I have a few questions. I have a simple circuit I made using a breadboard. It's 4 AA batteries hooked up to a potentiometer and an LED. The potentiometer is a 2K one. My DMM shows the voltage from the batteries as 6.46VDC. The resistance on the potentiometer is currently set for 986 Ohm (according to my DMM). I try predicting what the current should be for the circuit using Ohm's law. I have I = ΔV/R. I = 6.46 / 986, I = 6.551724 mA. When I use my multimeter to test the current though from the positive terminal that goes to the LED, I get 4.31mA.
The way I test it is I place the multimeter probe between the wire going to the red post (the positive terminal) and I place the other probe on the positive side of the LED (the anode side I believe). Why does the multimeter show the current to be 4.31 mA but Ohm's law says it should be roughly 6.55 mA? I've replaced the battery in my multimeter. Does it mean it's failing? Thanks.
