Re: Question regarding Ohm's law and a Digital Multimeter.
I don't need to do a damn thing.
I wasn't the one who sent him on a wild goose chase, over something that wouldn't possibly affect his ckt.
You did the same thing. People have been getting so caught up in this "maker" stuff, that they've begun to assume that unless they're "told" something, a person, individually, can't figure it out. There's not much simpler than the OP's ckt, yet your claims of burden voltage, which I might add would never have crossed your mind unless you too were told about it, perhaps by a maker-breaker.
What about the percent impedance/regulation of his supply voltage, or even the effect of worn test leads? Both of which are more of a problem, and real ones at that.
You claimed to "educate" the OP, but didn't even realize yourself that you're suggestion had no bearing, suggesting that you yourself had been mislead at some point. Quit being a maker, and start being a learner and thinker- nothing better than this.
You're peeing on my leg. Didn't I suggest not overthinking this? You don't have to "set anything up" to know that the shunt impedance of that DMM is insignifigant compared to the dropping resistor already in the circuit.
Just as you don't have to "set up" and pull the ESR meter out to "confirm" the blown Sacons are bad- if that's not overthinking and "getting all theory," tell me what is.
So you're suggesting that this fraction of an ohm matters just as much as the pot, simply because "it's in the circuit?"
Why are you failing to make this leap?
I guarantee you googled that in the last 20 minutes; you had no inkling of Ohm's law's implications, yet you suddenly show me the I2R power formula?
Do you have hands-on electronics experience beyond "making" things on a breadboard? Don't answer me unless you've actually designed your own circuits, even if it's an LED and resistor, like the OP.
People are being mislead by the "makers," and slowly becoming "breakers," without even realizing it.
Originally posted by mariushm
View Post
View Post
View Post
View Post
View Post
