Does anyone have experience with 3D printer?
3D printer ?
by re-atariHello all, as the title says, I'm very much in need of a valid firmware dump of a Anycubic Photon 5.5 3D resin printer. It's stored in a Winbond 25Q32, so it's 4Mbyte.
Here's a little background for my request. A few weeks ago I bought this 3D printer from a guy who had moved on to a PLA printer. I got it at a vey reasonable price, as it was in a defective state. The seller told me that he had experienced a power failure during a firmware upgrade, after which the printer appeared to be dead. He thought the firmware was corrupted in such a way that the printer was now bricked. As he... -
by Curious808SOLVED. I removed the printer in settings, replugged and let it reinstall and it worked this time.
Brother HL-2140 laser printer
Windows 10
Attempt to print and immediately get a Windows pop-up saying "Error printing". The document appears in the printer queue window with Status "Error-printing".
Turned off printer. Unplugged, waited, replugged. Ran the Windows troubleshooter. Removed and reinserted toner cartridge. Checked for paper jam. No printer error lights. Reinstalled driver. Restarted the Spooler service. Rebooted...06-22-2023, 11:11 PM -
by ArtefilHi,
One of the partner I'm mostly working with, brought his Officejet 8012e, facing a problem I'm failing finding a solution.
On the Officejet 8012e, there's only one USB connector on the back, for connecting the printer to a computer.
The screen displays the following message :
"a problem has occured with one of the printer's critical system files. A printer update will be installed to fix this problem"
But even if the printer is connected through wifi to the network, nothings happen, and the printer stays idle for days.
Have you ever...09-28-2023, 05:11 PM -
by прямоHi all,
a friend gave me this printer because it's no longer working.
It powers on, but won't do a self-test print and when connected via USB to Windows, Device Manager says No Printer Attached under USB Hubs tree.
The red light doesn't blink either with no paper inside.
I think the firmware maybe corrupted. If someone has a similar printer and can provide a firmware dump, I really appreciate it.
Printer model: Panda PRJ-58U
Flash memory: Boyamicro BY25D16ASSIG4 Photos -
by shamsudeenEpson M3170 Monochrome inkjet printer adjustment program tool.
Hi, i want to reset a epson reset program tool needed to reset the EPSON M3170 PRINTER's Maintenance box,
anyone having it, please share
Thank you - Loading...
