Beware of "new" Sharp H8147AF laser pickups (CD)
  • Chungalin
    • Jul 2014
    • 423
    • Spain
    Some sellers (either at eBay or AliExpress) try to sell obsolete Sharp H8147AF laser pickups claiming they're in NEW condition. When you receive it, it doesn't look very "new".
    Beware if the label is exactly like the picture attached, including shape, color, numbers and typography. In that case, your pickup is very likely refurbished and possibly very used.
    It's nearly impossible that two pickups have the same callibration numbers. Even more, this yellow label is MASS PRINTED, while original labels were printed individually at factory for each pickup. Font was like a dot matrix printer, and color was light green or orange. This one is printed in Arial-like font. These pickups have been relabeled.
  • trebo
    • 514
    • Wales, UK
    Re: Beware of "new" Sharp H8147AF laser pickups (CD)
    Jeepers that is very much used, how do they think they can get away with that, It beggars belief
    • CalculuS
      • May 2015
      • 3
      • Netherlands
      Yeah Aliexpress is only crap actually. Seen a guy buy a GTX 660 from there, turned out to be a GTX 8800 with a fake bios.
      Current Specs:
      I5-3570k @ 4.4Ghz(1.22V Rajintek Aidos)
      GTX 970 JetStream
      ASRock P67 Pro3 SE
      Corsair Vengeance 1866Mhz/CL9
      Cooler Master Thunder 700W
      Oldschool WIP build:
      MSi KT4V
      AMD Sempron 2400
      2X512MB DDR2
      6800GT Asus Ultra
      FSP-300W
      • Chungalin
        • Jul 2014
        • 423
        • Spain
        In my case, I bought one of these pickups on October 2014 from a german seller at eBay. The second one was bought from another german seller too, and both pickups had exactly the same label. So, the problem is that even if you avoid AliExpress, another one will buy from there and resell that crap to you at a higher price, which is even worse.
        • Dannyx
          Hilti PD30 Laser Range meter Error 276
          by Dannyx
          Good day folks.....wow, seems like forever since I posted anything here Still alive and well, thank you I guess you could say I've become more independent and able to work stuff out on my own. This one though goes way over my head and I doubt is fixable, but maybe some bright spark out there has an equally bright idea.
          So: my Hilti PD30 laser meter quit on me just the other day. It was working fine, I set it down for a while and when I tried using it again it gave me an E276 and wouldn't do anything else. I tried taking out the batteries, all that standard stuff but nothing...
          07-30-2023, 05:05 AM
        • advant
          by advant
          02-03-2020, 12:25 AM
        • sefoster
          Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
          by sefoster
          I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
          11-20-2022, 09:29 AM
        • gavenb
          Sharp LC-80LE661U 80 inch
          by gavenb
          Hi folks!
          I have a LC-80LE661U that had some interesting issues.
          Initially, it would come on and show the sharp logo and would show normal static before shutting off.
          I started troubleshooting by disconnecting the led lighting strips and turning it on. It would do the same thing - come on, show the sharp logo and shut off. After reading, it was suggested to replace the main board. That was replaced and the same symptoms resulted. After this and some reading, the parts cannon got loaded up. I replaced the power board, same issue. Replaced the Tcon board and now it...
          11-12-2023, 02:05 PM
        • SONY_E-WASTER
          Help! Sharp LC-70UE30U 3 long flashes + 3 short flashes.
          by SONY_E-WASTER
          Hello, I'm new to this forum. I like to tinker with Sony electronics, I have been lucky trouble shooting sony stuff, But I can't find much info on this Sharp TV.
          The problem; plug to power>white led power indicator light is on>it turns on to the red Sharp logo>
          then the android logo is displayed, lit fine then the android logo brightness varies, then lit normal, then the tv restarts and does the same startup logos over and over for 5 times then it turns off and the power indicator light flashes the trouble code 3 long blinks plus 3 short blinks .
          does...
          12-26-2021, 05:46 PM
