Can't Remember Why?
  • bogart219
    • May 2009
    • 175
    • usa
    Can't Remember Why?
    Hey fellows. I have 13.8 volt DC power supply that I have had for a long time.
    Years ago, a co worker added two Chromalox 10.5 ohm What I believe to be resistors on it. I can't remember why exactly he modified it this way. I'm not sure if it was to increase the amperage or just a dummy load for it to work better? Anyone have any idea's? Thanks
    http://www.mediafire.com/view/lc98b7...020321.JPG%5D#
    http://www.mediafire.com/view/kdn1rd...b/P1020325.JPG
  • Longbow
    • Jun 2011
    • 623
    Re: Can't Remember Why?
    Classy mounting arrangement. Makes it look like the USS Enterprise.
    If you don't have a particular reason, disconnect them. How can we tell from a photo how these resistors are connected (are these even resistors)? Maybe someone needed 6 volts instead of 12 volts, who knows? The supply is almost certainly a linear supply, designed for (more or less) constant loads.
    You may be searching for the term "bleeder resistor". On the planet I come from, they were used to discharge high voltage filter capacitors and improve regulation on high voltage low current supplies. After removing the alien parts, save them in a glass case and they will be worth a fortune some day.
    Is it plugged in?
      • 30964
      it looks like one of the desk-bricks we used to use to test cb radio's
      the best improvement for those is a big electrolytic cap and a .47uf ceramic in parallel on the output
      • bogart219
        • May 2009
        • 175
        • usa
        The top disk is wired to the bottom disk. From there, one wire comes out. Strange.
          • 30964
          if they are wire-wound, maybe it's a choke?
          • bogart219
            • May 2009
            • 175
            • usa
            [QUOTE=stj;617189]if they are wire-wound, maybe it's a choke?[/QUOT
            That rings a bell. Wonder why he would put a choke on there? Thanks!
            • TinkerTron
              Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
              by TinkerTron
              Hey everyone,
              I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
              Instead, here's what's been bugging me so far:
              The schematic...
              03-06-2025, 02:03 PM
            • brightest_z
              Hot Air Blew Away Resistors Near Bios
              by brightest_z
              Hi All - I'm in the midst or reprogramming the bios on my gen1 Surface Laptop Studio and I accidentally blew away 2 resistors nearby the bios. I don't have another board to measure values of the missing resistors and schematics aren't available, bbut the bios is a 6x5mm Winbond WSON8, W25R256JWPQ model. The traces are conductive to Pins 3 and 7 (IO2 & IO3 respectively) so I have reason to believe they are 10k pull up resistors since IO2&3 pins are used for Quad SPI instructions.
              Does anyone with more knowledge, and experience than I, know if this is the case?
              12-11-2024, 08:34 PM
            • jinu_j
              LED driver circuit. Burnt Resistors
              by jinu_j
              Hi Folks
              This has to do with a LED light driver rated for Output - DC36-65V 300mA. This is used to drive a 15W LED panel light.
              Now this does not work so opened up and found 2 resistors burnt to crisp. Sensing a learning moment, i looked around the circuit to figure out that it is built around the OB2538 chip. The circuit to a large extent follows the sample application circuit mentioned in the data sheet. I have traced the actual circuit and the same is also attached for reference.
              But i have some queries on this circuit
              1. The resistors that burnt to crisp...
              08-26-2020, 01:24 AM
            • repair-it
              Pioneer VSX-40 ,Trying to ID these resistors
              by repair-it
              I am trying to determine why these two resistors are the colors that they are. This is a Pioneer amp. The ones I am concerned about are the RED & GREEN colored resistors. I need to replace them and want to be sure to use the properly rated component....
              12-16-2024, 02:08 PM
            • BustinCaps
              Dell 2007WFP resistors under white silicon blog
              by BustinCaps
              My beloved 2007WFP just died on me. It has a green blinking light that just cycles through various display numbers. For a while I noticed it would blink slightly like the refresh rate was off. Nothing I have done has been successful in turning it on. So I took it apart and looked at the USB board since many people have had problems with the resistors under the silicon blob. I looked at the various other boards for the obvious signs such as blown caps, bad fuses, burn marks etc. Nothing looked obvious. I also checked most of the caps with an ESR meter and they checked out good.
              04-29-2022, 06:19 PM
