Trouble finding a Variac
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Requesting for a bit of help. Im currently after a variac as the other day was testing a tube amp and as soon as I plugged it in 3 of the paper caps blew up in my face, after rethinking carefully what I had done wrong, figured it was because I brought them up to line voltage too fast causing them to explode. Don't suppose any one knows where I could get a hold of a variac it needs to be capable of 240 VAC @50-60Hz roughtly. If any one has any ideas where I could obtain one let me know thanks.
    • 31087
    Re: Trouble finding a Variac
    lol
    i would have re-capped it first.
    some stuff simply should not be preserved - ancient caps are top of that list followed by rubber-insulated cables.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Yeah lol im only 15 years and not really familiar to older electronics like this never expected such a bang, next time im going to be alot more careful and not put my head soo close lol. Planning on restoring it fully.
        • 31087
        i'v seen lots of caps explode - you *never* get used to it!
        closest i'v been was about 3ft from it - had to pick bits of paper & foil out of my hair afterwards!
        bastard xenon strobe lights really piss me off!!!!
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Lol it left some crap on the floor that was sizzling smelt horrible as well yum....
          Alot of them I can use some radial lytics I have around but before I do that I need to replace the following:
          Rectifiyer think its selium
          Every wire with high quality braided wire
          Caps
          Carbon resistors
          Possibly tubes need to test them on mates meter
          • Agent24
            I see dead caps
            • Oct 2007
            • 4978
            • New Zealand
            You should read up on tube equipment safety... you're lucky only the paper capacitors exploded. The big can electrolytics can go too, if they've been sitting around for a long time. You don't want a face full of toxic oil!
            -David VanHorn
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Yeah lol at the time I was busy enough and just wanted to see if it worked well I was in for a surprise....
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Now its a case of seeing if im able to fix and restore it, going to have to put it aside for the min as got other things to focus on will be fun to do though.
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  Still no luck, any one have any suggestions ?
                  • SteveNielsen
                    Retired Tech
                    • Jun 2012
                    • 2327
                    What particular amp is it? Have you looked for a schematic?
