rebuilding USB circle
  • dlshad96
    • Apr 2016
    • 39
    • Us
    Hello mates
    i know its not easy but i am tired to Make my usb ports back to work.
    the power 5v working but the data not
    updated bios , using heat gun for super io and south chipset, data chip
    replace sio chip.
    was working well.
    nothing make my 3 usb ports back to work no data
    so i have an idea i want building new usb circle . inside the laptop what i need to Success please , . using same usb ports adding new chips electronic small parts
    i dont want using express card it disconnecting sometimes
    anyone have ideas
    thank you in advance
    • 31071
    Re: rebuilding USB circle
    laptop make & model?
    • samanthban
      • Feb 2014
      • 253
      • Sri lanka
      may be your data drops some where in the middle .
      sigpic
      • dlshad96
        • Apr 2016
        • 39
        • Us
        Fujitsu A512, .
        the led of power working ,(mouse external hdd), but not working , the all 3 ports have 5v. nothing wrong with the power,
        • dlshad96
          • Apr 2016
          • 39
          • Us
          Fujitsu A512
            • 31071
            there is a small chip between the usb ports and main chip that acts as a filter to protect the chip from static or damaged usb connectors.
            • dlshad96
              • Apr 2016
              • 39
              • Us
              Thnak you for replay
              many small chips around 5 , 4pins 8pins 24pins 68pins
                • 31071
                6 or 8pin usually
                • petehall347
                  lithium iron battery pack rebuilding kit
                  by petehall347
                  i am now being pushed for a list of the best tools for the right price to allow me to rebuild 80v battery packs and the like .someone i do work for has threatened to buy me the kit . so things like automatic cell testing kit with many bays . tab welder and suchlike to enable me to get right on it . and supplies that will be needed like new tabs and single cells .
                  05-17-2024, 05:09 PM
                • nobbnobb1
                  General Question - Rebuilding Lithium Ion Battery Packs on Mobile Devices/Laptop
                  by nobbnobb1
                  Hi guys,
                  Just a general question. Usually on mobile devices/laptops the battery pack consists of lithium ion cells with their +/- tabs welded onto the controller IC. I'm wondering, in general if it can be assumed that one can find a replacement lithium ion cell, is it ok to simply re-use the old controller IC in an attempt to re-build the pack? Or is that controller somehow paired to the cells from the factory?
                  From my experience it sometimes seems to be hit or miss. Not sure if this is true, but sometimes it's almost as if the controller IC will go to a failsafe...
                  12-25-2022, 01:02 PM
                • RukyCon
                  Rebuilding an Li-Ion Tool Battery with Li-Po Pouch Cells (Ryobi P189)
                  by RukyCon
                  So awhile ago, i picked up a used Ryobi drill from a thrift store, so I could give it to my father (so that he could have something that was slightly better than his Drill Master drill with a broken battery mount), but with that drill came a dead P189 1.5 Ah battery, since my charger refused to charge it, i decided to take it apart, I found that all 5 of the 18650 cells in the battery were discharged to less than 0.5v, so knowing that the cells in it were pretty dead, i ended up setting it aside, unsure of whether i would repair it.
                  Anyway, about a week ago, i dug up the battery...
                  02-09-2022, 08:58 PM
                • laadya
                  Fujitsu Lifebook A557 power-cycling
                  by laadya
                  Unfortunately, the A555 schematics does not help when it comes to issues I am dealing with in my FSC Lifebook A557 laptop.
                  The symptoms:
                  1. The power supply can turn the laptop on, it can charge the battery fully
                  2. The laptop is power cycling – it flashes the status LEDs and can hold the wi-fi + power-on LEDs on, it spins the fan for approx. 5 secs. After 20-30 secs it turns off and immediately on again with the same pattern
                  3. When “running”, I also found out that 2 of the 3 USB3 ports on the right side of the laptop do not work - the third one does...
                  05-15-2023, 01:51 PM
                • csberti03
                  645 G10 with some liquid damage around the bios chip
                  by csberti03
                  Hi!
                  I could use some help.
                  I have a 645 G10 with some liquid damage around the bios chip.
                  After cleaning, the laptop does the same as in RHS93-s reply above.
                  1. F5 key LED lights up Orange
                  2. Power LED flashes White/Orange
                  3. Machine turns on and off like this a few times
                  4. Finally the F5 key LED turns off and the Power LED stays white
                  5. If I press power button in such condition I get 7 flashes on the CapsLock LED
                  6. Laptop reacts to the power button: if I press it long enough the machine turns off...
                  08-28-2024, 04:17 PM
