Questions about motherboard testing
  • Lance Thornton
    • Jan 2005
    • 84
    After reviewing Akor's guide on testing the vrm's, I have a few questions and please forgive my stupidity on this issue. Step 3a says to measure the resistance from the output of the VRM to the load supply pin. Where is the output of the VRM exactly, and how do I judge where it is on any motherboard? I have an Intel D865 PERL and the lights are on, but nobody's home, and I'm trying to figure out the problems. Also, on each FET, there are 3 legs. Long legs are on each side and a shortleg in the middle that is not connected to anything. What is the procedure for testing these? Thanks for the help, I do appreciate it.
    Lance
  • coolday
    • Jul 2008
    • 12
    Re: Questions about motherboard testing
    same for me .... admins please continue the mentioned post
    • byteexp
      • Oct 2006
      • 10
      hi i think its the two legs, test all, if its good, 1 has a 1M reading and the other leg has 0 reading, if both legs (long) are 0 there it is bad vrm.
      that was my case in one of my board, 0 0 replace regulator, and it worke
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        Intel D865 PERL suffered from the defective Nichicon HM and HN series caps.
        Those caps built between 2001 and 2004 had a manufacturing defect.
        Check the date codes on your caps.
        [letter][2 digit year][2 digit week]
        Mann-Made Global Warming.
        - Dr Seuss
        • glovecaps
          by glovecaps
          11-25-2024, 04:23 PM
        • Docus
          Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
          by Docus
          Hi everyone 😀,
          I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
          To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
          Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
          1. I already own the exact same model, but its plastic chassis is badly damaged.
          06-10-2025, 04:24 PM
        • Öğretmen27
          Turning on and testing the power card without the motherboard
          by Öğretmen27
          I want to turn on and test the power card without the motherboard.
          I have 17IPS62 and 172IPS72 power supplies. Are the joins correct in the images below?
          If it is wrong, how should it be?
          Thank you.
          01-05-2025, 02:56 AM
        • Archimedes
          HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
          by Archimedes
          Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
          Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
          Fans are spinning. Blindly could install windows11 and got the device manager...
          07-30-2024, 05:14 PM
          ASUS P5GC-MX motherboard recap
          by momaka
          Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
          This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
          So here is what the motherboard looked like with its original caps:
          CPU VRM area up close…...
          01-27-2021, 11:59 PM
