Electrolytics: rated capacitance obtained only at rated working voltage?
  • japlytic
    • Oct 2005
    • 2086
    In page 423 of Television and Radio Repairing (John Markus), it says "with electrolytics, rated capacitance is obtained only at rated working voltage".
    Is that true?
  • Harvey
    • Apr 2007
    • 264
    Re: Electrolytics: rated capacitance obtained only at rated working voltage?
    Up to a point yes. That's why it always used to be recommended to run a electrolytic at least at 25% of its rated voltage, otherwise the layer of aluminum oxide breaks down and the capacitance is reduced and/or the capacitor fails.
    For the same reason electrolytics have a limited shelf life, leave them sitting around in your cupboard for years and they tend to just give up as soon as you try them.
    Exactly how bad 'modern' electrolytics are in that respect its hard to say, as the chemicals used have changed and developed over time, but the problems do still exist.
    • Perry Babin
      Operating caps well below rated voltage
      by Perry Babin
      I think this has been answered but I couldn't find the thread.
      Someone asked me if it would harm a capacitor (10F [not a typo], 24v) if it was operated on nothing more than 12v.
      So, I ask... Does it change any of the capacitor's characteristics/parameters/? in any way if it is never operated near rated voltage?
      If operated for years at 1/2 rated voltage, does it accept full rated voltage like it would if it had always been operated at the higher voltage?
      Or would it require reforming?
      05-23-2024, 05:43 PM
    • UserXP
      Transformer producing higher voltage than rated
      by UserXP
      Hello, people.
      i am not sure if this question belongs to this forum section exactly, but since there already are some queries here about power transformer, let's give it a try.
      So, I have this old but very well preserved Casio SA-20 ToneBank keyboard. It is powered either by five 1.5V AA bateries, or via a power adapter, so its operating voltage is 7.5V. The power adapter input jack also states 7.5V DC In. Now, since this keyboard was never supplied with a PT, but actually came with test bateries included, I decided to try to buy an adapter for it. I know I could have just gone...
      09-02-2025, 12:42 AM
    • Antonynl
      Capacitance and voltage of tantalum?
      by Antonynl
      I have a tantalum capacitors with indicators EB 21 that measures only 22pF. See attached picture.
      Since this is a windmeter that is normally in a very high mast I would like to get the correct replacement capacitor.
      Is there somebody that can tell me what the capacitance and voltage of this capacitor are?
      I don't feel confident that I can figure this out myself after searching around
      Cheers!!
      04-14-2024, 03:19 PM
    • Fernon@Repair
      Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
      by Fernon@Repair
      i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
      VCCIO voltage ok
      VCCSA Voltage OK
      VCCPLL Voltage OK
      Ram Voltage ok
      RamVTT OK
      VPP 2.5 OK
      But No Core Voltage
      and i want to this vrm ic datasheet or pinout (ISL69269)
      anyone have this ic pinout voltages?...
      06-25-2025, 07:19 AM
      Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
      I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
      The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
      Now...
      06-09-2024, 10:57 AM
