FT labs detectors
  • barry wilkins
    • Aug 2009
    • 172
    FT labs detectors
    Does anybody know how these probes work ?
    They plug in to a audio socket on a phone ,and software drives them.
    So how does this work ?
    Barry Wilkins
    Re: FT labs detectors
    Are you talking about this thing?
    http://www.ebay.com/itm/Smart-Geiger...-/291401260715
      • 31159
      radiation hits the sensor creating a pulse, the sotfware counts the pulses per second - that's all.
      it's probably junk in something that small.
      btw, there was a guy who used the cmos camera as a sensor so you only needed the software
      you can probably use these things to know when not to aproach something, but you wont get useable numeric readings from them.
      • barry wilkins
        • Aug 2009
        • 172
        Hi yes it is the one for radiation I was looking at.
        As I understand the jack plug has 4 poles
        The barrel is the sound in
        The first ring is ground
        The next ring and the tip are the two stereo outputs.
        I am hoping the device powers the device using the stereo connections and uses the audio input for the signal from the detector module.
        Barry Wilkins
          • 31159
          probably, by generating a high volume waveform on the audio that can be rectified & smoothed at the device.
          it wont do the amplifier much good though even if it is a clever trick!
          • sofles
            Bowers & Wilkins PX7 S2 Needed help with identifying charging IC
            by sofles
            Hi there,
            Recently I bought broken Bowers & Wilkins PX7 S2, the problem with them is that battery discharges on its own even with headphones turned off. It is a quite common issue with this model and even with model higher PX8.
            With help of thermal camera I found out that there is one IC that is hot even with headphones turned off. To check if I'm correct I bought another PX7 S2 working one and replaced small charging board with this IC and problem solved, battery no more drains on its own. After changing board back to original problem returned so I'm 100% sure problem...
            05-30-2025, 01:11 PM
          • corrize
            Small and robust multimeter probes
            by corrize
            Hello, I search a new probes for measuring pin of qfn and other very small stuffs. I bought the AE basics ones, but they are no longer sharp. Metal is bad. Do you have a stonger ones ?
            05-13-2023, 02:36 PM
          • sigh45
            Bowers & Wilkins PX7 S2e Internal Photo's
            by sigh45
            This is a long shot but does anyone have a photo of the USB Charge board wiring? I have a pair here that somebody has used a blowlamp to get the port off, Luckily the tracks are all good but some of the NC and filter cables were desoldered. A new port is fitted but there isn't a sniff of any marking on either side of the headphones as to the cables use. Here's hoping
            Cheers
            Simon
            11-09-2024, 07:46 AM
          • tvguy12012012120
            by tvguy12012012120
            02-07-2025, 05:13 PM
          • SolomonMan
            Vintage BK Precision 1403 Oscilloscope....
            by SolomonMan
            All,
            Some of you have helped me in the past and I am very appreciative of all the help! (I have fixed TVs/Stereos/ and other small appliances with your efforts...Thanks so much!!!
            Today I went to a local HAM Radio Festival. It was one of the smaller ones in our area. My stepfather is the HAM operator. I tinker in electronics but am a Software Programmer (27 years now).
            I was looking for a few odds and ends for some electronics work I have to do for the household/farm. Typically these type of shows have the grab bags or a electronics vendor...
            12-03-2023, 10:39 PM
