PCB protecter? Waterproofing? How to service?
  • scampo77
    • Dec 2010
    • 233
    I have a circuit board that seems to be cast in nylon? Rubber? Polyester? It's a controller for a transmission. I have seen this in controllers for aviation and generators, more industrial applications and it's usually pretty hard kind of like plastic. For the first time, this compound seems gummy, all most like rubber I can pick at it and slowly remove pieces. Does anyone know if there is a chemical or heat process to remove this stuff? I need to service this board.
    Any idea how to remove? or re apply this stuff? Or any idea where I can find out more about it?
    • 31262
    Re: PCB protecter? Waterproofing? How to service?
    depends on what it is.
    if it's rubber then you need to scrape it,
    if it's plastic then you can usually remove it with white spirit,
    if it's epoxy then it's a bitch to remove and you need to use the end of the soldering iron.
    • scampo77
      • Dec 2010
      • 233
      How can I definitively determine what I have? Is there a wiki page somewhere? Or photos? Or a test I can perform?
        • 31262
        see how it reacts to heat from a soldering iron.
        epoxy will soften slightly,
        plastics will melt & burn,
        rubber will do nothing really.
          LCD LED TV Service Menu Codes
          TCL LED TV Service Menu Code
          LG LED TV Service Menu Code
          10-31-2024, 03:58 AM
        • howardc64
          by howardc64
          Problem
          08-04-2024, 10:36 PM
        • AustinCER
          Dell XPS 8940 | Manufacturing Mode? | No Service Tag
          by AustinCER
          Hello, I currently have a Dell XPS 8940 in our office for repair.
          Service Tag: HG1Y673
          The most recent BIOS is pictured below -- being available as an .exe on Dell website.
          Needed a new motherboard due to power surge. The motherboard replacement was installed and upon power up it was booting to a display message - Manufacturing Mode Active -
          Have not dealt with this issue before or what the proper steps are. I booted to the BIOS and manually entered the Service Tag, but upon each reboot -- the service tag is wiped and shows the Manufacturing Mode display message,...
          07-15-2025, 05:28 PM
        • C.Levan
          Help Learning How to Remove Dell Service Tags
          by C.Levan
          I work in a second hand PC shop and we primarily get our stock from the government and businesses which means sometimes we get BIOS locked devices coming through, a colleague of mine found a way to remove the service tag off a Dell Optiplex 7080 and using that .bin put it on another 7080 which basically allows us to re-use this .bin on problematic 7080 models. My end goal is to have a catalog of .bin files in-case one fails a BIOS update or has some other BIOS problem.
          06-09-2023, 07:54 PM
          Acer Aspire A517-52-31EP + Extended Service Plans Notebook 5 Specification for Upgrade or Repair
          This specification for the Acer Aspire A517-52-31EP + Extended Service Plans Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A517-52-31EP + Extended Service Plans boardview and A517-52-31EP + Extended Service Plans schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
          09-07-2024, 02:20 AM
