YD7377 4×10W radio amplifier, how can it output 4×25 W?
    Re: YD7377 4x10W radio amplifier, how can it output 4x25 W?
    "Let's use Behemot's setup here as an example. You have four 2-Ohm speakers, and you are using the IC in single-ended mode to drive each channel. With a 14.4V supply and ignoring voltage drops in the amp IC, the maximum output power is 25.92 Watts RMS per channel into a 2-Ohm speaker"
    Post 17 by fzabkar:
    P = (Vrms x Vrms) / R = (Vpeak x Vpeak / 2) / R
    = (14.4^2 / 2) / 4 = 25.92W
    That's assuming that there is no distortion over the full peak-to-peak voltage swing for a bridged configuration.
    So Per formula post 17: R= 4 Ohms, V supply is 14.4V, Bridged mode configuration
    In the example shows = (14.4^2 / 2) / 4 = 25.92W
    The 14.4 is the peak Voltage due to bridge mode.
    So in single end mode, the Vpeak will be only 14.4Vp-p/2 =7.2Vp
    So using formula in post 17 with Vp of 7.2V due to the supply Voltage is 14.4 V and in single ended mode = (7.2^2 / 2)/2 Ohms = 12.96 W R.M.S. So where does 25.92 Watts RMS into 2 Ohms in single ended mode come from?
    Am I missing something? From the Radio Amplifier manufacturer product spec sheet? Which will not be surprised.
      master hoarder
      • May 2008
      • 12170
      Nope, you are actually 100% correct . For some reason, it was stuck in my head that the power calculation that was done in post #17 was with a 2-Ohm load *and* SE mode operation. Apparently, a big brain fart on my part, because that calculation was done with a 4-Ohm load and BTL mode (*sigh*, that's why you don't post math calculations at 1 in the morning - or at least I shouldn't). Hence the bogus 25.92 Watts RMS in my post above. Sorry about the confusion there.
      So yes, with 14.4V input supply and a 2-Ohm load, the theoretical maximum RMS is indeed 12.96 Watts, as you found.
      But again, this does not take the peak output current limitation of the IC into account. Therefore, this still applies:
      Originally posted by momaka
      And what if you try to drive all four channels simultaneously and equally? Then that 3.5 A repetitive peak output current rating is split into 4 channels - i.e. each channel will be able to supply only 3.5 Amps / 4 = 0.875 Amps to each speaker. With that current limitation and the same 2-Ohm speakers, the maximum peak repetitive output power per speaker becomes as I stated in post #18:
      P = (I^2)*R = (0.875^2) * 2 = 1.53125 Watts per channel, with all four channels driven simultaneously and equally.
      ... unless, of course, that peak output current, Io, is for a single channel. The datasheet doesn't say, though. But I wouldn't give it benefit of the doubt. When you have to make assumptions about parameters, always assume the worst case. Otherwise, kaboom may pay you a visit.
      • flibidy
        Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
        by flibidy
        I have here a Magnum IA.100 which belongs to my parents.
        The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
        Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
        What Ive done........
        01-01-2025, 01:26 PM
      • waigy
        Nikkai EAPA 450 car amplifier rear speaker output is a low level and distorts easily
        by waigy
        As the title.
        I think these used to be sold in maplins a lot of years ago, it is an antique, but it's just fine for my needs.
        It looks basic enough inside with large components so I could do a full recap pretty easily.
        Any suggestions on what component would cause the symptoms of low volume output on both left and right rear speaker outputs?
        If I turn up the rear gain level in the amp until the speakers start to distort it starts to distort quickly even though the speakers are still pretty quiet.
        I thought I had dodgy speakers as I just fitted new old stock 6x9s in...
        11-08-2024, 03:53 AM
      • shelby5041
        clock radio / radio lifespan?
        by shelby5041
        hi
        ive got a modern digital clock radio approx 15yrs old
        my question is how long can a clock radio or a simple radio last ss farcas operating hours?
        since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
        the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
        it uses very little power just a few watts i would imagine that may have something...
        09-14-2024, 03:30 AM
        NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
        I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
        I bought this from an eBay seller but unfortunately they only had one
        I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
        I bought three of from them to also make battery packs with this output power limit in mind
        I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
        04-23-2025, 05:50 AM
        Corsair CX750M [Model 75-002019] - burned output toroid inductor
        by momaka
        Looks like I may need a little help from the PSU experts (or anyone really! ) I have a Corsair CX750M (Model 75-002019) that I picked up for free about 4 years ago. This is the PSU:
        So here’s what’s strange about this one: it appears to work normally (normal output voltages) and any PC is stable with it. However, after a while (typically 10-20 minutes, but time can vary depending on the load), there is a sweetish smell of burned magnet wire insulation emanating from the PSU. Upon opening the PSU after this happened (many times), I was able to confirm...
        09-19-2021, 08:44 PM
