About loewe individual 32 s
  • hispeck
    • Aug 2015
    • 258
    • nigeria
    This tv input is 220 to 240v power, but in my place we hardly have this type of voltage we only have 200v sometime or less, if i don't use stabilizer it wont work, i have them two one work but one don't, even with stabilizer only if the voltage is very full before it can work, please anyone with a useful tips on how to handle this?
    hispeck
  • joshnz
    • Feb 2011
    • 969
    • New Zealand
    Re: About loewe individual 32 s
    would have to redesign the power supply.
    or find one that is compatible that has pfc that goes down to 90 volts.
    My pc
    CPU : AMD PHENOM II x4 @ 3.5Ghz
    MB : ASUS M4A89TD PRO USB3
    RAM : Kingston ValueRAM 16gb DDR3
    PSU : Cooler Master 850W Silent Pro
    GPU : ATI Radeon HD 6850
      hispeck
      If one work with AC Voltage regulator but another one does not, I would inspect the Voltages on that non-working unit.
      How about some good clear pictures of the TV showing all the boards?
      • edugimeno
        About replacing individual LEDS on BL strips
        by edugimeno
        Hi There!
        Having fixed 5-6 TV sets by replacing full LED strips, and having watched other people fix that by replacing just one LED in the strip, my question now is what should I consider before doing so.
        At this time I have some old strips removed from TV's with all but one LED working. Are there different voltage/current LED on different strips? Are 99% of them just the same and interchangeable?
        How do you find which specific model is needed for each strip? When I check if a LED is OK by attaching the multimeter leads to the individual led pads on the strips I...
        11-07-2022, 11:12 AM
      • Mercbaz
        Loewe Art 40 model 54457 W80 service manual
        by Mercbaz
        just acquired a rather stylish Loewe Art 40 model 54457 W80 with chasis SL310 which I think has a mainboard fault. Does anyone on here have a service manual/schematics for such please ???
        09-24-2023, 03:27 PM
      • Dannyx
        Voltage stabilizer trips RCD ?
        by Dannyx
        Good day folks. A friend of mine asked me to have a look at this fat servo-driven voltage stabilizer. It claims to be 10kVa ! He says it works but it sometimes trips the breaker at the panel (not its own at the front there), despite having a very light load connected to it, or none at all. Unfortunately, I don't know for sure whether it's an RCD that trips here or a regular dumb MCB. Either of them could cause the issue if they weren't sized according and they'd get tripped by the high inrush current - this was my initial hunch, but the thing is he says it doesn't happen at startup, but rather...
        10-20-2021, 11:15 AM
      • nubinator
        how can i test individual leds without tester
        by nubinator
        Hello I have TCL 65S4 and it has no backlight, seems common problem on this tv to have bad LED's. I have no tester though I thought I could just test each LED with 2xAA batteries for 3v but it doesnt light up at all?
        I saw a vid with LED tester on this TV and it had 130v for 1 good line which is 24 LEDs does that mean it needs around 5.5v per LED?
        10-25-2022, 11:05 PM
      • zen
        Connect40 Loewe TV manual / advice please
        by zen
        Hi all
        This set seems to power up , with LED at front changing to GREEN , but no picture , or backlight , plus cannot set TV back to standby .
        Suspecting main board issue .
        Powered the backlights independently & they light up ok .
        Disconnected HDD & powered , with same results .
        Checked supplies at all the buck regulator outputs on main board & again seem ok .
        Anyone have experience working on this model ....
        07-22-2022, 06:32 AM
