Overheating battery charger
    Re: Overheating battery charger
    Shorted cells in the batteries.
    What DCV do you have on your batteries with load connected? Battery spec? NiCad?
    So the Transistor is dissipating about 3W of power.
    Check the Vdrops on that large white 390 Ohms bias resistor.
    BTW, that power transistor is still tested good?
    • madan1
      • Nov 2016
      • 682
      OK, just got more readings.
      It turns out the charger does not want to start charging even at room temperature - 22-25*C. I had to leave it outside ( ~-10*C ) for some time to get it working.
      Once working steadily I measured 2.5A @10.7-11V.
      I also disassembled the battery and found a temperature fuse in it, but again absolutely no controller.
      I do not know if the battery is bad... but I got the drill on Thursday, back then I partially charged the battery twice ( 20 minutes - test the drill till there is no power - 10 minutes charging ) and left it in the case. Today the drill worked fine for another 10 minutes before the battery died again. Basically what I'm saying is that it looks like the battery holds charge. Visually all battery elements are fine.
      On Tuesday I am getting the new electronic components ( diodes, transistors, caps and resistors ) and will see what happens.
      By the way, that lm317 sounds great! I will dig into it and see if the charger can be modified. By the way I'm already thinking about substituting the graetz with a single-element solution like KBP206G
        What is the batteries Voltage rating?
        Changing the charging method to constant current charging is not going to solve the problem due to bad batteries.
        Batteries look good does not mean it is good electrical.
        So again, what are the batteries spec?
        • madan1
          • Nov 2016
          • 682
          how? where to hook the Vmeter? ( sorry for the stupid question )
          12V 10cells without anything written on them. Visually similar to these https://www.alibaba.com/product-deta...964662007.html
            And the Voltage reading with load is? So it is NiCad more likely and they do shorted out when they go bad.
            Look up NiCad failure mode.
            • madan1
              • Nov 2016
              • 682
              #26
              starting voltage - 7.5V
              free run at max speed - 7V
              loaded (trying to stop the drill with hand) - 3V
              When I got the drill the battery was totally flat, and basically I have never fully charged it.
              • petehall347
                • Jan 2015
                • 4426
                #27
                i am placing a bet on the battery pack ... until you have another pack with same ratings all bets should be called off ..
                i do however find it most strange that it wont power up unless at a cold temp .
                a schematic should help in sorting that part out .
                • madan1
                  • Nov 2016
                  • 682
                  #28
                  I bet that the problem originated from the charging circuit and had already damaged the battery.
                  I just found out that the battery also gets very hot when being charged ( now when the unit is dissembled I was able to check the temperature on each individual component - transformer, pcb and battery without heat transfer from one component to other ).
                  • petehall347
                    • Jan 2015
                    • 4426
                    #29
                    get me a bottle of leffe blond and call it quits
                    • cpt.charlie
                      • Sep 2013
                      • 270
                      • Spain
                      #30
                      Try to charge the battery, once disconnected, measure the voltage of each cell (should be about 1.2V per cell) and while charging check if any cell gets significally hotter than the rest.
                        So you think the battery is good with the reading like that?
                        If you keep on trying to charge that battery you will end up damaging the charger too, it is already damaged trying charge shorted cells..
                        • madan1
                          • Nov 2016
                          • 682
                          #32
                          If you keep on trying to charge that battery you will end up damaging the charger too.
                          Well, the battery was flat when I got the unit. I never managed to fully recharge it due to the heating issue. Except for the voltage readings, the battery does not show any signs of issues ( at least from the user point of view ) - it keeps charge and gives enough juice to power the drill.
                          As I said - I have not had any experience with such kind of equipment and power banks .. some user experience like drilling and sawing with power tools does not count I guess .
                          Right now I really do not care about damaging the charger - I already have decided to replace the components from the power side of the board. Probably my biggest worries are not to blow the battery pack ... and Indeed I still hope that I will be able to use that battery. After all, the battery is the second most expensive thing in this unit after the gearbox.
                          By the way, next week my IR thermometer should arrive, and I will finally be able to measure properly the T of the components
                          p.s. I was able to charge the battery to 10V
                          So now the stanby is 10V
                          the max speed run is 9.5V
                          and when I tried to stop it ( indeed I was not able to stop it because it almost tore my hand ) I got 6V
                            All you have to do is to to check the voltage of each cell to tell you which cell is bad.
                            • madan1
                              • Nov 2016
                              • 682
                              #34
                              I know.. I'll probably get there. Unfortunately I do no have the equipment ( spot welder ) to get the battery back together. I'm still thinking on what will be the best way to dismantle it so that later can be reassembled without welding.
