to update TNM2000 to TNM5000?
  • capwizard
    • Jun 2016
    • 1991
  • andyred
    • Aug 2012
    • 13
    Re: How to update TNM2000 to TNM5000?
    have you managed to do this upgrade in the end?
    • my dodge
      • Dec 2018
      • 18
      • Persia
      is it possible ?؟
      • dkneyle
        Sony KDL-46HX850 Can't upgrade/update firmware
        by dkneyle
        Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
        Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
        09-25-2024, 10:44 PM
      • akwky
        by akwky
        Hi!
        04-14-2025, 01:56 PM
      • TheUser
        Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
        by TheUser
        Hello to everyone ,
        This is my first post here, and i would like to share with you a small story in case you can help me.
        Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
        All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
        I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
        02-10-2024, 02:07 PM
      • lordgeny
        z490-f gaming bricked after bios update
        by lordgeny
        I had to assemble a PC with this Z490-F Gaming motherboard and an i7-1700K CPU. Upon the first boot, the CPU LED was red and flashing. I realized that I needed to update the BIOS. I didn't read the ASUS notice that said, "Before BIOS update, please download Intel ME update tool from ASUS support site, and update ME firmware to Version 14.1.53.1649V1.1 to ensure optimized system settings." I updated the BIOS without doing this, and everything seemed fine until the system performed an Intel ME update and shut down permanently. My attempts to reflash it were unsuccessful. Searching online,...
        11-02-2023, 09:03 AM
      • iMuhtaseb
        A1706 2017 critical update
        by iMuhtaseb
        this board suffered from a bad trackpad and bad keyboard after liquid damage; board was turning on no issues..
        we've replaced the bad trackpad and bad keyboard no issues whatsoever.. during 2nd final checkup we booted to an external macOS and there started the critical update issue; it boots externally but to the internal SSD it shows critical update; tried Wi-Fi tried Ethernet tried Hotspot same thing..
        One weird symptom is it takes too long to power on and show the Apple logo for some reason..
        I've taken a look into the MLB and noticed tiny liquid around Q3100.. its...
        08-13-2024, 08:41 AM
