Chip identification
  • oxonater
    • Oct 2012
    • 77
    Chip identification
    Hi I need help identifying a chip on a cq58b motherboard the markings are as follows:-
    3242V 2n503 MXA
    I maybe able to post a picture any help would be greatly appreciated.
    Thanx Oxy
    • 31131
    Re: Chip identification
    you better post a foto, because you dont even say how many pins it has!
    • GUARBorg
      • Jul 2015
      • 6
      Is the IC round? Does this package match what you're after? http://www.microsemi.com/packaging-i...tails?pid=5535
      If so, 2N503 pulls up http://alltransistors.com/transistor...ransistor=4431
      Please double check though because I haven't.
      • oxonater
        • Oct 2012
        • 77
        Hi many thanks for the replies, the chip is rectangular and appears to have 7 pins each side and 1 pin at each of the smaller sides.
        Thanks for the links, unfortunately the chips are different which is a shame.
        Finding it very difficult to find a replacement, the cq58 came into contact with juice the user turned it off,but after about half/hour switched laptop back on and wondered why it wouldn't power
        Anyways here is a couple of pics please excuse the quality I do not own a high end SLR LOL
        Just wondered if I clean the chip in question give it a bit of fresh solder maybe a miracle will happen.
        Also noted a couple of small caps that look a wee bit charred
        Thanks again peops
          • 31131
          i would desolder it, clean the board & chip and put it back down.
          if you dont have the tools, try cleaning it with alcahol and a toothbrush - make sure you get between the pins.
          • oxonater
            • Oct 2012
            • 77
            Yeah was thinking may give that a go, looks like it may of burned though.
            I have cleaned with alcohol and toothbrush already thanks
            • fzabkar
              • Mar 2009
              • 772
              Tell us the markings on the other ICs. In this way we might be able to determine which, if any, of the markings are YWW or YYWW (Year/Week) date codes.
              For example, "503" might suggest week 03 of 2005 or 2015.
              The markings on the crystal at YS3 might also give us a clue. The fact that the chip requires a crystal would suggest that it may be a processor/controller of some kind, or perhaps a clock generator?
              • oxonater
                • Oct 2012
                • 77
                Hi ok so the markings on YS3 are H252F
                The other IC to the right labelled U1101 has these markings:-
                s51211
                TI 25I
                C6Y9
                many thanks
                • fzabkar
                  • Mar 2009
                  • 772
                  The TI part is a TPS51211. Unfortunately I don't recognise the date code format, nor is the datasheet of any help. :-(
                  https://cdn.badcaps-static.com/pdfs/...972c11692f.pdf
                  I'm not sure about the crystal, but 252 would suggest 2500, so I would think that means 2.5MHz. That's an odd value, though. Maybe it's 25MHz?
                  Perhaps other chips might have more recognisable markings?
                  • oxonater
                    • Oct 2012
                    • 77
                    Hi again
                    Thank you for your input, on visual inspection of the cq58 motherboard it appears that a couple of the ceramic caps in the 3rd pic seem to be burnt, and there is a couple of others also appear tarnished will post a pic of these.
                    And other than these the only other issue I can see is with the IC that has these markings:-
                    3242V
                    2n503 MXA
                    What I will do as a first port of call is remove and clean area were said IC is attached to board and see how this goes.
                    Proving to be a pain in the padded to find replacement chips for this.
                    Thanks All
                    • fzabkar
                      • Mar 2009
                      • 772
                      There was a recent thread where a user claimed to have the CQ58 circuit diagrams. Perhaps you could check that out.
                      • oxonater
                        • Oct 2012
                        • 77
                        Hi
                        Ok so have removed the problematic 3242V 2n503 MXA chip, it appears to have lost a pin were the liquid must of come in to contact.
                        • oxonater
                          • Oct 2012
                          • 77
                          I put the laptop together to see how it behaved, well it powers on to a blank screen both external connection or built in display also laptop will shut down soon after switching on.
                          Now I know that a blank screen is associated with a graphics problem, but just wondering now if the missing chip has something may provide a circuit with the gpu.
                          Thanx
