Replacement heating element too long, trim?
  • caphair
    • Nov 2011
    • 1249
    Ordered some replacement heating elements for my soldering iron. Went to install one and noticed it's longer than the other by a little.
    The instructions are in Chinese so I have no idea what it says. Can it be trimmed? If not will it affect function?
    • 31157
    Re: Replacement heating element too long, trim?
    isnt the element mounted on a spring so it can push in a bit? some are.
    • caphair
      • Nov 2011
      • 1249
      Yeah it's pushed in all the way
        • 31157
        how much did the elements cost btw?
        • caphair
          • Nov 2011
          • 1249
          $5 from china
            • 31157
            each?
            • petehall347
              • Jan 2015
              • 4433
              • United Kingdom
              what iron is it ?
                • 31157
                cheap hakko 907 clone i think.
                • caphair
                  • Nov 2011
                  • 1249
                  It's a no name 852D+
                  • petehall347
                    • Jan 2015
                    • 4433
                    • United Kingdom
                    might be better with all the correct parts ..
                    something like this ...
                    • caphair
                      • Nov 2011
                      • 1249
                      I could only find a US seller that sold entire handle so purchased that but it seemed of lesser quality.
                      Shorter cable, thinner, different feel.
                      Found heating element on eBay in china for original handle so figured I'd get it so can have original feel I was used to but when I soldered it in I ran into that problem
                      • caphair
                        • Nov 2011
                        • 1249
                        I tested it and it seems to work fine. I'm wondering if I alter the little indents on the bottom that seat into the soldering iron PCB if it would be safe to use?
                        See here the top is original and bottom is the replacement which said is for the 852D+ station. I also just noticed the original iron had writing that faded and all I can make out is "907" and the last letter I think was an "A"
                        Should I be looking for a heater element for a 907A instead of the station 852D+?
                        The iron as a whole just looks better quality compared to cheap alternative I got for $7 which was entire assembly but the wires are shorter, cheaper plastic, no labels and I noticed I need to crank the temp up higher than I did with the original.
                        • petehall347
                          • Jan 2015
                          • 4433
                          • United Kingdom
                          look at specs for 907a .
                          • caphair
                            • Nov 2011
                            • 1249
                            This is the exact listing I purchased the heater elements from
                            https://www.ebay.com/itm/161568266487
                            • Agent24
                              I see dead caps
                              • Oct 2007
                              • 5012
                              • New Zealand
                              If you can't find some the right length perhaps http://www.ebay.com/itm/2x-LUKEY-936...-/252254261836 would work. They don't have that mounting part on the end. They work for my TS-1560.
                              -David VanHorn
                              • caphair
                                • Nov 2011
                                • 1249
                                Thanks. My concern is the resistance of the heater and sensor. Would it hurt anything if not exact to original? I can't take a measurement to compare since original is bad
                                • caphair
                                  • Nov 2011
                                  • 1249
                                  Had someone with a 907a iron measure heater resistances for me
                                  Heater - 14.4 ohms
                                  Sensor - 1.0 ohms
                                  My replacements measure
                                  Heater - 14.6 ohms
                                  Sensor - .8 ohms
                                  So close enough. What I ended up doing was trimming the holder slots on the iron PCB so heater sits recessed as needed.
                                  • caphair
                                    • Nov 2011
                                    • 1249
                                    What I'm noticing now is solder is melting at a lower temperature than it was with the old entire iron assembly I had (not original iron that came with the system). I can melt leaded solder with a beveled tip at 155c where with the other one it would have to be set to around 230c. Is something wrong?
                                    • Agent24
                                      I see dead caps
                                      • Oct 2007
                                      • 5012
                                      • New Zealand
                                      There are two types of heating elements for these irons, depending on how accurate your knockoff is compared to a genuine Hakko. One is a standard wire resistive heater with a thermocouple (cheaper) and the other is a ceramic heater with a thermistor (like the genuine one)
                                      If you had the wrong type, I'm not sure exactly what would happen, but the heater either running full power or not at all would be my guess, because a thermocouple outputs a voltage, and the thermistor will change resistance, so you're measuring two completely different properties and a circuit designed to use one will be completely incorrect for reading the other.
                                      If the iron does regulate and you can actually adjust the temperature, but the numbers are 'wrong', then it sounds like you have the right type of heater, but something isn't quite the same as the old one (I suspect cheap Chinese knockoff heaters for cheap irons don't have very tight manufacturing tolerances )
                                      You probably just need to recalibrate the iron. There should be a calibration\adjustment trimpot on your soldering station somewhere. Obviously you will also need a known good thermometer.
