Help with USB bluetooth external antenna project..
  • Blacktek
    • Nov 2014
    • 250
    So i have this BT USB dongle and i need it to cover a wider area, The question that i have is WHERE DO I SOLDER the middle middle wire..i know that the outer layer goes to ground but I believe i have to bypass a few caps or resistors to connect my new omni directional antenna. I have photos of the device and The SChematic for the IC CHIP.
  • capwizard
    • Jun 2016
    • 1991
    Re: Help with USB bluetooth external antenna project..
    My friend made a salad bowl antenna, he has been used city wifi for free about 2 years.
    Wifi antenna comparison Which directional type ?
    http://users.picknowl.com.au/~gloaming_agnet/ant4.html
    Two quicky directional wifi antennas
    http://www.instructables.com/id/Two-...-bowl-antenna/
    • Blacktek
      • Nov 2014
      • 250
      AWESOME i'll give that a try... I actually have a 16dbi onmi directional antenna..i read somewhere that some of the component in the antenna circuitry makes it differentiate between diapole and omnidirectional..something like that..but I'll give this a try. thankx a lot.
      • capwizard
        • Jun 2016
        • 1991
        Can't wait to see the result. PL. Giving a Feedback.
          • 30985
          keep in mind, just because you can see "them" does not mean they can see you.
          they have original antenna's
          • capwizard
            • Jun 2016
            • 1991
            Sti Will this work, surf the web invisibly.
            How (and why) to surf the web in secret.
            http://www.pcworld.com/article/20135...in-secret.html
              • 30985
              the only way to surf in secret is to hack someone elses wifi using a virgin mac address and Linux.
              and soon as you go anywhere that needs a login you can be spotted.
              • Blacktek
                • Nov 2014
                • 250
                I dont think it worked. can't get away more than 50 feet away from this bluetooth with the antenna soldered as suggested. i even set different tx power/calibrated power on devices's setting.
                • Blacktek
                  • Nov 2014
                  • 250
                  Any other suggestions??
                  • cpt.charlie
                    • Sep 2013
                    • 270
                    • Spain
                    Install antenas in both devices.
                    • capwizard
                      • Jun 2016
                      • 1991
                      Increase and extend the range of a USB Bluetooth dongle!
                      http://www.instructables.com/id/Incr...-now-attached/
                      Increase your bluetooth and other devices range.mp4
                      https://www.youtube.com/watch?v=wCW4PcG-hRc
                      If 30m till not enough, one way to extend to 1000ft , I could tell you but I'd have to kill you.
                      pic2: connect wire go as far as you what , to you next, next door neighbor.
                      pic3: with one HV caps connect to antenna, other side to the AC plug, use your whole house electrical wires as antenna.
                      PS: Danger!!!! on your own responsibility
                        • 30985
                        what type of cable was it?
                        at 2.4GHz it matters!
