changing Direct-Lit LEDs take too long.
  • capwizard
    • Jun 2016
    • 1991
    Re: changing Direct-Lit LEDs take too long.
    my pal, "use a SCR driver controller to give you fine adjustment control" that's why, i use light dimmer, inside has A TRIAC.
    "you need a mil-second timer" just use your hand to do it quickly!
    • Pipolups
      Corsair K70 LUX RGB dying LEDs
      by Pipolups
      Hi there !
      I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
      Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
      10-08-2024, 11:58 AM
    • howardc64
      by howardc64
      Problem
      08-04-2024, 10:36 PM
    • THE GTC
      Insignia NS-37D20SNA14 intermittent LEDs
      by THE GTC
      So I use this TV daily as a second monitor for my PC or my Playstation - at one point a few months back I tried to fix the problem - but in the process, I figured out something that works so I haven't posted this for awhile. It is an annoying trick to have to do though, so I decided to post about it to see if anyone could spot what's wrong. It baffles me because it works on it's own half the time.
      When I first got this TV, I was told it wouldn't turn on, and of course I did the flashlight test, and the image was there. Also, the red LED on the front indicated that it had power (it...
      11-03-2020, 02:40 AM
    • pni
      Backlight panel diffuser melt by backlight leds broken
      by pni
      Hi guys, I changed my backlight to a 5g in Samsung but the broken leds burned the thick plastic panel . I give the photo. Do you think if I try to rotate the panel, with the botton on the top I have a good image? Becacause now how u can see, on the light color I sse the leds because of the burned on the plastic diffuser....
      10-12-2025, 12:08 AM
    • edugimeno
      Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
      by edugimeno
      Hi There!
      I'm trying to help my friend who owns a restaurant be just bought.
      He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
      It's stuck using, I guess, the 2 sided tape that comes with the strip
      The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
      09-05-2024, 09:34 AM
