Bios programmer
  • nackgr
    • Mar 2015
    • 18
    • greece
    Bios programmer
    Hello
    i want to start expiriment with bios chips .. i was searching bios programmer , what u think is proper for a variety of laptops?
    i saw that
    http://www.ebay.com/itm/121493860355...%3AMEBIDX%3AIT
    • 30965
    Re: Bios programmer
    dead link.
    • Spork Schivago
      • Mar 2012
      • 4734
      • United States of America
      Re: Bios programmer
      I think they meant this one:
      http://www.ebay.com/itm/USB-Programm...item1c49993003
      -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
      • nackgr
        • Mar 2015
        • 18
        • greece
        Re: Bios programmer
        yes that!!
        • Homer79
          • 13
          • england
          Re: Bios programmer
          I've been looking at, it supports more chips you find in laptops.
          http://m.ebay.co.uk/itm/400841941718
          • torla
            • 76
            Re: Bios programmer
            which is the best bios programmer pls link for buy.
            • Agent24
              I see dead caps
              • Oct 2007
              • 4940
              • New Zealand
              Re: Bios programmer
              Learn about them and do your own research... the best one will be the best one for you.
              The best quality one for example might be a high-end one costing hundreds of dollars. To a corporation that would be best for support and repair in the future... but for a hobbyist a waste of money...
              You need to know what *you* are going to use it for, to find out which one will do what you want.
              Get one that does the chips you want to program, and has decent software with it (good software is most important!)
              Read reviews and compare software and reliability etc... can you get adapters for new chips? Will there be new software in the future to support new chips or will you have to buy a whole new programmer?
              Only you will truly know which is the best one for you. If you don't know that yet, you probably shouldn't be buying one yet.
              -David VanHorn
              • STKR123
                The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                by STKR123
                Greetings badcaps community,
                I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                I learned that desoldering...
                10-29-2024, 06:03 AM
              • hotcrossedbuns999
                M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                by hotcrossedbuns999
                My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                3. I could only locate two chips that look like bios chips. Could someone verify this
                01-03-2025, 12:32 PM
              • zlr8r
                looking for fully extracted by programmer Bios for a Dell Inspiron 17 (7786)
                by zlr8r
                looking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
                cheers
                Dell Inspiron 17 (7786) Laptop
                Service Tag: 5J0NHT2
                Bios: 1.9.0
                MOBO: RO 15 17 WHL 2GB MB / 18706-2
                Attached;
                1. My saved bios using a programmer
                2. Dells Bios updater .exe (v1.16)
                3. Dells Bios recovery file
                4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
                5. Image of ME...
                12-18-2023, 03:08 PM
              • what_1282105
                Thinkpad t480s, completely dead after BIOS flash using CH341A programmer
                by what_1282105
                Following this guide (https://www.reddit.com/r/thinkpad/co...g_and_flashing) i re-flashed my t480s BIOS using an external (CH341A) programmer. The flash didnt work, so i reverted back to my BIOS backup successfully. The BIOS in the chip and the BIOS backup file are identical according to windows' file compare. The revert, however, didnt work: the only thing the computer does is flash the power button 3 times when AC power is connected. I've tried unplugging the CMOS battery, holding the reset button and holding down the power button- no signs of life....
                02-14-2025, 07:27 PM
              • mikeybass
                by mikeybass
                04-23-2025, 04:30 PM
