Voltage regulation with Arduino
+ More Options
Posts
  • SaleB
    • Oct 2012
    • 19
    • SER
    I have yet again come with another problem and willingness to learn.
    There is a custom made computer case that will function headless (without the motherboard), it's rather a box for 12x hard drives (at a later date extendable to 24), psu, 8x fans and one backplate. In a development stage I have come to the problem of active fan speed control. Computer fan typically uses <200mA@12V.
    I intended to use Arduino with a few temperature sensors and a control circuit for fan speed another circuit to collect fan speed data. The research on the topic of fan speed control proved to be rather difficult. First idea was to use pwm, but I could not find any simple and reliable solution. Using a serially controlled LDO regulator for each fan seem as an overkill. So, the simplest solution would be to control a series of FETs with analogWrite, but then I do not have enough analog pins on arduino mini pro. There won't be a problem to use more then one arduino, but if there is an elegant and reliable solution that I have not thought about, I would like to know about it.
    Thankful in advance
    • 30952
    Re: Voltage regulation with Arduino
    you cant part-drive a fet.
    use a microcontroller with hardware pwm or write your own code using hardware timers.
    use the pwm output to drive a fet.
    • SaleB
      • Oct 2012
      • 19
      • SER
      Thank you for your answer. I have accidentally found an alternative solution, an IC that would allow me to use PWM control rather then FET's. On the first look it seems like much simpler/better solution. The name of the IC is PCA9685. It uses I2C to communicate with the microcontroller.
      For the other problem of collecting sensor data I have found that 4051/4067 circuits may be usable. A quick question here, is there an alternative to 4051/4067 that would use serial selector input or also I2C for selection rather then 3-4 digital lines?
      It seems much simpler to organize the board if one mux collects temperature data, another speeds and a before mentioned PWM circuit controls the fans.
        • 30952
        you still need fets, that pca chi is 25ma drive - a fan needs upto 300ma
        i dont know why your wasting time muxing sensors, AVR's have 6 or more ADC's on them.
        • mariushm
          • May 2011
          • 3799
          Sigh... microchip microcontrollers are powerful enough to send a pwm signal on that 4th wire of regular fans to adjust the speed.
          But you can be smarter and use ready-made fan controller chips, for example see this 2$ EMC2305 chip Microchip makes which can control up to 5 4-pin fans and since it works on SMBus you can link up to 6 of these in a chain to control up to 30 fans : http://www.microchip.com/wwwproducts/en/EMC2305
          (US) Digikey link: http://www.digikey.com/product-detai...-CT-ND/4490169
          (EU) Farnell : http://uk.farnell.com/microchip/emc2...pwm/dp/2361972
          If you can't order from you country, I'm sure someone could here could order a few for you and mail them to you.
          SMBus is similar to i2c and you can find ready made code to talk to SMBus devices using arduino, so you can just talk to them using Arduino's i2c and connect your arduino to your computer using a rs232/uart to usb adapter.
          Then you just open putty on usb serial port and send commands to your arduino through the rs232 to usb adapter or receive the temperature readings and the rotation speeds of all fans (which you can read from the fan controller chips through smbus)
          You'll find tutorials about arduino and serial online, you'll find tutorials about arduino and temperature sensor chips (See below) like this one for example (didn't watch it skipped through it and sounds good to me) : https://www.youtube.com/watch?v=_fNto4JOu4E
          Arduino also has some adcs so you can also get a bunch of cheap temperature sensor chips that take some voltage (ideally stick with 3.6v or less since the above chip works at 3.6v or less and arduino chips also work at such low voltages) and you can use arduino's internal ADC to take temperature measurements every few seconds and adjust the fans accordingly.
          Here's some example of very basic temperature chips, they have +/- 2c accuracy or better. You shouldn't need more than this accuracy :
          MCP9700 (10mV per C, 500mV at 0C) : http://uk.farnell.com/microchip/mcp9...c70/dp/1332165
          MCP9700 (10mV per C, 500mV at 0C, through hole) : http://uk.farnell.com/microchip/mcp9...-92/dp/1332166
          MCP9701 (19.5mV per C , 400mV at 0C, through hole ) : http://uk.farnell.com/microchip/mcp9...-to/dp/1439483
          LMT89DCKT (+/- 1.5c accuracy , VO = −11.69 mV/°C x T + 1.8663 V ) : http://uk.farnell.com/texas-instrume...deg/dp/2314391
          LMT85DCKT (+/- 0.4C accuracy, V = (-8.20 mV / °C) x T + 1569 mV) : http://uk.farnell.com/texas-instrume...deg/dp/2314387
          etc more to pick from here: http://uk.farnell.com/ic-sensors_temperature-sensors
          Basically glue these to something using double sided thermal paste or some silicone and thermal grease and you have cheap and simple temperature reading
          • Yanleb
            LG 60PK550 Logic Control Board EBR63450301
            by Yanleb
            Hi all, I just want to share the repair of my 60PK550-UA TV set.
            The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
            But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
            All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
            C57: 3.30V
            C61:...
            07-20-2023, 12:38 AM
          • harp
            triac phase control 0-100%
            by harp
            Trying to understand which properties of circuit affect triac phase range, is it possible to control near whole period, or it have some limitations - on net found a couple circuit, that claims almost full control, but in the past I build some simple circuit and remember that it do only half of control over triac?...
            06-02-2024, 09:00 AM
            MPS NB670 NB670GQ Switch Mode Converter for Laptop Computers Datasheet
            The NB670 NB670GQ is a fully integrated high frequency synchronous rectified step-down switch mode converter with 3.3V fixed output voltage. It offers very compact solution to achieve 6A continuous output current and 9A peak output current over a wide input supply range with excellent load and line regulation. The NB670 operates at high efficiency over a wide output current load range. Constant-On-Time (COT) control mode provides fast transient response and eases loop stabilization.
            Under voltage lockout is internally set as 4.65V. An open drain power good signal indicates the output...
            10-23-2024, 03:23 AM
          • tmhobadcap
            Pioneer VSX-522-K remote control not working???
            by tmhobadcap
            I have this receiver for at least 10 years. Usually, we just use the remote for turning on/off and adjusting the volume. Recently, the remote control started not able to turn the receiver on. Later, the volume also could not be adjusted by the remote control.
            At first, I thought that it was the usual problem which can be fixed by cleaning the contacts on the switches and the pcb. I opened the remote and clean it with alcohol. The remote did work again after that. But after one day, it did not work again. I opened it again and clean with alcohol and contact cleaner. Again it worked...
            12-24-2020, 01:44 AM
          • tommy97
            MacBook A1932 & A2337 MDM - Permanent solution?
            by tommy97
            we're getting quite a lot wiped A1932 & A2337 from scrap with MDM (Remote management), we'd like to find permanent solution to remove it without CPU swap as it gets not economical, I found iremove.tools website which offer permanent solution, however if they got shut-down i believe laptops would also get locked? Does anyone have any knowledge about this service & about any other possible method?
            06-18-2025, 02:43 AM
