Understanding the code for this cap
    LCD LED TV Service Menu Codes
    ALL LCD LED TV SERVICE MENU CODES
    Service Menu Code with Board Name
    China Universal Board / Jumper Board Service Menu Code
    Changhong Ruba Service Menu Code
    Ecostar LED TV Service Menu Code
    Orient LED TV Service Menu Code
    Haier LED TV Service Menu Code
    TCL LED TV Service Menu Code
    Samsung LED TV Service Menu Code
    LG LED TV Service Menu Code
    Videocon LED TV Service Menu Code
    Supra LED TV Service Menu Code
    Toshiba LED TV Service Menu Code
    Symphony LED TV Service Menu Code
    Veste/ LED TV Service Menu Code...
    10-31-2024, 03:58 AM
  • Curtissimo
    HP EliteBook 850 G8 - Error code / Caps Lock permanently on and blinks twice every 6 seconds
    by Curtissimo
    Hi everyone.
    I have a HP Elitebook 850 G8.
    Serial: 5CG2324XM0
    ProdID 6L8D5EC#ABA
    It has a Winbond W25Q256JVEN Chip.
    I need to remove BIOS Password.
    I made a dump with an CHA341A programmer and NeoProgrammer 2.2.0.10.
    Attached my dump.
    I also used the HP Unlocker tool to create an unlocked file (I followed the guidelines)
    I also downloaded latest HP BIOS Update (SP158137) which includes 3 .bin files. I found the Number T76 in my original dump, so I used: T76_01210000.bin
    What I did:...
    08-26-2025, 04:42 AM
  • cubytus
    Samsung UN50TU8000FXZC shows thin horizontal green line when warm
    by cubytus
    Hi to all,
    I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
    I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
    Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
    01-10-2024, 01:26 AM
  • Sorrow1
    Intergraph TDZ 2000 mainboard post code 2F/2E
    by Sorrow1
    I try to repair an old Intergraph TDZ 2000 from 1998. It is a dual Pentum II machine based on Intel 440LX chipset. There is a non-removable bios chip named PhoenixBios B1787840. I cannot see any physical damage to the board. All caps look OK.
    It shows no picture and POST stops with code 2F/2E regardless whether or not any graphic card is plugged in. If memory is removed, it stops on previous code 28/17 and stars beeping. I tested both CPUs in another machine and I also use RAM from another machine.
    When I recorded video of POST card and played it in slow...
    01-03-2024, 04:13 AM
  • DynaxSC
    MSI PRO Z690-A DDR4 (MS-7D25) - stuck during boot every second time - debug code 16 & A1
    by DynaxSC
    Hi Folks
    I have an MSI PRO Z690-A DDR4 (MS-7525) which underwent LGA1700 replacement and had a missing resistor in the VRM section. The missing resistor RV170 (49,9Ω) has been resoldered, and I have also replaced a demaged LGA1700 socket.
    Generally the board does boot to Windows, but not always in the first attempt, but after the second attemp to boot the board with Power Button. Also restarting the board from Windows ends up with stuck boot process, but restarting the board again (long push Power Button or switching off and on PSU). Under Windows etherything works
    09-29-2024, 04:27 PM