                                      -David VanHorn
                                      • caphair
                                        • Nov 2011
                                        • 1249
                                        Yeah I thought maybe it's just fully on or off but if I keep it set to 100c (the lowest setting) solder doesn't melt, it doesn't start to melt till I hit 155c and if I try melting lead free solder it doesn't melt till 200c
                                        So definitely lower than I'm used to. Before I'd have to crank it up higher to just melt solder and really crank it to solder on a PCB. This is with the knock off entire soldering iron assembly. I don't remember the number for original heater that came with the station.
                                        Is a thermometer accurate enough to measure soldering iron temperature? I have an infrared type.
                                        I do like that at lower temps it's hot as it leaves me plenty on the dial to increase if ever need be. Just worried if it'll ruin the station or not.
                                        Don't want to start calibrating inside the station as I'm not even sure which heater is best suited for it lol
                                        • EasyGoing1
                                          The best way to drive a heating element?
                                          by EasyGoing1
                                          I've got this circuit that I've been playing with on a breadboard. I'm not happy with it mainly because the MOSFET gets too hot and generally controlling the temp of the heating element with the Arduino has proven to be a little more cumbersome than I would like.
                                          What I would like to know, is what is the best way to set up a circuit like this? The heating element is just a PCB and its going to be mounted under a 3D-printed enclosure that a lizard will use to warm his belly.
                                          This is the general setup that I have now.
                                          This is what the...
                                          01-25-2023, 11:29 AM
                                        • jm942
                                          Hp Lh482p 5 short 3 long short after cpu vcore mosfet replacement
                                          by jm942
                                          My laptop went dead and after checking ,the main 19 volt power rail was shorted. After some checks i could identify that a high side vcore mosfet was shorted.
                                          I replaced the mosfet and now the white powerled is present , fans start spinning but capslock shows the famous 5 long and 3 short code.
                                          I checked the vcore voltages after replacement and i get for all 1.01 V so means for me that the driver is still working of the replaced shorted mosfet. On the Nvidia i measure around 0.8 V after the mosfets.
                                          I did voltage injection on the cpu with 0.7V and i have a current...
                                          07-11-2024, 05:11 AM
                                        • HectoPascal
                                          Replacement caps ok? (smoothing caps, PSU heating controller)
                                          by HectoPascal
                                          Hallo,
                                          i want to replace two smoothing caps from a heating controller PSU. They are probably 30 years old and it might be time to replace them.
                                          SXE 470uF 63V 105°C (tested: 472uF 0.35Ohm) --> Nichicon VY 105°C - 463uF 0.15Ohm
                                          SXE 470uF 25V 105°C (tested: 422uF 0.63Ohm) --> Samwha K5A 85°C - 446uF 0.10Ohm (or Panasonic RAD FC 470/25 8mm)
                                          I couldn't find anything about 'SXE'. That's the only declaration on the caps. Edit: The top/bottom ident says Nippon CC.
                                          Nichicon should be 'VY' series (linked).
                                          I couldn't find anything about Samwha...
                                          09-06-2023, 08:30 PM
                                        • madfreak
                                          Need help with finding replacement for L6 element model 80L3A-40-HF, MS-16K21 GS73Vr
                                          by madfreak
                                          I will be very grateful if someone will help me to find a replacement for L6 / 80L3A-40-HF element on MSI motherboard
                                          Laptop model : MSI GS73VR
                                          Motherboard model : MS-16K21 rev 2.1
                                          Thank You very much in advance for help
                                          04-26-2023, 10:01 AM
                                        • JayPoorJay
                                          A Central Air Heating Element, A PID and a Sauna
                                          by JayPoorJay
                                          What could go wrong...?
                                          I'm not sure if this is the right sub category or even the right forum but here goes,,,
                                          I'll just dive right in. I want to see if it's possible and what it would take to use a PID Controller (or 2) to run a central air conditioning heater element (the kind that goes into an air handler) and a small blower fan... The application is a DIY Sauna... Am I nuts? Mean, these components could be had for around 100 bucks.
                                          What do I need to be thinking?
                                          Of course I will go to Vevor and order one of their 200$ sauna heaters so I...
                                          01-10-2024, 02:48 PM
