Can someone explain this circuit to me?
  • caphair
    • Nov 2011
    • 1249
    This is the backlight circuit for an iPhone 6
    I'm confused at the line out (D1) because the ic says OVP doesn't this mean over voltage protection?
    Then below it D3 and D2 (LED1, LED2) wouldn't these be the lines out for the backlight or are these for limiting the brightness?
  • gabiz_ro
    • Mar 2011
    • 167
    • Romania
    Re: Can someone explain this circuit to me?
    D1 is not output
    Is indeed OVP.
    Like other IC,OVP function could be tied to output or to some divider circuit from output.
    Pulses are rectified by D1501.
    In case you don't need OVP then don't connect,but I don't have datashhet for this IC to check what conditions are required on OVP pin.
    D2 and D3 are ILED and are some kind of adjustable constant current.
    IC boost voltage from battery.OVP prevent over voltage.Current flow from diode cathode through some number of LED's,one string,to ILED1 or 2 here current is controlled via software to obtain variable backlight level.
    Hope my english was good enough so you can understand what I write.
    • caphair
      • Nov 2011
      • 1249
      Thank you. From the schematic D1 goes to the backlight connector of the screen.
      So you're saying even though it is OVP it can still be the output that drives the backlights?
      • gabiz_ro
        • Mar 2011
        • 167
        • Romania
        No.
        Real output is on cathode of diode D1501.
        OVP is tied to this to monitor output voltage.
        OVP is input for IC.
        Since is same track from cathode to cap's and to OVP,is same track,or traceline,to backlight connector.
        • caphair
          • Nov 2011
          • 1249
          Originally posted by gabiz_ro
          No.
          Ah ok. Makes sense now. Thanks. Do you know the purpose of the other pins? (Lower half of the ic)
          • gabiz_ro
            • Mar 2011
            • 167
            • Romania
            A1,A2 are SCL and SDA.
            I2C bus line to main CPU.
            C1 is VIO SPI. 1.8V power for IO SPI and maybe I2C
            B1 is backlight enable.But seems to be enabled by Vcc of SDRAM,so always enabled if powered iphone,0 value or off state may be controlled by software.
            B2 and C2 are second bus line,SPI ones.
            Seems connected to CPU-PMU (proccesor-power management unit)
            Without datasheet don't know why is used both I2C and SPI bus lines.
            • retiredcaps
              • Apr 2010
              • 9271
              Have no idea since I have no interest in iphones, but saw this youtube video just posted
              iPhone 6 backlight problems---how to rebuild the backlight circuit and why you have to
              https://www.youtube.com/watch?v=8I9MlOkpR3k
              --- begin sig file ---
              --- end sig file ---
                Read the spec sheet to see the pins function, similar to LM3533.
                LED backlights controller with Boost Converter (L1503, D1501, IC) and constant current controller to maintain constant current through the LEDs.
                • caphair
                  • Nov 2011
                  • 1249
                  Wow did you read the comments with the member "mrsemifixit"? I have to agree with what he's saying. She doesn't seem to know much about how a circuit could fail in some instances. She does that for a living? Pretty surprising
                  • caphair
                    • Nov 2011
                    • 1249
                    Thanks! I couldn't find the spec sheet when I searched?
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      I, as a rule, never read youtube comments. I hate the columnar reading format. I also found in the past, people don't use any resemblance of English, grammar, punctuation, etc. Thus, I don't bother.
                      I have watched a few of her videos and she is one smart woman so unless I read the comments, I will give her the benefit of the doubt.
                      There are people who list themselves, voluntarily, as professionals here on the forum that post very dubious advice and show they lack fundamental skills. I could point out a few threads, but I'm not that type of person and I have better things to do with my time.
                      • caphair
                        • Nov 2011
                        • 1249
                        I agree but I thought it was an interesting exchange as she kept defending her claim that diodes don't fail shorted. Here's the last two comments
                        • Alimash
                          op amp circuit function?
                          by Alimash
                          I am repairing a ups which doesn't turn on ,it has the following ICs:
                          SG3525 used to drive inverter mosfets.
                          couple of uc3483, one for the power supply and another to drive a big mosfet at the output stage(i think the technique is called boost)
                          A LM358 and TL074 for control mechanism and of course the uController.
                          The SG3525 is shutting down every time the ups is turned on.
                          I want your help to know the function of LM358 and TL074 in the system.
                          I reverse engineered the LM358 circuit and i think that one of the block(A) is used for battery level...
                          07-31-2025, 07:45 AM
                        • Astonished
                          Fixing the Charge Circuit of the Batteries of the DC Motor
                          by Astonished
                          Hi friends of electronics
                          What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
                          The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
                          Please help me fix this circuit.
                          (the datasheet of the IC: https://pdf.datasheet.live/28...
                          01-28-2025, 06:24 AM
                        • rddube
                          Lenovo L490 Ram voltage circuit malfunction
                          by rddube
                          Hello friends,
                          Looking for some guidance here. The RAM voltage circuit on this motherboard keeps burning out PU301 which is a RT8231AGQW. Copy of the board with the burnt chip attached with some voltage measurements and copy of the schematics also included.
                          I think I've checked almost every component in the circuit, but when I change the RT8231, the laptop starts I have 1.2V on the inductor for about 10 seconds and then the RT8231 goes south and no more voltage on the inductor. All other voltages on the laptop are good, this is the only one conking out for a reason I...
                          07-15-2025, 04:41 PM
                        • Tarot Superstars
                          Short Circuit tester
                          by Tarot Superstars
                          Hello.
                          I have seen a short circuit tester made with 3 * 9V batteries, a voltage limiter component and a resistor connected to the probes of a multimeter.
                          The theory is that the meter becomes sensitive enough to read very low resistances and the lowest resistance to ground on a circuit is likely to be a short circuit in that area.
                          Link
                          The Amazing $1 Short Finder Upgraded! Convert ... - YouTube
                          https://www.youtube.com/watch?v=0eixDdCpiO4
                          My multimeter isn't normally sensitive to very small resistance, but when I put a 1 mega ohm resistor...
                          09-25-2023, 09:11 AM
                        • M1NEBLANK SHOW
                          MSI B250 Gaming M3 Short circuit in CPU power supply circuit
                          by M1NEBLANK SHOW
                          Hello. MSI B250 Gaming M3 board, short-circuit on the power supply. Found a problematic mosfet VQ1
                          (N-PK616BA_PDFN8-HF) soldered it out - short circuit is gone. I replaced VQ1 + VQ5 (N-PK632BA_PDFN8-HF). VQ1 was replaced with PK618. After starting attempt VQ1 is lit again. What can be the problem? In the driver?
                          Schematic and Boardview here
                          04-04-2025, 03:57 PM