                                You can measure each cell Voltage without removing any links, the batteries are connected in series, simple.
                                • madan1
                                  • Nov 2016
                                  • 682
                                  #36
                                  Damn!
                                  Well... so my brain is just refusing to think outside its usual way
                                  Recently I've been dealing only with single batteries or in parallel, so I've just forgotten that batteries in series exist (facepalm).
                                  Thanks for re-opening my eyes !
                                  • madan1
                                    • Nov 2016
                                    • 682
                                    #37
                                    Aaand I think we have a winner ... at least partial .
                                    So I changed all 10 battery elements ( 2x price I paid for the drill and the shipping ) and now the charging current is 1-1.1A.
                                    I also changed the 4 diodes and the two caps ( I could not find a transistor ).
                                    Now the charger starts charging as soon as the battery is plugged in ( so I guess getting it cool was fooling something on the protection circuit? ).
                                    After 15-20 minutes I get 34*C on the traf, 36*C on the transistor and 60*+ on the diodes ( finally got my IR thermometer ).
                                    I couldn't get rid of the ripple though ( see the attached image ). It is still around 1.5V. I hooked the biggest capacitor I have ( 10 000uF / 50V ) and the ripple was still there ( ~1V ) but with a smoothed profile.
                                    Should I focus on removing that ripple or it is fine for such electronics? Could it kill the new batteries?
                                      Float the scope so you can look at the Base drive signal of that power transistor, more likely it will be pulsing too, I believe it is doing semi-pulse charging.
                                      How big is the ripple between the two legs of that 100uF filter cap?
                                      The scope signal is from between the Batteries terminals, right?
                                      • petehall347
                                        • Jan 2015
                                        • 4426
                                        #39
                                        looks like it pulsing in a positive direction ..this might be normal to keep things cool ..i have never studied charging these batteries .
                                        • madan1
                                          • Nov 2016
                                          • 682
                                          #40
                                          You are right. Here is a scope from the base of the powerTR.
                                          I cannot safely hook the scope to the capacitor ( the croc connectors are too bulgy ), but should there be difference? The first scope image was from the battery terminals.
                                            ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
                                            Highly Integrated Narrow VDC Battery Charger for Notebook Computers
                                            The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
                                            for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
                                            Narrow VDC applications where the system power source is
                                            either the battery pack or the regulated output of the charger.
                                            This makes the max voltage to the system equal to the max
                                            battery voltage instead of the max adapter voltage. Operating
                                            at lower system voltage can improve...
                                            11-05-2024, 04:43 PM
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                            Bauer tool battery pack charging with a HERCULES charger modification
                                            The Bauer power tool battery charger just has to many issues with the charger over heating because I several HERCULES Hercules battery chargers that are 3 amp charge and because they have gone on quite a few times over the years before they came out with the fan cooling battery charger I going to modify one so I can charge Bauer battery packs faster than the crape battery charger that they have
                                            Here is how this modification is going to be done I taking a 1.5 amp hour battery enclosure and gutting it removing the battery cells and replacing some Ryobi 1.5 amp hour battery pack that...
                                            05-06-2023, 12:17 PM
                                            Milwaukee M18 HD12.0 (12 amp hour battery pack) unbalanced failure charger refusing
                                            I have two Milwaukee 12 amp hours battery packs that have an issue with battery cells very unbalanced these are probably over 4 years old and been heavily used in the past but now get occasionally used heavily and when I went to use the grinder tool the battery lost battery battery power very quickly so I decided to open it up and found some battery cells voltage from 3.6 to 4.1 no wonder the battery charger was not fully charging them 3 out of 4 LEDs were on meaning that it was only 75% charged
                                            So I have put them on the battery testing machine to drain each battery cell down to...
                                            09-04-2022, 04:45 PM
                                            Texas Instruments bq24745 bq24745RHDR bq24745RHDT Battery Charger IC for Laptop Computers Datasheet
                                            The bq24745 bq24745RHDR bq24745RHDT is a high-efficiency, synchronous battery charger with an integrated input-current comparator, offering low component count for space-constrained, multi-chemistry battery-charging applications. The input-current, charge-current, and charge-voltage DACs allow very high regulation accuracies that can be easily programmed by the system power-management microcontroller using the SMBus interface. The bq24745 charges two, three, or four series Li+ cells, and is available in a 28-pin, 5-mm x 5 mm QFN package.
                                            The bq24745 features dynamic power management...
                                            10-23-2024, 02:50 AM
