Ceramic Tip Tweezer?
  • capwizard
    • Jun 2016
    • 1991
    Any suggestion on Ceramic Tip Tweezers.
    I love this:
    TU-12C 5" Non-magnetic Fine Sharp Straight Tweezers Repair Tool Stainless Steel Precision Tweezers Tools
  • chth96
    by chth96
    03-09-2024, 10:03 PM
  • Laelster
    ASRock 9070XT Steel Legend Schematic Request
    by Laelster
    Currently working on my ASRock 9070xt Steel Legend, and would greatly appreciate a schematic for it!
    09-24-2025, 03:31 PM
  • nolaryie
    BIOS .bin file for ASRock B450M Steel Legend
    by nolaryie
    Hi, I’m looking for a clean, working BIOS .bin dump (16MB) for the ASRock B450M Steel Legend motherboard.
    I’ve already tried flashing the official ASRock ROM file via CH341A, but it won’t post — I believe the capsule format is incompatible.
    Any BIOS version that supports Ryzen 5 2600 is fine (e.g., P2.30–P3.60).
    If anyone has a working board and can dump the BIOS using CH341A or flashrom, I would really appreciate your help.
    Thank you!
    08-06-2025, 12:01 PM
  • spleenharvester
    Ceramic capacitors/resistors - do suppliers matter?
    by spleenharvester
    I want to buy one of those SMD component books so I don't have to spend as much time searching my scrap boards for what I need, specifically ceramic caps and resistors as they seem to be what I spend most of my time replacing. But the only ones I can find are no name brands. Does manufacturer matter as much for SMD parts as it does with electrolytics or is the generic stuff likely to be fine?
    05-01-2025, 05:34 PM
  • MarcB7
    Asrock B450m Steel Legends Schematic
    by MarcB7
    I need of Asrock B450m Steel Legends schematic motherboard, i thank you who can make it available to me!
    04-26-2025, 09:36 PM
